Old 06-17-2016, 01:23 PM   #61
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
Hmm mine fit on with no modification. Check you have the mounts oriented correctly.
Did you round out that hole on the bottom left of the picture too or optical illusion?
bmaddock is offline   Reply With Quote
Old 06-22-2016, 08:39 AM   #62
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Optical illusion. And yeah according to the instructions, in order to place the mount in the forward most bracket configuration I had to notch it or it slid rub the turbo hardline
corkscrew is offline   Reply With Quote
Old 06-23-2016, 05:58 AM   #63
Black240Ct
Black240Ct will become famous soon enoughBlack240Ct will become famous soon enoughBlack240Ct will become famous soon enough
Send a message via AIM to Black240Ct
could be just bent up from shipping. my turbo water lines were kinda jacked up
Black240Ct is offline   Reply With Quote
Old 07-04-2016, 02:02 PM   #64
corkscrew
corkscrew's Avatar
So I know this thread is dead but I just wanted to post my own experience with the $4 Rock auto mount in the first post and the $12 crossover radiator pipe. The mount fit 100% bolt on minus having to drill the holes about 1mm longer, and the pipe fits great. I'm using xcessive brackets, oem mounts with the lips shaved, and the $4 Rock auto trans mount
Old 08-16-2016, 01:06 PM   #65
Freddy
Freddy's Avatar
Freddy is an unknown quantity at this point
Incase anyone was wondering about gates racing timing belt.
Part# T923R
Freddy is offline   Reply With Quote
Old 08-16-2016, 09:03 PM   #66
rvlliein
rvlliein is an unknown quantity at this point
ha! im almost finished! just needing it to start, no spark....gonna test the ecu plugs for harness.
rvlliein is offline   Reply With Quote
Old 08-18-2016, 07:38 PM   #67
Marques
Marques is an unknown quantity at this point
Is that $12 radiator pipe From ROCKAUTO and what category (car specific)would I look for it under?
Marques is offline   Reply With Quote
Old 08-19-2016, 05:43 AM   #68
corkscrew
corkscrew's Avatar
It's from Home Depot
Old 08-19-2016, 08:51 PM   #69
undant
undant is an unknown quantity at this point
Awesome thread good work! Sticky please!
undant is offline   Reply With Quote
Old 08-20-2016, 10:00 AM   #70
unndat
unndat is an unknown quantity at this point
unndat is offline   Reply With Quote
Old 03-24-2017, 12:07 AM   #71
ss_lambo14
ss_lambo14 has a little shameless behavior in the past
sorry i know this post might be old, but im currently in the middle of the same exact swap. and i was wondering if i need a tune after the swap is complete?
ss_lambo14 is offline   Reply With Quote
Old 03-25-2017, 04:42 AM   #72
bmaddock
bmaddock's Avatar
Stock ecu will be fine. Good luck
Old 07-09-2017, 10:11 AM   #73
beems240sx
beems240sx's Avatar
beems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant futurebeems240sx has a brilliant future
Has anyone tackled AC yet? If not I'll take the plunge when putting my motor in. Got close to 120 here in Phoenix so far this summer, currently my ka has crazy good AC. Curious if it would be easier to make a bracket and custom lines, or run the 1j compressor and custom lines
beems240sx is offline   Reply With Quote
Old 07-28-2017, 05:13 AM   #74
XxS13LifexX
XxS13LifexX's Avatar
XxS13LifexX is an unknown quantity at this point
bmaddock, thank you for this awesome guide! It gets tough having to look at 10 different ones of these for different cars to get the information you need so I really appreciate you putting it into one for us!
I was wondering if anyone has run into the ignition immobilizer issue yet and if there is an easy way to overcome this if I want to start out with my stock ecu? It's been a while since I did the original research, but my belief is that my motor is from a jzs171 crown and that it has an ignition immobilizer within the ecu because it is the newest ects-i model.
XxS13LifexX is offline   Reply With Quote
Old 08-03-2017, 02:19 PM   #75
koukizhang
koukizhang's Avatar
koukizhang is on a distinguished road
This thread is absolutely amazing. Your work does not go un noticed, fuckin grateful for people like you.
koukizhang is offline   Reply With Quote
Old 11-29-2017, 02:16 AM   #76
foofers
foofers is an unknown quantity at this point
Awesome thread.
From what I have searched, cheapest route would be to buy another stock ECU without the immobilizer.
foofers is offline   Reply With Quote
Old 02-04-2019, 08:56 AM   #77
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Edit: solved the problem.
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
