#61 | |
Guest
Posts: n/a
ELEPHANT RACING Tech Topic, Polyurethane Bushings and Friction I removed my polyurethane bushings and noticed a significant amount of wear within the bushings where the metal shaft/tube rotates in the bushing crevice. The polyurethane looked like it started to clump together and tear a bit, not a significant amount but enough for me to call it quits and move onto the nismo bushings. Now, I received a bunch of nismo bushings several weeks ago and get this, the ones that were supposedly for the lower control arms did not fit. not only did they not fit, but they looked (and measured) damn near identical with the ones that fit the upper arms and spindle! I'll have to snap some photos. Does anyone have part numbers for the nismo bushings for the lower control arms by any chance? Thanks |
#62 | ||
![]() Join Date: May 2003
The new T/C rod bushing are perfectly fine. They realized there was a problem, redesigned them, and they now allow the flex that's needed so your front LCA won't crack. Yes, spherical bearings are better...but we all knew that. But the new ES bushings, and the master kit...ARE FINE. - Brian
www.KA24DEvelopment.com |
#63 | |
Super Moderator
![]() Join Date: Jul 2007
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
#64 | |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
NISMO SUBFRAME BUSHINGS PT # 55400-RS590 NISMO REAR AXLE&LOWER CONTROL ARM LINK PT# 55157-RS580 NISMO REAR SPINDLE BUSHING PT# 55157-RS521 |
#65 | ||
![]() Join Date: Mar 2003
this website also has the part # information
Nismoparts.com - Your #1 Source for OEM Parts and Accessories (add to cart, then view cart, it will display the part #) Quote:
#66 | ||
Guest
Posts: n/a
#67 |
If usually the ES only allows rotation on 1 axis, shouldnt the metal casing be rotating around the actual bolt? I would think as long as you use antiseize you shouldnt have too much of a binding issue.
I see rubber as more of an issue when the bolt seizes, such as the LCA. Those were torn because the bolt was seized to the casing, and the up/down movement was binding in the rubber. I do reccommend ES LCA bushings, they work great. |
#68 | |
![]() Join Date: Feb 2005
I noticed when I installed mine that when the wheels are off of the ground the hem joint is even -[]- but when the tires are on the ground the hem joint is slanted -//-. It should be even when the tires are on the ground so there is an even amount of travel within the hem joint for flexing? What I did is just look at the way they were leaning -\\- and then jack up the rear and turn the hem joint the oppisite way -//- then retighten them and lower the car back down and they now are straight -||-!!
#69 |
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
OK it's time for me to come in and clear up some shit here.
First off energy suspension has updated their design since 2004 (when this thread was started) and their tension rod bushings no longer crack control arms. They used to be soild one-piece bushings, which caused a lot of bind and cracked arms. Now they are a 3-piece design and work much better. Never buy solid urethane bushings for the tension rods no matter who makes them. Second for the entire rest of the suspension urethane works ok. Not perfect, but ok. I have seen some rear arms break i think due to bushing bind though(a RUCA and a toe arm). I personally have urethane FLCA, RLCA, and rear upright bushings on my car still and I am happy with them. The key to urethane bushings is to keep them well lubed at all times. I installed zerk fittings on mine so that I can easily lube my bushings whenever I want. I HIGHLY reccomend that anyone installing urethane bushings does the zerk fittings. The urethane bushings seem to lose lube quickly (a couple months) and when they do they bind like hell. As long as my bushings are lubed I can compress my suspension all the way up with the shock dis-connected. Third I would not reccomend the nismo bushings for any of the suspension arms. For subframes and mounts they are fine, but not for a suspension arm. The design of the nismo bushings inherently has more bind. The inner sleeve, bushing, and outer sleeve are all glued together. This means that for the suspension to move the bushing rubber has to twist. On top of that the nismo ones are a higher durometer rubber so they are even harder to witst then the stock ones. At least with a urethane bushing you have one free axis of movement. Anyone who does have the nismo or stock bushings in their arms please be sure to tighten all the suspension arms with the car on the ground. This will ensure that the bushing is in it's normal position at ride heighth and help eliminate some bind. With urethane bushings that is not necessary though. |
#72 | |
Guest
Posts: n/a
any pics of how you installed grease fittings in your arms? ide like to see how the grease goes from the outside to the inside shaft that sits on the bushing. |
#73 | |
Guest
Posts: n/a
55157-RS580 - RUCA, Traction & Toe Arms - 6 per car (3 per side) 55045-RS580 - RLCA - 4 per car (2 per side) 55157-RS521 - Spindle Bushings (for RUCA & Traction) - 4 per car (2 per side) 55152-RS520 - Spindle Bushings (Toe) - 2 per car (1 per side) Subframe: 55440-RS520 - Front Subframe (2 needed) 55442-RS520 - Rear Subframe (2 needed) Front LCA: 54535-RS520 - 2 per car what a pain in the ass, so many fucking different part numbers.... and allergies dont help. |
#74 |
The Architect.
Awesome.
My plan is, since I have this spare subframe, throw on ES bushings on one, Nismo bushings on the other. Reading only does so much for me. Actually driving a car myself with different bushings allows me to decide for myself what I really want. Greasing isn't really a problem to me since I don't drive the car often and after a certain point, I'll need something to work on anyway. Hah. |
#75 | |
![]() Join Date: Mar 2007
#76 |
dont you just drill/tap?
Take it even further by making a passage around the whole bushing in the center, chamfer/deburr the edges, and installing the zerk. This way your bushing gets a full 360 of grease, and its also like a reserve. |
#77 | ||
I would say: bearings > urethane > stock > nismo The stock and the nismo are pretty close though because the nismo bushings lessen bushing flex in bad directions as well as good ones. Quote:
I did it the quick way and it works alright. I just drilled and tapped. If I had it to do over again though I would spend more time chamfering the holes and I would use a dremel to make a spiral groove inside the bushing to distribute the grease better. |
#78 | |
![]() I might have to shave a little off the upright.... the rear shock is hitting it slightly. I've been looking for a cheaper alternative for that shock mount bushing but cannot find anything other than SPL's which is rape. Sadly it looks like I will have to eventually bend over and just take it. As for the tension rod bushings I have experience with nismo's, ES, and the SPL rods. Nismos are hands down the BEST for daily driving only because they don't rattle your teeth out and still stiffen everything up a good amount. Just be sure to get them pressed in correctly.... with the arrow pointing toward the back of the car. ALSO be sure to tighten the tension rod with the car on the ground to avoid tearing them up. ES requires too much greasing and the spherical rods are too much for my kidneys |
#79 | |
![]() Join Date: Jun 2003
oh jesus. these are just from this page.
#80 | |
#81 |
![]() Join Date: Jan 2005
[QUOTE=cdlong;2714289]oh jesus. these are just from this page.
Thanks, it was late and i may have missed a few posts. I have the 3 piece one's installed, i was just curious. ![]()
#82 | ||
Guest
Posts: n/a
i disagree mostly with you're view because you're saying that the factory-style bushings (oe or nismo, doesnt matter) are restrictive - this is the point of the bushing, it not only acts as an insulator but also will spring back the suspension arms back into their normal position. I dont see this as a problem at all. they're part of the suspension and they work as intended. by the way, being that there are so many different part numbers for the same sized bushing (as i listed above), it would make sense that the difference is in the durometer of the bushings.. that some bushings in the arms or spindles should flex less while others should flex more. here is a question for the pros... is it possible to use s13 rear shocks on Z32 rear spindles if you press in that metal stud that secures the s13 shock? that would be very trick. unfortunately, the only z32 spindles ive seen on s13s also use z32 shocks. Last edited by ixfxi; 03-26-2009 at 04:19 PM.. |
#83 |
i just installed the ES 3-pc tension rod bushings in my stock tension rods. i am very happy with the difference it made in the ride of my 89' hatch. a few days earlier i switched to new agx's w/teins and the tension rod bushing made more of a difference in the ride than the springs and struts.
after this thread popped up i inspected the angle/bind on the bushings with the car on the ground and it was centered and didn't look like it was under any stress. my guess is that on excessivly lowered cars, the geometry is already in a "stressed" setting and then when you hit a mean dip on the freeway, it gets pushed too far and something has to give. i would say even the old design bushings would not be a problem unless you are sitting on the ground, tuckin' rim.
IG - @24deee |
#84 |
![]() Join Date: Dec 2002
Mike, you cannot use the S13 stud in the Z32 upright without significant modification, IE welding a portion of aluminum into the upright then drilling/tapping for the stud at the correct angle. This would eliminate the need to use Z32 shocks in the rear but I've never met anyone willing to make the effort. The angle alone is your main concern as it would need to be precisely set up to match the S13 upright under both full load and unsprung load. Since the Z32 upright already sits at an angle it'd be hard to get it perfect. The spherical bearing in place of the bushing is the more ideal situation all around, you just have to use Z32 shocks. Some people don't like going that route since the Z is heavier and therefore the shocks are a different preload, in that case you just go with coilovers and matching Z32 fork mounts.
As far as urethane bushings in the uprights, these don't wear near as bad when used with arms that have spherical bearings, as the arms do allow for more twist than a stock arm. The better setup would be spherical bearings at both ends, but the cost and ride comfort level are heavily effected. You're going the better route by using the Nismo bushings since they're still compliant to an OE level but with reduced flex.
#85 |
For the z32 rear spindle Why dont you just machine an aluminum rod down to size and drill a hole in the middle of it, then press it into the z32 spindle. no bushing ,solid mount. If you grease it up well it shouldnt bind, the rear suspension only moves so much.
ANTI-STRETCH NAZI Vortech Supercharged Vh45de S14 V8nissans.com |
#86 | |
the t/c rods are bolted directly to the LCA, but they do not move on the same axis as the LCA. the t/c rod bushing will be inevitably subject to a twisting motion as the LCA moves, even at a stock height. since poly bushings don't allow for much deformation, something will have to give. |
#88 | |
Guest
Posts: n/a
i am thinking if i pickup Z32 RUCA/toe arms, to slot them and then re-weld material with the new hole position, that way they're pre-slotted and reinforced. that, or i will have to compromise and run solid RUCA/toe., not that bad i dont think. |
#89 | |
#90 |
Guest
Posts: n/a
![]() ![]() ![]() here we have it, pics showing the wear that occurs on the inside of the bushing. you can see wear marks on the shafts and chunking of polyurethane as it heats up from constant motion on the shaft. edit: thats the rear LCA bushing. |
