12-02-2012, 01:09 PM | #962 | |
i put a 3.69 r & p from a q45 into my original s14 pumpkin. i had to use a smaller spacer on the pinion between the pinion and the front bearing and i had to have a machine shop drill out my obx lsd to accept 13mm bolts but it works beautifully and matches up to the gearing of the r154 very well. with that being said i have never really been happy with the r154 so i recently purchased a v160 and am now back to the drawing board trying to figure out what to do about the rear end again. is the tech2 kit the only one still being made that fits with the v160? i might just end up modifying what i have in there now but i am also considering just picking up the kit from tech2 to make it easy. |
12-02-2012, 02:13 PM | #963 |
i believe the freed kit does a V160 mount as well.
In for pics of notched core supports. im looking to gain clearance this winter.
12-02-2012, 02:48 PM | #964 |
Trader Rating: (22)
Feedback Score: 22 reviews
Sorry, these pics probably don't make it too clear. I couldn't get any good pictures of the lower area I cut since my bumper is on, but the next time it's off I'll snap some (though it was pretty simple, just cut an equal amount on the bottom and redrill holes for the radiator pegs).
I trimmed the core support about 1.25 inches (and yeah it could look better, I did this in my driveway with a 9 dollar harbor freight angle grinder lol). I need to get some new foam (I resued the factory stuff, which isn't sticky anymore) Also, I obviously don't have a hood prop anymore (need to cut that little piece off that would normally hold it) I'm running circuit sports hood dampers with no issues. |
12-02-2012, 03:53 PM | #965 |
Trader Rating: (53)
Feedback Score: 53 reviews
is the 1JZ-GTE any shorter in length than the 2JZ? i would really rather not cut my upper support and move the radiator forward because im trying to keep my A/C and the way the condenser is mounted, there is no room for it to move forward.
has anyone moved their radiator forward and used a smaller condenser from another car? im trying to figure out all possible options here. |
12-02-2012, 08:36 PM | #966 |
Question guys, I've got the Xcessive swap kit, I'm 50/50 on going with solid motor mounts or just keeping the stock 2J ones. Same for the trans should I just stick with the stock mk3 supra mount? I've ridden in a talon with solid mounts and it felt like a lazy boy recliner but I've never been in a rad car with solid mounts.
BlackHand |
12-02-2012, 10:30 PM | #967 | |
12-03-2012, 11:54 AM | #969 |
What fans do you have on your car? I'm not sure if i'm going to grind the water pump bolts and the aligning nub down so it fits better or if i'm going to mod the Core support.
The Flexalite 410/420 Series fans and Koyo radiator don't like to fit.
12-03-2012, 12:29 PM | #970 |
Trader Rating: (22)
Yeah it was a tight fit even with notching the core support. I'm running a set of dual FAL's that have a built in shroud, though I'm unsure of the model number (doesn't have a thermostatic control box though, so I think they're just 220's)
12-03-2012, 03:05 PM | #972 | |
It FITS, but it's tight, REALLY tight. I could go back and do what i did with the old setup this year, but i'm looking at making a few little changes. If you take the factory foam off the top of core support, you will see the core support has a little "lip" I just bent that down out of the way a little bit, and put new foam up and then i tried to fit the Koyo/Flex a lite combo. and it wouldn't budge. I had to cut about 1/4" or 3/8" off the studs, and i had to grind down the nose piece of the water pump then they fit, but there is pretty much NO clearance. Here are some pics i took from earlier this year, I guess i'm too concerned on the appearance side of things to just hack up the upper core support. But i might notch the outer corners of the core support and use a thinner foam and see if that helps at all. Maybe that will help.
12-03-2012, 03:11 PM | #973 |
Hey guys who have done R154 to s13 diff, and then converted to Q45 does the q45 sit the same distance away or is there some modification required for the drive shaft to work?
12-03-2012, 03:52 PM | #975 |
Yeah, I'm not a fan at all of how close it was. Just not sure the best idea... Still playing with my options.
12-03-2012, 04:17 PM | #976 |
I have 1j in s13. Running Mishimoto radiator with two of the lowest profile fans that Spal makes. I maybe have a quarter inch between the tip of the water pump and the back of the fan.
12-03-2012, 04:32 PM | #977 |
Do yall think fal pushers wouldn't be sufficient enough? I'm in the process of removing the Ac compressor to have more clearance. I was running my girls fal's as pushers and temps were gettin to 200
Follow me on Ig- Andydennington |
12-03-2012, 05:26 PM | #978 |
Trader Rating: (53)
im not a big fan of pusher fans, i really just prefer pullers. i already know what my only real option is, and it's gonna cause me to lose my A/C condenser. FFFFFFUUUUUU
12-03-2012, 07:45 PM | #981 |
Trader Rating: (22)
I don't think 1j's are any more/less long, 2j is just taller (since it has a longer stroke) as far as I know (or at least the deck height is taller on a 2j). But people with s14's don't seem to have the clearance issue us people with 13's do lol. I'll post up a picture of how close the fan clearance was to that water pump nose piece. But I don't have cooling issues so I can't complain, though I would like to add an oil cooler and a hood vent eventually
12-04-2012, 05:50 AM | #986 | |
BlackHand |
12-04-2012, 08:22 AM | #987 |
Instructions for in car installation. 1. The mounts are designed to fit either side of the engine and the slot for the X-member mount allows for adjustment when fitting in the car. 2. Remove the four bolts (Per bracket) that hold the stock brackets to the side of the engine block and remove the stock brackets. (If applicable) 3. The X-member mounts, (rubber mounts) will need the index pin on the top ground off. The new motor brackets do not use the index pin and will not sit properly if the pin is still in place. If your using Xcessive urethane motor mounts, you do not need to worry about index pin issues. 4. The stock rubber mounts also have metal plates on top that will need to be positioned properly. The driver side mount will have the top lip to the rear and passenger side mount will have the top lip to the front. This is typical for most applications. Be sure to check that it applies correctly to your fitment. 5. Bolt the new brackets to the block using the new supplied bolts. A mild thread locker can be used if vibration or loosening is a concern. 6. When placing the engine in the car, it’s usually easier to leave the motor mounts in the car loose so they can be tipped allowing the mounting stud to align with your new motor brackets and allowing them to center up easier on the cross member when the engine is set. You may also hang the motor mounts from the new brackets and lower it all down to the cross member all at once. 7. With the engine sitting down, you can check that the motor is sitting straight, once you have the motor straight you can tighten the rubber mount base plates to cross member. 8. With clearance checked, you can now put the nuts back on the top of the motor mounts and tighten it down. Instructions say to use the mounts off the crossmember aka stock mounts. 2jz mounts are different, I don't think they would work but you never know? Anyway I see no advantage to using the 2jz rubber mount over a sr/ka one. Get a nismo one and be happy. |
12-04-2012, 05:01 PM | #990 |
Hey flick, If you take the rubber seal off the fans it will help move them forward, worked on mine with just a bent lip on the core support...
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
