#9722 |
![]() Join Date: Nov 2003
Is a clutch disk totally fucked once there is oil on it?
My clutch slipped a little bit today, and I am afraid it might be my rear main seal leaking and causing the disk to slip. It cant be leaking that bad, cause its not dripping on the ground while parked for a while. But I have a Stage-2 Exedy clutch on my S13 SR Blacktop. With 3000 miles on the rear main seal and clutch. Can I reuse this clutch after I replace the rear main seal if that is the issue?
-Kyle ![]() |
#9723 |
![]() Join Date: Dec 2010
if its on the friction material i wouldnt suggest it. its just like brakes, porous and would absorb the oil if left.
you can always put it back in though and see if it slips. just be prepared to pull it all back apart if it does |
#9726 | ||
-Kyle ![]() |
#9727 |
throw out bearing might be bad
when i first bought my car the clutch started slipping and when i replaced it the clutch was still good, bearing was shot
street dancer. GLEAM |
#9728 | |
![]() eehh too long. |
#9729 | |
AFC #1
![]() Join Date: Oct 2003
#9730 |
![]() Join Date: Feb 2010
has anyone seen a legit tomei type s fpr without the serial number on the back? i recently bought one from a guy locally, never used still in box, had intruction manual, 2x tomei decals, 4x fittings all teflon coated, the box looked perfectly legit but the fpr doesnt have a serial number and looks kinda dark
#9732 |
![]() Join Date: May 2011
What size flux core wire should I use in my hobart to weld 16gauge sheet metal? I'm running whatever came with it now (.035 I think) and I blow thru really easy.
#9734 | |
if its really bad then wetsand with 2000 grit and then polish, by hand slowly make sure its not clear coated bolts could have came loose for the headlight/horn bracket. otherwise that shit is welded in, if it came loose its rust
#9735 |
theyre chrome, not cleared. they were rechromed before i bought them, and i want them shinier. just looking for what people might recommend for cleaning them up and getting them that nice chrome "ricer" bling. i've definitely seen what can happen to a chrome wheel when the wrong cleaner is used, hence why im asking
#9736 |
![]() Join Date: Jun 2007
![]() Feedback Score: 13 reviews
SR20 IACV plug has 4 wires, one of which is black. I found out while cleaning up my harness that the black wire is just cut off. Is it supposed to be grounded?
My idle is usually a bit high (~1.4k rpm). Could this be the culprit? |
#9737 |
2 Questions:
1. My stock S13 blacktop is running really rich, drives fine just smells like its running super rich. How can I lean it back out not doing anything fancy and keeping it stock? 2. The engine makes an annoying ticking sound, a bit loud at startup then lowers once its warmed up. Engine runs fine though, what could it be? TIA |
#9738 |
![]() Join Date: Jan 2009
^^ Running rich can be cause from a number of different thing. Maf, cts, tps, o2 sensor, leaky injector etc. I would first start by making sure your fuel pressure is set correctly and start trouble shooting from there
and where does it sound like the ticking is coming from. the head or block? |
#9742 |
so i went to cut out my front frame rails to fix the rust, and pulled up the carpet and notice this https://fbcdn-sphotos-a.akamaihd.net...51828642_n.jpg
those holes let water in and i'm pretty sure the whole floor board is rusted. i could cut it all out and fix it with enough time, but is it worth it? I know most of you would buy a new shell but i don't have money for one right now, and no way to swap my motor over. |
#9744 |
i have a little bit of 16 gauge in the garage right now, is that what people would use for such jobs? i've cut out some of the frame rail already and it seems to be in like 2 or 3 layers up at the very front of it of what looks like 16 or 18 gauge
#9746 |
should i just cut it all out, weld the floor up and then do the frame rail?
also, what wire should i use? i have a hobart 140, no gas im using flux core. but the .035 that came with it blows thru. |
#9747 | |
#9749 | |
You need to bleed the hydrolic lifters.
