#9241 | ||
![]() Join Date: Feb 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
http://zilvia.net/f/archive-faqs/291...-calipers.html |
#9243 | |
any help? |
#9245 |
i have a question:
i have a base model 96' s14, with only power window and window lock switches. i recently purchased door wire harnesses for both drivers and passenger sides and i have a set of new window,door lock, and window lock switches. what i really want to know is there anything else im missing to do the conversion? ie; fuses, plugs? help me please. |
#9247 |
![]() Join Date: Nov 2005
Anybody run a 15/16 BMC off of a z31 on stock brakes?
I read on NRR that it helps the rear lock up even harder/easier.
http://www.nissanroadracing.com/ |
#9249 |
Besides ebay, I checked craigslist, could anyone tell me a good site or refer me to someone currently selling a upper and lower wire harnessing for a sr20det. Thank you very much for reading. my email is [email protected] feel free to email me a good site to try to find one or a link to a person selling one. again thank you very much
#9252 |
Hi,
would a 17X8 +38 wheels fit an S14? previously mounted on an EVO8, i know there are some offset issues, will i need spacers / longer wheel studs etc? i now it won't look the best but still... thanks, Al |
#9255 |
is a soch and doch chassis harness the same??? im doing a fuse box relocation on my vert with sr swap (wiring specailties wiring) and wondering if can use an old harness and still drive my car. anyone know for sure what is different?
Edit- its the engine room harness are they the same in a soch and doch Last edited by dpritchard4; 01-15-2012 at 02:57 PM.. Reason: Wrong info |
#9258 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
Yup!
#9260 |
![]() Join Date: Aug 2011
Long story short.
I've got 2 s14s in my back yard, one's wrecked one I'm parting out. Just got my s13. Will I have everything I need to put the s14 5 lug on the s13. I've looked this up and everyone beats around the bush. No direct answer. So yes or no, will I be able to put the s14 5 lug on the s13? What all will I need to take off and replace? |
#9261 | |
AFC #1
![]() Join Date: Oct 2003
On the rear, Unbolt the axle nut and the 4 bolts holding the Hub/bearing assembly onto the knuckle. Transfer the Hub/Bearing assembly.
#9262 | |
Thanks! I've got ss brake lines as well, will they fit on my s13? |
#9264 |
is a soch and doch engine room harness the same??? im trying to do a fuse box relocation on my vert with sr swap (wiring specailties wiring) and wondering if can use it. Im a rookie when it comes to electrical.
#9265 |
anyone know besides ebay,craigslist if anyone is selling sr20det full wire harness? i cant locate any for under 200 dollars, let me know if you come across any or if there is a easy way to make my own for cheap
#9270 |
I just pulled it tonight and it held up fine, I did detach the trans though so it was only motor.
The dude on the same page you posted this picture, posted a picture of a helical and these look identical... lol, did you scroll up before you posted this?
* S14SR22 * 9.0 c/r * GT3071R * |
