#9361 | |
![]() Join Date: Jun 2004
Shifting Paddles for a Sparco Steering Wheel |
#9362 |
Did some research and mine apperently isnt a Sparco spacer -__- it has 6 holes straight through it, no threads or anything. Thats why Im confused as how to install it. Unless I run super long bolth through my steering wheel into the hub...but then I couldnt use the 40 dollar TI Bolts i just bought for my wheel, and that would just be a stupid design :/
#9364 |
SMH I may just sell it then or completley redesign it. nevermind found a nardi adapter ring thats double threaded I can use it to make shit work hah
#9366 |
My s13 has a full blacktop s13 swap (motor, tranny, ecu, harness). Would I be able to run a redtop SR motor in the car without changing anything or are there differences in the harness and ecu between the redtop/blacktop?
#9367 |
![]() Join Date: Dec 2004
Trader Rating: (58)
You'd need a redtop ECU/harness to make it all work.
#9369 | |
![]() Join Date: Jan 2009
Also another question, in between shifts my redtop sr runs super rich. My UEGO will read around 14.7 but as soon as I start letting off it will start getting rich and when I let off completely it will drop down to the 12-11's briefly. When I get back on it the afr's will go back to 14's. I've heard this is normal and nissan did this to ensure smooth shifting. |
#9370 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#9371 |
![]() Join Date: Jun 2010
![]() Feedback Score: 11 reviews
are rear calipers the same for s chassis? like pass side and driver side? i had to use driver side for my pass side and it seems the ebrake works opposite. when its down the ebrake is engaged, when its up the wheel spins freely. only one way to connect the ebrake to the caliper correct?
#9372 |
![]() Join Date: Dec 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
Am I missing something? Or does no1 make after market Silvia s13 headlights like the kouki s14s from vertex?
They would sell more of those then kouki lights! I don't get it.. |
#9373 |
![]() Join Date: Jul 2008
Brake lights do NOT work. Bulbs and fuse are fine. Looked underneath to check if the rubber stopper was broken and I found some electrical tape wrapped around the wires that go to the connector (I assume it sends the signal to the lights) and found this............. WTF
![]() Is this wrong? As you can see there is a black wire soldered the the brown wire and another black wire from the connector cut and just chillin there... Courtesy of the previous owner. |
#9379 | |
street dancer. GLEAM |
#9382 |
![]() Join Date: May 2011
cool, its like 75 bucks or whatever for them then if you bring your old ones you get money back right? Cause I'd be able to get both for 40 bucks total after that. Which would be real nice.
#9385 |
Searched thread but didn't really find what I was looking for.
So my question is, is there a noticeable difference in ride quality between Stance GR+ and GR+ Pro coilovers. I will only be street driving and from what I've found on the interwebz people seem to think that the Helper Springs that you can get for the GR+ Pro's will help with track applications (which is usually why they go for the Pro's instead of the normal GR+) but won't make a difference on streets...but this was on a 350z. Anybody that has GR+ or GR+ Pro on an S13 have any input? |
#9390 |
![]() Join Date: Nov 2003
Anyone ever have trouble with their coilover perch nut coming loose, and the coilover loosening over time causing play in the front end and front end shake?
I have a set of older Tein HA coilovers, and my front driverside coilover keeps coming loose, and then causing play in the front end...any one deal with this also? Simple fix? (yes, I have tightened down the adjustment nuts using those perch wrenchs, multiple times, but it works its way loose)
-Kyle ![]() |
