Old 02-18-2016, 06:07 PM   #61
Hoonigan19
Hoonigan19 is an unknown quantity at this point
sick pictures man! love see old ass blocks getting that fresh look. I'd use a sanding block and block the nissan logo to remove the paint so the words are shiney.
Hoonigan19 is offline   Reply With Quote
Old 02-18-2016, 09:41 PM   #62
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
Thanks man. You know, I've thought about doing that with the sand paper, however I've decided I want it to be all black.
2.5T_/<ouki is offline   Reply With Quote
Old 02-29-2016, 11:09 PM   #63
2.5T_/<ouki
Got the oil pan bunged. :mrgreen:
Old 03-05-2016, 08:17 PM   #64
2.5T_/<ouki
Got the JGS motor mounts as well as the RB25 XTD flywheel / ACT clutch kit on. Also installed lower temp thermostat.
Old 03-06-2016, 09:28 PM   #65
2.5T_/<ouki
Got a good amount of work done today on the car! Super excited the engine is finally in ! Got some help from one of my buddies today which REALLY helped me get a lot done.
OD of stock KA flywheel and OD of RB series XTD light weight flywheel.
Old 03-22-2016, 12:51 AM   #66
2.5T_/<ouki
Installed the JGS Rubber tranny mount. Gotta say, it's a pretty beefy setup and I can't wait to try it out on the road! I've now owned the car 5 months and haven't been able to give it a wash LOL! It's been sitting in the garage and I've been working on it dirty. Planning on taking it to a pressure wash and getting the underside. (Didn't bolt the mount to the tranny in the picture). I advise that you pick up (3) M10x1.5mm locking nuts; one to fasten rubber mount to the cross member and (2) one for each side of rubber mount to transmission.
-- Drilled 7/16 size hole in the (center ) of the 2 factory mounting holes. This is where the M10x1.5mm studded rubber mount fastens to the cross member.
Old 03-27-2016, 09:08 PM   #67
2.5T_/<ouki
Got a good chunk of work done on the S14. Not too much more updates on the engine however.
Walbro 255 lph fuel pump install
Replaced all fuel lines with new 6.9 bar fuel injected fuel hoses
cleaned out the s14 gas tank (was sitting for months previous owner)
dropped the rear sub frame with all arms/diff
installed s14 energy suspension rear subframe bushings
removed auto driveshaft
Old 03-28-2016, 10:52 PM   #68
2.5T_/<ouki
I got more goodies ! Got a text from my dad today that read "come over after work, I've got something for you". Show up, and what do you know?! He picked up a z32 N/A R200 VLSD for me! Removed the z32 axles and took the diff to the pressure was to clean it up nicely! Will be painted it to match the subframe/car. Also, will be changing the fluid to Redline GL-5 75W90. Picked up 5 bolt J30 axles for the diff.
Old 04-03-2016, 01:23 AM   #69
2.5T_/<ouki
Got the rear end all put back together and installed back onto the car today. Done with that now I can start back on the engine and finish putting the accessories on and firing her up !
Z32 R200 VLSD, J30 Axles, Z32 5 lug hubs w/ Ebrake setup, Z32 rear brakes, R33 ebrake cables, Moog ball joints, and Energy suspension poly pushings
Also installed New Moog rear ball joints on the car.
Old 04-24-2016, 01:19 AM   #70
2.5T_/<ouki
Old 05-03-2016, 11:48 PM   #71
2.5T_/<ouki
I've been pounding away at the car and have gotten SUUUUPER close to being able to fire her up! I'd say within the next couple of weeks I should be golden! Here are some updated pics.
So, getting my intake manifold ready for boost as well, however I will be running it like this N/A also. I will be breaking in the motor N/A. Aluminum welding was getting pretty expensive, so I opted for the tap/plug option. I used 1/8"-27 NPT tap & pipe plugs. Came out pretty good
Old 05-06-2016, 07:24 AM   #72
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
Following ! Can't wait to see it up and going
Vicious Beaner! is offline   Reply With Quote
Old 05-06-2016, 10:43 AM   #73
2.5T_/<ouki
Right on man ! Same here, been a long 7 months ha. Up's and downs. You know how life goes.
Follow the build/progress on Instagram as well if you'd like @TripasGarage
Old 05-14-2016, 09:01 PM   #74
2.5T_/<ouki
Had some time today to remove the s13 tranny that's giving me problems! Picked another one up last night in super excellent condition with all sensors, clutch fork, TOB, shifte, AND crossmember/mount. Decided since the tranny was already out I would drill the hole for the S14 crank angle sensor into the bell housing. Also flocked the dash.
Removed problematic s13 tranny
Made my "template" for drilling the CAS. 9/16" back from end of bellhousing (where it meets the block) & 1" from nearest bolt hole.
Need to get some washers/spacers to raise the sensor up.
