Old 09-09-2013, 08:50 AM   #1
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
s14 kouki sr20vet / cd009
follow me
Facebook : Pierre-Olivier Belisle
insta : blkreapers14
Built info
head:
p11 head machined for 1/2 studs
p12 cams
Yashio Factory p12 valve cover
Mazworx shimless valves
brain crower cam gears
Kelford beehive springs
Taarks hallsensor kit
Taarks single vvl conversion kit
Mazworx headgasket
Hypertune intake
Bosch 82mm dbw throttle body
bottom end:
s14 block sleeved with Darton sleeves + gtir main bearing mod
Mazworx billet main cap with 1/2 main and head studs
JE ultra serie sr20det pistons 87mm 10.5:1 (will work with ve swap)
Wiseco Boostline rods
det crank
King gtir main bearing
new timing chaine kit
new sr20ve p12 oil pump
taarks water pump delete
moroso oil pan
taarks oil filter relocation kit
taarks power steering relocation kit
taarks timing mark relocation
new seals everywhere
ATI crank pulley
Drivetrain:
Comp Cutch tripple plate
g37 transmission (with z34 rear tail section with gear position sensor)
Mazworx sr to vq Bellhousing
GKtech z33 shifter kit
4:10 gear
z33 axles
Weir performance z33 chromoly conversion hub with spool diff
Cooling:
c&r custom rad
Electric water pump
an fitting welded for rad hose
swirl pot custom made
oil cooler and power steering cooler
hot side:
Doc race sr20ve manifold with v-band flange and mvr waste gate flange (i provided a sr20ve flange to them ... flange from taarks)
custom down pipe
fuel:
Id ?
I will run e85
electronic:
Motec m130 (gpr , stage 2 loging)
Motec pdm15 with keypad
Motec c127 dash
Racegrade tc8 egt box
exterior:
Superdoof body kit
Bn Sports type2 Hood
Origin Labo type 3 front and rear fenders
dmax roof wing
Brake:
up front :
z32 calipers
Hawk hp+ pads
stoptech z33 rotors
z1motorsport conversion bracket
in the back :
z32 calipers
Hawk hps pads (regular brakes)
project MU d-spec pads (hydro hand-brake)
z32 stoptech rotors
HGK billet Hydro Handbrake
suspension and steering :
Sparco 2 spokes steering wheel
Custom steering column
fortune auto 500 v5 / swift spring (7k/6k)
Front:
Gktech top plate
Gktech front v3 knuckle
Gktech cromoly flca
Gktech front swaybar
Gktech inner /outter tierods
rack moved forward 35mm with custom c-clamp
BinkIndustries rack spacers
Rear:
Gktech rear Knuckle
Gktech rlca
Gktech suspension arms
Gktech subftame riser
Gktech subframe brace kit
SPL solid diff bushing
wheels
GAIA MMX III 2x 18x9.5 and 4x 18x10.5
rbs14kouki is offline   Reply With Quote
