#9542 |
16-18ga is what i've come across
street dancer. GLEAM |
#9544 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
The simple answer would be.... Service the engine.
Scan the OBD2 port, and see what's wrong with it, and fix it, or just ignore it, as I've been doing since I got the car 2 years ago. It's not always something bad. Me for example is the EVAP control valve wiring is messed up.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#9545 |
Any suggestions on the best tranny fluid? And what you guys use. I've been using Redline MT90 for the past couple years, figured i'd see what others think before i swap trans and change fluid. Only other one i've really heard of was some Amsoil gl4 i think.
Edit: nvm, found an old trans oil discussion thread. Gunna try out the Amsoil Last edited by nutz240sx; 02-06-2012 at 05:19 PM.. |
#9548 |
![]() Join Date: Jan 2007
I have an s13 hatch, my front drivers side wheel sticks out further than the passenger side. Will front adjustable lower control arms fix this?
![]() "Home is where the armor is" |
#9550 |
is that box on the s13 fan shroud a resonator? it has a hose coming from the air tube, and definitely looks like a resonator, but wanna be 100% sure
@ s13 bumper support guy. not without modification @ fender problem guy some s13's had body fitment problems. one side fit different than the other. just pull the fender to accommodate, unless its a camber problem
#9553 |
![]() Join Date: Dec 2003
Emanage is a stand alone I thought.
why would you need to piggy back if you have a stand alone?
![]() **CoUpe LOve** Member #00 |
#9554 |
![]() Join Date: Jan 2009
emanage is not a standalone. in my case, i have the emange to make fuel corrections. what i would like to do it send my ecu to be tuned (jw or enthalpy) and use the emange to fine tune the ecu.
#9556 |
Hey guys I can't pull up any definitive info on this megan AFPR. Megan Racing Universal Silver Fuel Pressure Regulator with Gauge
It comes with universal fuel rail adapters but, my question is. Do I need to purchase a seperate fuel rail adapter or use what megan provides? This will be going on a KA24DE. |
#9557 | |
![]() Join Date: Nov 2009
![]() Feedback Score: 35 reviews
Nissan Factory JDM Chuki Front End Turn Signals - Nissan 240SX S13 CHUKI |
#9558 |
![]() Join Date: Oct 2010
Trader Rating: (24)
![]() Feedback Score: 24 reviews
I cant seem to remove the coolant temp sensor plug from the sensor on s14. I pushed the tab down but it just wont come off, i even broke the tab on accident from pushing down on it too hard. Anyone got any ideas?
edit: NEVERMIND i found the hold down ring, started fucking shit up for no reason ![]() Last edited by JasianBlazin; 02-08-2012 at 03:58 PM.. |
#9559 |
ok quick one before i buy parts.
i just pickedup a hicas rear swaybar for my coupe. i was wondering if the old swaybar brackets will work with the new swaybar and bushings? am i gonna have to get a hicas bracket? i doubt ill find one or maybe a universal ones. anything will help. thanks |
#9560 |
![]() Join Date: Feb 2011
Trader Rating: (25)
![]() Feedback Score: 25 reviews
i have both of the rear hubs
can someone tell me which i should use and which i should sell? one has the tab, one doesn't the tab is for the e brake i believe but I'm not sure which will work with mine i have a base model 1996 s14 ![]() |
#9564 | |
is it sand blasted? might have messed up the bearings if it is, or some wierd shit is going on because i've never seen one painted/blasted before heli-coil if its on the outside of the engine if its a block thread then you should take it to a shop so they can do it
#9566 |
![]() Join Date: Jun 2004
troubleshooting question:
my safc reads that my throttle position is always over 50%. my car also breaks up at around 4000 rpm and won't hold idle. is my TPS broken? i don't have a multimeter to use at the moment, so i can't do the test. |
#9570 |
heli coil it
if you do it yourself make sure its going in straight
