![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
I don't see any reason to not try and use the GTIR itbs and plenum since the engine should already be on a standalone engine management at that point anyways. And I can't imagine the runners between the GTIR and VE manifolds would be significantly off from eachother.
Go look at a GTir IM. There is a whole lot going on apart from just cut and shut
GTI-R Flange/lower runner with ITB [IMG] ![]() SR20VE Lower runners A few things 1) Port/lower runner spacing seems to be different 2) Runner shape 3) P11 VE is reverse taper. P12 is straight (shouldn't have an impact, just a FYI) 4) Vacuum ports on the lower manifold which need to be tied into the head flange for it all to work 5) Lowport vs High Port (if my memory serves me correctly) And that's just to name a few. I have seen a few folks try and just give up. It actually looks pretty close on first glance however. Easier (and probably cheaper) to just buy a Xcessive, a set of horns and weld her up. Not trying to disuade you, but its a little more intricate than just cut and shut (and there is proabably good reason not alot of folks have went that way) Also, tuning speed density or TPS with ITBs is a bitch. There are tuners capable of doing it as this is nowhere close to a foreign concept, but you have to find the right person. |
@therealsy80 for Na hp the gtir manifold just dosen't cut it. I forgot to mention Hayward made some nice ones too but $$$$.
95 240sx RB20 415whp 91 Nx2000 VVL yo |
![]() Join Date: Apr 2013
At what power level would you guys recommend upgrading to supertech oversized +1 in +2 exh valves on a p12 head? I just sent my p12 head to maxworx to get their stage 0 head work done and was thinking if i should slap on oversized valves. Im aiming for around 500-600hp at around 25-30psi of boost. Head is going to have supertech 93lb dual valve springs amd tomei cam gears, thats pretty much it as far as the head goes.
#7 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
IG/TikTok-ThatS14_Z06guy |
#8 | |
Spend your money on valve seat/valve work. THAT is where the gains are. The VE head could benefit from opening up the exhaust ports, but unequivocally, where the air actually enters and leaves the engine is where the magic lies. |
#9 |
What's choking you up top? Intake manifold? you seem to peak at 7200ish rpm or is the cam timing you are running?
**Fark I need glasses lol it's the turbo maxing out.
95 240sx RB20 415whp 91 Nx2000 VVL yo Last edited by Yellow4g63; 08-22-2018 at 11:26 PM.. Reason: i'm blind |
#11 |
hello after a few people on Instagram told me to post here im @jp_s14 on Instagram I run a S14/P11 ve+t making 532whp at 29psi on 93 octane 9100rpm redline, it is my drift/weekend streetcar with 8200 miles so far, fully built engine 87mm bore on stock sleeves, using an old gt3076r T3, sr16 non n1 cams, id1000cc, aem v2, custom intake manfold using stock runners, modified doc race exhaust manifold, fully built valve train shimless oversize valveswith ported exhaust, and bottom end.. using stock s13 trans Lol, I build engines for a living so if anyone needs a bulletproof vet setup let me know. I am from CT. before anyone says its "dynojet numbers" this dynojet has been calibrated within less of 6hp of what your "mustang" dynos read. ive been on and off both too many times
#13 |
#14 | |
![]() Join Date: Oct 2007
Maybe the problem is when the lobs are switching over
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#16 |
I ran into valve float issues with the supertech springs and bent all my exhaust valves so I went with a better spring setup, but the shimless setup was the best thing I could have done to stop spitting shims.
#18 |
The problem is simply drifting. The shock on the valve train by banging off the limiter @ 9000+ RPM (JP revs it out to that range) is utterly tremendous! No ammount of shim working would ever really fix that unless one wants to spend cubic amount of $$ to keep shims in place and bang off limiters @ 9000+ RPM
#19 |
![]() Join Date: Mar 2005
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
My question for those who have gone shimless is how long until you have to tear down the head to replace valves because the lash went out of spec? Do VVL heads have a worse likelihood of spitting shims than a solid lifter DET head? I never once spit a shim in the 13 years I've had my DET head (spun up to 9k with solid lifters, but mostly between 8-8.5k), but I'm in the process of switching over to a P11 head now.
96 S14: Grip Track Car 90 R32: Bucket List Car 92 S13: Just for Fun Car Instagram: @SS.Maxey |
#20 |
![]() Join Date: May 2006
Correct me if I'm wrong. The P12 Head uses the same Valve Springs as the H22 head?
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
#22 |
You're saying its the same part number for p12 as well.
#23 |
#24 |
gotcha Chris
#25 |
for you guys who are pushing 700hp range. are you guys using -8 AN or -10 AN fuel lines.
#26 |
-8AN fuel lines should suffice but folks just step up to -10AN for peace of mind.
Anyone here running Taarks Hall sensor and ECU Master ECU?? Or any other ecu with the taarks hall sensor?? Looking to pick someone's brain on setup. |
#27 | |
#28 |
Trader Rating: (26)
So turns out my P12 head is missing two shims. And I cant get new ones for another 6-8 weeks.
Whats this I hear we can run shimless heads? How can I do that because I really doint want to wait 6-8 more weeks. I already waited 8 weeks for custom CP pistons. Im done waiting lol
#29 | |
![]() Join Date: Apr 2012
Trader Rating: (63)
![]() Feedback Score: 63 reviews
Mazworx shimless valves 600$ plus a new valve job |
#30 | |
