#872 | |
i understand that, i was just referring to the rim of the guages going over the imaginary box panel of which the other guages sit in and what their dimensions are contained in i DO NOT want mine stacked up like that either cause it would protrude out too far and would NOT look nice either. i simply wanted to show that i understand that the gauges being 5in and not 3 3/8 (like the others examples i have seen) that it would over lap over the panel into the bezel edges of the gauge cluster. the pictures show the example of what i am expecting with ONLY the 1 middle single gauges rim protruding outward. the already massed produced panel that uses 3 3/8 would need to be heavily modified to fit the 5in guages and would ultimately have gaps around the edges of the 5in gauges would not look good either and look like a hack job. it would need to be molded into the panel bring it back to where i started with needing fabrication. i could also buy that massed produced panel if it would be a good starting point for you and decrease the amount of time and effort to have a starting molding point ... in return maybe reducing the price... ![]() |
#873 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
#874 |
![]() Join Date: Jul 2006
![]() Feedback Score: 14 reviews
Would having such little material compromise the work?
Check out my build thread! http://zilvia.net/f/builds-builds-on...rhd-build.html |
#875 |
I hope not
#876 |
![]() Join Date: Dec 2007
![]() ![]() Feedback Score: 1 reviews
After you bond it and sand it how do you go back and "Texture" the surface like how it was before? This sounds like something I can definitely try.
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
#878 |
![]() Join Date: Oct 2012
Hey.
What do you recommend for someone who wants to go the the AN route for the hard lines for their brakes and fuel lines? I saw in your thread of your LS3 S13, you were using some kind of flare AN fittings, could you give more information on them or a link to them? Thanks -Kyle |
#880 |
No, I just haven't had time to do it yet... been far too busy to worry about it. I had planned to do it when I told you I was going to do it, then I had a ton of custom work show up that I am attending to.
#882 |
![]() Join Date: Jun 2011
hey broadfield
what shifter are you running with your tr6060 (iirc, thats what you have, right?)?
BustedS13: anything you can hide on your person is free. junkyard law. |
#884 |
Awesome. I couldnt find any real info on someone running this one in an s-chassis. mine came with the stock camero shifter assembly and i didnt know if i could use it or not. Probably just gonna get this one now to make it simple
just to be positive, its this one? Generation 5 Camaro Short Throw Shifter
#885 | |
#886 |
Hey Broadfield,
I'm not sure if this has been address before, my question is how do dash integrated tablets compare to a high end head units pros and cons Last edited by Ikera; 10-23-2013 at 11:37 AM.. |
#887 |
HAT setup
Looking to do a nice sound system in my s13 240sx. Looking at the Clarus line, 6.5 all around with either a 12 or a 15 inch sub. not sure which tweets to get. i listen to 90% rap 90% of the time. not looking to bust windows or be heard from miles away, but would like a nice decently hard hitting system. Can you quote me a full system price from you? i want it to be as complete as possible, i.e. front and rear componenets, tweeters, sub, amps, xover's, the whole nine down to wiring. thx for your time!
#888 | |
These are just some of the things. My customers always think it's going to be sooo awesome for me to put a tablet in their car. Then realize the little things like having to start the music back up, every time when they get in the car, kinda of sucks. Here is an iPad Mini I just installed into my salesman's truck... he will eventually swap it out for the black model so it looks a little better in the dash. It is quickly removable by pushing on the right side... it has spring loaded release that kicks the right side of the iPad up and then you can grab it and slide it out. Here is the folder where I have some build pics of how it all started and ended: Greg Loercher's Chevy Colorado iPad Mini Mount album | Broadfield | Fotki.com, photo and video sharing made easy. ![]() ![]() |
#889 | |
Thanks, Toby |
#890 | |
if these are the major cons, it doesn't even look that bad also some Androids have build in FM Receivers and there are $20 USB FM Receiver dongles available as well. Not sure about XM Radio tho yes it sucks not to have physical buttons, but you could buy a android keyboard which are small and cheap The things I wanted when I chose to go Android were - GPS NAVI - 7" High Resolution Screen - Capacitive 5 point touch screen - Multi-Core CPU with >2GB RAM - Multitasking Capabilities - ability to play any video format files - Customizable home screen (widgets) - Cost under $200 and here is some other cool stuff you can do - Pair with a OBD II scanner via BlueTooth and display all the cool data you can pull from it (ELM 327 OBD II BlueTooth scanners are $10 on eBay) - 3D Accelerometer Gauge Last edited by Ikera; 10-23-2013 at 11:37 AM.. |
#891 | |
#892 |
Hey Broadfield, so I'm looking into getting some gauges for my car (I actually just bought a center vent panel from you). I was wondering what you would recommend for a tight budget. For now I'm only looking for vac/boost and temp.
Obviously the most important thing is that they have to be accurate and reliable. But I have to admit, I'd really like to have LEDs and an opening and closing ceremony. What would you say is the best option for something like that for cheap? I'm a full time student, so I need to pinch as many pennies as I can! Thanks man! |
#893 |
I have a few questions for Mr Broadfield:
1. What is the best way to fix hairline cracks, cracks in general on a dashboard. 2. I want to repaint my entire dashboard since i dont like the light blue, bad idea? I know the SEM texture coat is pretty close to the stock grey look. 3. How are you securing the gauges after installing them in that s14 radio bezel? Do you have a shot from the back? Talking about this. Also would like to know what glue you are using to adhere the plastic pieces youcut out to the s14 radio bezel. Thank you, and if these questions have been answered in previous pages my apologies. ![]()
Nothing says racecar like a stock car with no interior. |
#895 | |
#897 | |
2. I would use the SEM Chip Guard then paint it with an SEM Color Coat if you do not like the satin black of the Chip Guard. 3. I use Norton Speed Grip to bond plastic and to typically glue the electronics in place if there isn't room for brackets. |
#898 |
AFC #1
![]() Join Date: Oct 2003
I know about all the mirrorlink stuff. It just seems that some still do it better than others.
#899 |
I'm not really a fan of any of them. If I'm going that route then I would just do an iPad molded into the dash. There are obvious pros and cons to a standard double din screen, an app radio screen and a tablet.
#900 | |
broadfield, toby |
