01-30-2012, 09:50 AM | #9452 |
you can polish it but i'm not 100% sure that removes the heat discoloration
street dancer. GLEAM |
01-30-2012, 10:11 AM | #9454 |
still trying to figure out if i should get diamond racing wheels. I know they're cheap and ugly to some people, but i'm a poor college kid and I think steel would hold up better than an xxr. Is the weight going to be a problem at all if I'm running 15psi on an sr20? I'm by no means an experienced driver so I don't have any driving on super light vs super heavy wheels.
01-30-2012, 10:14 AM | #9456 |
do you know if they do make 17" ones? All I can see is people running 16's, and I have 6 17" tires in my garage which would be nice to use so I don't have to go out and buy new ones for 16s lol
01-30-2012, 10:16 AM | #9457 | |
01-30-2012, 10:22 AM | #9458 |
no, im currently running stock. I had FN's 17x7. What I meant was steel will probably hold up better on the track/street versus XXR. I hear a lot of people saying they wouldn't run XXR on the track at all due to them being a knockoff wheel
01-30-2012, 10:30 AM | #9459 |
I ran XXR when i first started tracking my coupe. They held up pretty nice. But if you prefer steel wheels like diamonds then by all means go ahead.
01-30-2012, 10:31 AM | #9460 |
I'm also looking for some guidance on offsets and backspacing, because I know nothing about it and it's really confusing me lol. If they will make them, I want 17x9 F 17x10 R, and have no idea what offset and back spacing to get to fit on a stock body s13. I would prefer not to have to roll/pull but wouldn't mind it if needed.
01-30-2012, 10:36 AM | #9461 | |
http://zilvia.net/f/tech-talk/166626...1-dummies.html http://zilvia.net/f/chat/129865-whee...s-no-post.html if your going to run 10"s in the rear, you will have to roll or pull a bit. I did when i was running my XXR 962. 17" for me is the best size when it comes to track because its not too big or too small. |
01-30-2012, 12:14 PM | #9462 |
The tires I plan to put on are 235/45/17 i believe... if i ran 17x9 +20 F and 17x10 +12 R would that fit with minor roll/pull and not look retarded? I swear there was a wheel fitment question thread, but I must be blind or making that up
01-30-2012, 01:40 PM | #9463 |
Trader Rating: (58)
Feedback Score: 58 reviews
What color are you looking for? Send me a PM, I can help you out. I need to cut some for some SE-R foglight covers so if you need stickers made let me know.
01-30-2012, 01:41 PM | #9464 |
Trader Rating: (58)
Yes but you'll need to compensate for them in a tune.
Truthfully I'd suggest STI or WRX injectors, as they are larger CC and more commonly available. (not to mention cheaper/newer)
01-30-2012, 03:01 PM | #9465 |
question about tubs..
i got a new shell.. was going to put 18x8.5 +25 wheels on the front after i assembled it.. but i'd rather not cut anything if i dont have to.. will i have any turning issues? i plan on going as low as possible.. should i make tubs? and i plan on getting a 10mm spacer down the road... what should i do? |
01-30-2012, 05:49 PM | #9468 |
When I replace my shifter bushing and pull out my whole shifter assembly thing, will I need to replace some gasket? Or can I just use RTV or something..? KA trans.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
01-30-2012, 05:53 PM | #9469 |
no gasket
no rtv You only need a gasket if you are taking the the plate off the tranny. The shifter assembly can be removed after taking out the snap rings. Just replace them when you put the shifter back in.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
01-30-2012, 06:04 PM | #9472 | |
The one that's bolted to the actual chassis? If so, that one's all good.
01-31-2012, 02:02 AM | #9476 | ||
instead of just having one, you double up on them. bought two new ones when i did my bushing/fluid, but only used one + old one. the rubber boot is the one held with zipties on the actual shifter, it keeps dirt and grime out of the trans. the one bolted to the body is pretty much just noise suppressant and insulation Quote:
17x10 +12 would need camber or a pull for the rear, should work up front, not too positive my 17x10 +22 have about 3mm of poke in the rear, and hit the coilover in front
01-31-2012, 02:42 AM | #9477 | |
Ok will do lol i also need a maf would u or anyone noe witch should i go with z32 or sr20........unless anyone else has another option i dont noe about......... |
01-31-2012, 10:00 AM | #9478 | |
Alright cool thanks man.
01-31-2012, 11:12 AM | #9479 |
I guess my question is do I NEED a spacer for 17x9 F and 17x10 R with a pull/roll to avoid not hitting the coilover? I don't have a specific offset I want, and I'm not looking for super flush or anything. I just want low-ish offset and not hitting the coils
01-31-2012, 11:37 AM | #9480 | |
