#9961 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#9962 |
![]() Join Date: Jan 2009
headlights go up but won't go down. just happened out of nowhere. i've done plenty of research and changed a couple parts. so far i've replaced switch on steering column, relays under hood, and the headlight button. no luck. anyone care to share some insight?
#9965 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Loos like the oil.pressure sensor plug
#9966 |
I have a question about hub centric rings
I'm trying to fit xxr 527 17x9.75 that are four lug universal and they didn't come with hub centric rings at all. ive already broke 2 wheel studs and im tired of it. I'm trying to fit them on an s14 and need to know what size I need that will fit on my stock hub. any info will help thank you!
#9967 |
![]() Join Date: Feb 2011
Trader Rating: (25)
![]() Feedback Score: 25 reviews
^not sure what your asking but the hub bore on nissans are 66. something and most after market wheels are 70 something so i would suggest buy some hub centric rings
#9968 |
Nissan stock is 66.1mm. My RPF1's are 73mm hub bore, so I just got 66.1->73mm rings.
I recommend metal ones, not the shitty plastic ones that end up melting to the wheels/hub from the brake heat. Touge Factory sells them for around 20 bucks I believe.
#9969 |
![]() Join Date: Aug 2011
![]() Pulled my header off to see where my oil was leaking from. It is dripping into the header and out of the gasket an burning. The compression in that cylinder is 190 so it isn't the rings. My step dad said it might be the valve guides? Any ideas of anything else? It is also misfiring in that cylinder. |
#9970 |
![]() Join Date: Sep 2010
Whats the size of the vacuum line that that goes to the boost source on on the wastegate actuator? Is it 1/4 line or 3/8s? T28 turbo stock waste being replaced with hks one
#9972 |
I'd rather not have to deal with it, and for 20 bucks it's whatever... plus, they're GOLD.
Anyway, I'm going to be making a bash bar for the front and rear of my car. I have a few questions. 1. Would it be better to mandrel bend the ends of the front bar, just have a straight bar, or could I just weld on extensions at an angle? 2. Is it safe to make a rear jack point from the bash bar? Right in the center, so I won't have to drive onto wood, and I can easily swap wheels at the track. 3. What size tubing should I use for F/R? They're just gonna be single bars, nothing crazy. Gonna have someone I know do some of it, and also teach me how to weld, so I'll be doing a portion of it as well. So I just want something basic.
#9975 |
![]() Feedback Score: 8 reviews
quick question, i have an s13 sr20 with a rom tuned ecu tuned for 550 injectors, z32 maf, and a t28 the problem is my t28 is toast and i have a spare t25 in good condition my question is what will be the outcome if i use that t25?
#9976 |
Anyone knows how the mounting points of the OEM cargo net for S14?
This is the cargo net I'm talking about. ![]() One came with my car but I thought it was a kragen net. I just discovered it's a OEM but I don't see were it mounts. Google only provides me pictures for newer models like the Z's and the G's. |
#9977 | |
Trader Rating: (25)
Mike Burns 'Stripped'tease! on Vimeo ![]() |
#9979 |
Does anyone make a universal intercooler similar to this in dimensions? Preferably with the outlets parallel to the core instead of pointed forward.
Also, would an intercooler of this size be a sufficient replacement for the stock CA18 or SR20 side-mount, if the turbo and boost are kept stock? I plan to mount it in front of the radiator, similar to the Max HMIC setup. |
#9980 | ||
Trader Rating: (58)
Check ebay, but it's hard to find super short cores. Why on earth are you even wasting the time if the SMIC works?
#9981 |
![]() Join Date: Nov 2009
For my s13 silvia conversion, should i pick up a used gtr grill or buy a new one on ebay? I only ask because I have seen soooooo many that warp and loose their shape. anyone gone the ebay route for this reason?
*disclaimer* I wont necessarily buy it on ebay if i can get a replica somewhere that makes them. Thanks! ![]() |
#9983 |
I have been looking at white LM GT4's lately and I have noticed some are all white and some have the "forged" raised lettering in red. Wondering if one was was older an older version or what are the difference.
#9984 |
I would not recommend it. As a minimum, there should be three threads holding the nut on the stud. You most likely do not have this condition met. I would recommend ordering longer studs. Best of luck!
#9985 | |
![]() The only difference with LMGT4 wheels is the USDM vs JDM versions. The USDM versions use different style center caps that are not compatible with the JDM variant and vice versa.
#9986 | |
jack point is safe, although it does have a little play it is pretty much like jacking it from the front tubing IDK, ask Vinny at Destruction Warehouse honestly, let someone who knows how to weld do it all and learn on something less important. why? cause if your welds break in an accident well there goes that, and now you have a pipe that can do what ever it wants getting pushed towards you
street dancer. GLEAM |
#9987 |
![]() Join Date: Jun 2011
![]() Feedback Score: 11 reviews
![]() i was driving on the highway and this happened. no idea what went wrong. all the bolts broke off. the car can still roll. anyone know how i can fix this? do i need a new axle? the boots ripped so that needs replacing and i'd have to refill it with grease but what else, is their anything that should be inbetween the axle and diff? |
#9988 | |
#9989 | |
if youre replacing the boot then why not buy the oreilly's replacement ones? boots are more suited for low cars
