Old 08-21-2018, 09:41 PM   #961
livelovesole
livelovesole is an unknown quantity at this point
At what power level would you guys recommend upgrading to supertech oversized +1 in +2 exh valves on a p12 head? I just sent my p12 head to maxworx to get their stage 0 head work done and was thinking if i should slap on oversized valves. Im aiming for around 500-600hp at around 25-30psi of boost. Head is going to have supertech 93lb dual valve springs amd tomei cam gears, thats pretty much it as far as the head goes.
livelovesole is offline   Reply With Quote
Old 08-22-2018, 09:14 PM   #962
candyred_240sx
candyred_240sx is on a distinguished road
Latest tune:
sr22vet, Kelford 184-T cams, GTX35 1.06 A/R @ 35 psi, 70% ethanol.
725whp / 526 tq
candyred_240sx is offline   Reply With Quote
Old 08-22-2018, 11:24 PM   #963
Yellow4g63
What's choking you up top? Intake manifold? you seem to peak at 7200ish rpm or is the cam timing you are running?
**Fark I need glasses lol it's the turbo maxing out.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 08-23-2018, 07:25 AM   #964
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Don't waste the money if you aren't going to max power. You can get your power level easy with oem sized valves.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 08-23-2018, 08:21 AM   #965
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
This.
Spend your money on valve seat/valve work. THAT is where the gains are.
The VE head could benefit from opening up the exhaust ports, but unequivocally, where the air actually enters and leaves the engine is where the magic lies.
Old 08-23-2018, 11:23 AM   #966
livelovesole
Thanks alot for the help guys.
Old 08-23-2018, 07:50 PM   #967
PoorMans180SX
PoorMans180SX's Avatar
Originally Posted by CrunkGoat View Post
Well my build is slowly getting there and basically just have a few bolt ons left (intake, and a few swap parts.) My major decision now is what ECU to run. The engine is going in an old Datsun 510 and I'm doing a high compression NA build so don't think I need anything too crazy. Was looking at an AEM EMS 4 what's everyone think of that?
Fuck EMS4's. They have trigger and EMF noise issues and are generally poorly constructed. Don't do it. Get an Infiniti at minimum. Better yet an MS3pro and even better still a Link G4+.
Old 09-10-2018, 02:54 PM   #968
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
Anyone know of any off the shelf adapter plates for ign-a1 coils on a p12 head with p12 vc? Or what are people using (I doubt they bolt right on)
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 09-12-2018, 10:23 PM   #969
240SXK
240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light240SXK is a glorious beacon of light
hello after a few people on Instagram told me to post here im @jp_s14 on Instagram I run a S14/P11 ve+t making 532whp at 29psi on 93 octane 9100rpm redline, it is my drift/weekend streetcar with 8200 miles so far, fully built engine 87mm bore on stock sleeves, using an old gt3076r T3, sr16 non n1 cams, id1000cc, aem v2, custom intake manfold using stock runners, modified doc race exhaust manifold, fully built valve train shimless oversize valveswith ported exhaust, and bottom end.. using stock s13 trans Lol, I build engines for a living so if anyone needs a bulletproof vet setup let me know. I am from CT. before anyone says its "dynojet numbers" this dynojet has been calibrated within less of 6hp of what your "mustang" dynos read. ive been on and off both too many times
240SXK is offline   Reply With Quote
Old 09-12-2018, 10:43 PM   #970
RalliartRsX
Trader Rating: (32)
JP did you ever figure out your shim issue??
I was the one who posted the FSM shim diagram btw
Old 09-12-2018, 10:52 PM   #971
240SXK
yeah, by going shimless Lol, thank you!
Old 09-12-2018, 10:56 PM   #972
RalliartRsX
Trader Rating: (32)
I thought the first shimless setup didn't fare too well??
Old 09-12-2018, 11:02 PM   #973
240SXK
I ran into valve float issues with the supertech springs and bent all my exhaust valves so I went with a better spring setup, but the shimless setup was the best thing I could have done to stop spitting shims.
Old 09-12-2018, 11:10 PM   #974
RalliartRsX
Trader Rating: (32)
Aha! So that's what it was
It's a god send those shimless lol
You should put a full scale dyno sheet as the bottom the RPM plot is cutoff
Old 09-17-2018, 07:25 PM   #975
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Im running the Taarks adaptor kit to run r35 coilpacks , if that could help
I never saw an plate for the style of coils you plan on running ! Custom it is or maybe look into an other coil set-up
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 09-17-2018, 07:30 PM   #976
rbs14kouki
rbs14kouki's Avatar
I know my tuner never had any issue with shims but he's running on the big lob only (he runs in the high 7sec on the 1/4 btw)... i did the same thing on my engin . Its a vvl killer but for a broke mofo like me gahaha
Maybe the problem is when the lobs are switching over
AV FABRICATION
Old 09-17-2018, 07:39 PM   #977
RalliartRsX
Trader Rating: (32)
The problem is simply drifting. The shock on the valve train by banging off the limiter @ 9000+ RPM (JP revs it out to that range) is utterly tremendous! No ammount of shim working would ever really fix that unless one wants to spend cubic amount of $$ to keep shims in place and bang off limiters @ 9000+ RPM
Old 09-18-2018, 09:09 AM   #978
2_Liter_Turbo
2_Liter_Turbo's Avatar
Trader Rating: (28)
2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough2_Liter_Turbo is a jewel in the rough
Feedback Score: 28 reviews
My question for those who have gone shimless is how long until you have to tear down the head to replace valves because the lash went out of spec? Do VVL heads have a worse likelihood of spitting shims than a solid lifter DET head? I never once spit a shim in the 13 years I've had my DET head (spun up to 9k with solid lifters, but mostly between 8-8.5k), but I'm in the process of switching over to a P11 head now.
96 S14: Grip Track Car
90 R32: Bucket List Car
92 S13: Just for Fun Car
Instagram: @SS.Maxey
2_Liter_Turbo is offline   Reply With Quote
Old 10-02-2018, 06:51 AM   #979
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
Correct me if I'm wrong. The P12 Head uses the same Valve Springs as the H22 head?
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-02-2018, 07:33 AM   #980
Yellow4g63
P11 head, the BC springs are the same part #.
91 Nx2000 VVL yo
Old 10-02-2018, 10:01 AM   #981
s13silvia123
You're saying its the same part number for p12 as well.
Old 10-02-2018, 11:38 AM   #982
RalliartRsX
Trader Rating: (32)
What Yellow is saying is the P11 head shares the same springs/part number with the H22.
The P12 is a different animal entirely.
Old 10-02-2018, 11:53 AM   #983
s13silvia123
gotcha Chris
Old 10-15-2018, 08:46 AM   #984
s13silvia123
for you guys who are pushing 700hp range. are you guys using -8 AN or -10 AN fuel lines.
Old 10-15-2018, 08:48 AM   #985
RalliartRsX
Trader Rating: (32)
-8AN fuel lines should suffice but folks just step up to -10AN for peace of mind.
Anyone here running Taarks Hall sensor and ECU Master ECU?? Or any other ecu with the taarks hall sensor??
Looking to pick someone's brain on setup.
Old 10-27-2018, 12:13 AM   #986
EsChassisLove
Trader Rating: (26)
So turns out my P12 head is missing two shims. And I cant get new ones for another 6-8 weeks.
Whats this I hear we can run shimless heads? How can I do that because I really doint want to wait 6-8 more weeks. I already waited 8 weeks for custom CP pistons. Im done waiting lol
Old 10-27-2018, 12:48 AM   #987
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
Rb26kouki is an unknown quantity at this point
Feedback Score: 63 reviews
Mazworx shimless valves 600$ plus a new valve job
Rb26kouki is offline   Reply With Quote
Old 10-27-2018, 01:15 AM   #988
Yellow4g63
are they the same as the P11 head? if so just go down the Harley dealer and get some vrod shims.
91 Nx2000 VVL yo
Old 10-27-2018, 04:21 AM   #989
s13silvia123
run the head shimless. this is what i'm doing so the head won't spit them out. but you'll have to run a whole new set up of valves and machine them to clearance
Old 10-27-2018, 05:57 AM   #990
RalliartRsX
Trader Rating: (32)
Unless you want to drop another 1000-1200 to properly go shimless buy a set of v rod or 10mm shims.
I have several different sizes here. If you need a few let me know. I'll send them to you
