Old 02-10-2018, 02:03 PM   #871
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Originally Posted by gt3071r240 View Post
ok so considering changing turbo for the build...I currently have a Gt35r .82 AR, and considering going to a GTX3071r gen 2 in a .63 or .82 AR
Motor specs currently are:
CP 9:1 DET 87mm piston on stock sleeves
calculated compression is 9.285:1 with decking
1.8mm apexi headgasket
Eagle Rods
Mazworx head studs
P11 VVL head with Supertech 93lbs springs
P11 Cams
Mazworx Intake/Kit
ID1300 ATL FC with Bosch 088
all other supporting mods are there...
Not really looking to make more than 550Whp as it think the bottom end will become an issue.
Thoughts..
Just go with a smaller turbine housing on the GT35, going to a GT30 would be quite the downgrade and it's not the best sized turbo for 500HP+.
Also be sure to measure your piston to valve clearance during assembly since you're running the DET pistons, don't ever just trust someone else's "it works"
[email protected]
hanzbrady is offline   Reply With Quote
Old 02-10-2018, 02:28 PM   #872
PoorMans180SX
PoorMans180SX's Avatar
Dude has an old-tech 35R. The 3071 Gen 2 will be a massive upgrade in terms of response and power output.
Old 02-10-2018, 04:07 PM   #873
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Ahhhhh that 1.8 mm head gasket and yielding 9.2 CR?? How much are you actually decking?
Old 02-10-2018, 04:19 PM   #874
gt3071r240
gt3071r240 is an unknown quantity at this point
when i measured the block compared to a new VVL oil pump front cover i had to deck .011 off the pump .. the mazworx spec sheet stated they decked appx .003 from the head. total deck is .014-.015"
ugghhh maybe I should just pull down the fully ported 90mm hemispherical 1/2 head stud VVL mazwox head I have chilling on the shelf in the garage... then buy some kelford 184 st and a stage 4 mazworx SB and be done with it.
gt3071r240 is offline   Reply With Quote
Old 02-10-2018, 05:12 PM   #875
RalliartRsX
Trader Rating: (32)
So each oil pump is different so not a proper measure of decking.
I would go off Mazworx. 0.03" = roughly 0.8mm. Check the FSM for limit to decking.
I guess you are running the 1.8mm to make up the difference.
According to FSM
Resurfacing limit:
The limit for cylinder head resurfacing is determined by the
amount of cylinder block resurfacing.
Amount of cylinder head resurfacing is “A”.
Amount of cylinder block resurfacing is “B”.
The maximum limit is as follows:
A + B = 0.2 mm (0.008 in)
Or you could just use the bad boy Mazworx head?? Any reason why you are not running it??
Old 02-10-2018, 11:35 PM   #876
candyred_240sx
candyred_240sx is on a distinguished road
Finally finished up the tune today.
Gen 1 GTX3076r .78 twin scroll with N1 cams & E85
698whp / 557tq @ 30psi
candyred_240sx is offline   Reply With Quote
Old 02-11-2018, 12:20 AM   #877
RalliartRsX
Trader Rating: (32)
Candy, awesome numbers! Is that a 2,2?? Torque is very solid with a fat midrange
Old 02-11-2018, 01:50 AM   #878
peglio
peglio's Avatar
peglio is an unknown quantity at this point
The Sr20/Sr22vet thread
Those are some awesome figures man !
Quick question with regards to rev limits on the ve head
My tuner is saying 8 k rpm is a realistic limit , I was just wondering if this was correct ?
I have supertech valves , guides and seals , supertech springs and retainers ,custom cams with greddy pulleys ) naprec timing chain ,it’s been port matched and combustion chambers been CNC machined also
I’m running cdi ignition , 36-1 custom trigger disc on the ati super damper for primary trigger sensor
Bottom end is Darton sleeved and bored to 90mm with Carrillo pistons and Carrillo rods ,1/2” studs etc
Running a full race twin scroll twin gate set up with an efr7670 1.05ar
What do you guys think ? end of the day I want a reliable motor
Sent from Big Bear Kustoms Ltd
peglio is offline   Reply With Quote
Old 02-11-2018, 08:03 AM   #879
TEALSQUEAL
TEALSQUEAL's Avatar
TEALSQUEAL is making a name for him/her selfTEALSQUEAL is making a name for him/her self
If he knows your build list and he says 8k rev limit get a new tuner that knows what you have, because the current one doesn’t.
TEALSQUEAL is offline   Reply With Quote
Old 02-11-2018, 08:48 AM   #880
Malik
Malik's Avatar
Malik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant future
I was gonna say 8k sounds kind of low. 9k seems more appropriate for a built head... and the best ones push into 10k.
Malik is offline   Reply With Quote
Old 02-11-2018, 10:40 AM   #881
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Yeah was gonna say even 8500 is conservative for what you listed.
Old 02-11-2018, 12:13 PM   #882
candyred_240sx
Thanks man! Yep it's a 2.2 (87mm bore x 91mm stroker crank)
Couple videos, not sure how to link them to the forum properly.
https://youtu.be/-14GZlT5T10
https://youtu.be/_feimlYcqZ8
Old 02-11-2018, 12:15 PM   #883
peglio
peglio's Avatar
Cheers guys . I was hoping for around 8.5-9k and that’s honestly where I thought I would be at with the parts I have accumulated for this ! So good to know that’s where I should be aiming for .
I thought it was a bit conservative but maybe he was just playing it safe
Old 02-11-2018, 12:17 PM   #884
peglio
peglio's Avatar
Man that thing looks as sweet as it sounds . Colour is awesome dude [emoji1591]
Old 02-11-2018, 12:26 PM   #885
candyred_240sx
Thanks man! Looks better when the front lip is on lol
Old 02-11-2018, 01:42 PM   #886
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
I rev my SR22vet to 9500rpm without issue.
And this is my dyno chart from this summer.
SR22vet efr7670 and n1 cams at 22psi
https://photos.app.goo.gl/6l2x4SHKNJ3bMxAO2
RZRSHARP_240SX is offline   Reply With Quote
Old 02-11-2018, 02:22 PM   #887
peglio
peglio's Avatar
Nice man !
How do you find the 7670 ? Looks a good match for these engines? Which size do you have ?
Old 02-11-2018, 02:35 PM   #888
RZRSHARP_240SX
It’s the .92 internal gated twin scroll. I love the response and spools quickly it’s been great.
Old 02-11-2018, 02:37 PM   #889
peglio
peglio's Avatar
Yeah man I have seen some good figures for the internal gate set ups ! I have the 1.05 ar with twin external gates so will be interesting to see what it can do ! Probably won’t be quite as responsive but still think it should work pretty well .
Old 02-24-2018, 06:05 PM   #890
gt3071r240
What cam timing is common to run on P12 20V cams?
Old 03-25-2018, 06:52 AM   #891
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Anyone in here happen to have a set of P12 20V camshafts they can sell? In desparate need of some
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 03-25-2018, 06:57 AM   #892
EsChassisLove
Trader Rating: (26)
Old 03-27-2018, 08:45 AM   #893
funkymonk
funkymonk is an unknown quantity at this point
Peglio, I think the problem is keeping piston speeds in check. Trying to find some sources but I believe it is best to stay under 5000 feet per minute mean piston speed for reliability, all production cars and even F1 cars (ones I could find on google anyway) are not over 5000fpm by much. With your 91mm stroker that would be around 8.5k, that isn't to say it wont rev higher with out insta-exploding or making more power, but theoretically keeping it under 8.5k rpm is best for keeping it all together long term.
Whereabouts are you based? I have a P11 head and the same turbo, am looking at bottom end options, so very interested in hearing your results with that setup. Would love to have a chat about who did your sleeving etc. and ideally have a poke around the car at some point too if you were ok with that.
funkymonk is offline   Reply With Quote
Old 03-27-2018, 08:55 AM   #894
Yellow4g63
@Finkmonk got to motoiq and look up one of the project se-r's. They built a Na Ve with h22 rods and a custom je piston that you can ask for to keep the piston speeds down.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 03-27-2018, 09:05 AM   #895
Yellow4g63
http://www.motoiq.com/MagazineArticl...VE-Engine.aspx
91 Nx2000 VVL yo
Old 04-09-2018, 02:34 PM   #896
peglio
peglio's Avatar
Hey bud
Sorry I only just spotted this been mental with other builds at work not had time to do much
Yeah I would have to say that does make sense and I did ask him again he said a safe / reliable level would be around 8500 if I intend on using the car a lot ( which I do )
I’m near Warwick buddy ..that’s cool , there aren’t many doing these builds over here , I think the engine should be built this month / start of next month at the latest so going to crack on with the bodywork
Yeah man be cool to have a chat etc I own big Bear Kustoms if you have heard of us ? When the car is done will be having an open day at the unit with the car so more than welcome to pop down grab some food meet some other car guys and have a proper look over the car dude [emoji1598][emoji1598]
Old 04-14-2018, 10:14 PM   #897
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
P12 cas
Hey guys I have a question about the P12 CAS fitment on an S13. I got my motor from Mazworx and will be dropping it in the bay in a few days. I've read that I may have to bang in the firewall around where the CAS sits so it can clear and also depends on the engine mounts, It will be sitting on Nismo mounts. Before I spray the bay with primer and paint I would like to know if I indeed need to bang in the firewall for clearance.
Any help would be appreciated, Thank you.
kojiki88 is offline   Reply With Quote
Old 04-15-2018, 05:30 AM   #898
insa
insa is an unknown quantity at this point
The only good advise will be: Do a testfit and see how it sits. Including connected gearbox. Then add some space for when the engine/gearbox package moves...
insa is offline   Reply With Quote
Old 04-29-2018, 09:17 PM   #899
S13VE
S13VE is an unknown quantity at this point
This thread has been very valuable, thanks to all who have contributed. I signed up just to get involved.
I'm currently building a motor for a circuit/time attack style car and tossing up between VE head options.
Absolute max power would be 400rwkw (going for PB's/Wins/laps with mates etc) but for longevity I will happily run it at 300-350, know it can do it very easily and not have to worry about head reliability at revs.
I'm having a hard time choosing a head, both are available to me and I can afford either but I do like to get good bang for buck from mods and am not the type to go absolute best at all times for no good reason.
The P11 head comes out a bit cheaper even after coilpack conversion, CAS and solenoid swaps etc, but the things I'm having a hard time deciding are which cams are best suited to this goal and if the smaller valve stems are an issue in the p12 head as I hadn't planned on changing anything in either head beyond springs and a mild clean up port.
I will use a TS manifold and Ext gate whichi should help in response and top end flow respectively.
Thoughts?
S13VE is offline   Reply With Quote
Old 04-29-2018, 09:53 PM   #900
RalliartRsX
Trader Rating: (32)
Do P11 head
Keep the larger valve stems
The stock P12 cams work extremely well actually. However if you are starting with a P11, spring for a set of 184 ST (or 184T).
IN all honesty, if you are doing head work, it really doesnt matter which you start with. Valve seat if where the magic happens
