Old 02-10-2013, 05:43 PM   #1
SLYDEWAYS 96
SLYDEWAYS 96's Avatar
Trader Rating: (34)
SLYDEWAYS 96 is an unknown quantity at this point
Feedback Score: 34 reviews
1996 S14 240sx SE PARTING OUT
Parting out a 96 240sx SE
110k
OBDII
5 speed
Stock KA24DE
Red Exterior
Black Leather Interior
Front end is damaged so there is no hood, bumper, lights or fenders.
-Tein basic coilovers, also have stock suspension.
-ES bushings in the subframe and diff.
-Has brand new floor mats custom made from matworks.com
-New cross drilled & slotted rotors and pads have less than 100 miles on them.
-8 ball shift knob
-Stock s14 SE rims painted black with fuzion touring 225/50r16 all around w/ less than 100 miles on them.
PM, POST or TEXT whatever you need and offer a price.
Anything not on the sold list is available.
I prefer local only but will ship at buyers expense.
516-348-4478
PARTS SOLD
-Front 5 lug hubs
-Front spindles
-cluster
-Rotors
-Driver seat belt
-Wiper switch
-Shifter bezel w/ boot
-Radio bezel
-speed sensor
-Driver side mirror
-Coolant reservoir
-Steering column cover
-sun visors
-driver window motor
-rear bumper
-rear seat belts
-radio brackets
-MAF
-IAT sensor
-ECU
-Passenger door shell
-Front seats
-Rear Windshield
-Lock set
-Climate control
-Front Control arms
-Driver window switch
-Passenger window switch
-Mirror adjuster switch
-Wiper motor linkage
-Engine harness
-Tein Coilovers
-Back Windshield
-Back seat panel
-Gas line cover wheel well
-Tension rods
-Steering rack
-Power steering pump
-Power steering reservoir
-Power steering lines
-Clutch pedal assembly
-Brake pedal assembly
-Shifter boot
-Transmission
-Stock shifter
-Rear 5 lug hubs
-Rear spindles
-Exterior door handles
-Interior mirror covers
-Cluster tirm
-Trunk springs w/ hinges
-Trunk & gas cable
-Trunk lower latch
-Engine mount brackets
-Gas cap
-Sunroof Assembly
-Sunroof Control/Dome light
-Rear dome light
-Dashboard side vents
-KA24DE Engine
-Clutch & Flywheel
-Subframe
-Rear links
-Rear sway bar
-C pillar panels
-Interior fuse box cover
-Windows
-1/4 Windows
-Exhaust down pipe
-Exhaust mani
-Fuse box & harness
-Brake booster
-Window swtich bezels
-Throttle cable
-Brake master cylinder
-OEM knob
-C Pillars
-Motor brackets
-Trunk mats
-AC blower
-All seat belts
-Diff
-Axles
-Carpet
-Glove box
-Trunk
-Spoiler
-Roof
-Headliner
-Driveshaft
-Cross member 5 spd
-Front subframe bolts
PARTS AVAILABLE
_________________
-Rear seats
-Rear arm rest panels
-Door sills
-Rear speaker cover
-Floor mats grey/red
-8 ball shift knob
-Gas pedal assembly
-Dead pedal
-Center console
-Spare tire donut
-AC lines
-Stock exhaust
-Windshield washer pump
-Windshield washer reservoir
-Front sway bar
-Trunk weather stripping seal
-Window weather stripping seal
-Cruise controller buttons
-Cruise control module
-Pioneer radio deck
-SE headlight switch
-Heater core
-Ebrake & cables
-Passenger mirror
-Rear view mirror
-Door handle trims
-Starter
-Clutch slave cylinder
-Passenger window motor
-Window rails
-Interior door handles
-Actuators
-Driver door
-Quarter panels
-Door panels
-Dimmer switch
-Cruise control switch
-Stock s14 SE rims
-Brake calipers w/ pads
May be missing some things...let me know what you need
taillights, trunk, spoiler, & bumper
lower rear seats
upper rear seats
stock exhaust
floor mats dark grey/red
rear speaker cover
rear driver side arm rest panel
rear passenger side arm rest panel
door sills
windshield washer reservoir w/ pump
OEM shift knob & 8 ball shift knob
roof/head liner
rear subframe with open diff, hubs, links, sway bar & ES bushings; battery not f/s
window seals/ window weather stripping
interior panels
cluster trim, ac/heat vents, climate control, dome light, cruise controller, mirror adjustment switch, short throw shifter, pioneer deck, SE headlight switch, sunroof control switch, oem radio/ brackets
Last edited by SLYDEWAYS 96; 04-16-2013 at 07:30 AM.. Reason: *updated parts list*
SLYDEWAYS 96 is offline   Reply With Quote
