#62 |
![]() Join Date: Jun 2011
Yeah pretty much...just for launching when I'm drag racing....I'm building boost just fine when I'm sitting still, the car just falls on its face when I let out on the clutch, unless I ride the clutch out a good ways...
#63 | |
AFC #1
![]() Join Date: Oct 2003
Ign Cut and Rev retard should be the same. Try to lower it to the point where you are max boost building. Max VSS: 2
#65 | |
![]() Join Date: Aug 2008
![]() [email protected] |
#66 |
Little testing on my s13Rally style anti lag tuning and system set up explained.
This car is using the secondary air injection kit I found this particular set up doesn't need much keep the turbo boost happy. On ignition cut set up at the track or under heavier use you do start to get a good bit more noise and flame. I like the ignition cut option as it helps keep heat/stress off the exhaust valves. |
#68 |
![]() Join Date: Nov 2005
Seems like you're running pretty small turbos tunermt. Ever set this up on a car with something like a gtx3576 or Borg S300 series?
#69 | |
some launch control with "drag style AL" and the same car with no lift to shift set up (actually works VERY similar to a throttle bypass style ALS). |
#71 |
I am planning the following system.
- Evo SAS valve. - Vacuum canister / check valve - PWM solenoid on VAV canister to SAS valve. I have a couple questions. I assume the injection ports must be at a 90* angle to the manifold runners (to induce suction from charge pipe). Will the exhaust overpower the charge pipe or will the SAS valve act as a check valve? Also, can I utilize cyclic timing cut and add fuel or must I retard timing to ensure fuel gets to manifold? |
#72 | |
#73 | |
Can you give me an explanation of how it is supposed to work? |
als, antilag, brewed, tuning |
