#991 |
Just wondering what people think the limit is on stock axles?
I am at 460rwhp on pump gas, Z32 trans, one piece driveline, KAAZ 1.5 LSD in an S14 diff, all SPL suspension, 275/40/17 Nitto NT05s. Would I be at a big risk of breaking an axle if I hit the drag strip? That's probably the weakest link in the drivetrain I think, other than the softer 2nd and 4th gear synchros in my early Z32 trans.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
#993 |
I've ran at the strip on DR's pulling 1.9's(first time on DR's) and didn't have an issue. 2step and unpreloaded drivetrain could wreak havoc though.
#995 |
Wheel hop is the killer of all things stock...
#997 | |
![]() Join Date: Oct 2008
![]() I'm at 501whp now and will /not/ launch the car because I don't think I'll be getting home without a tow
My 96 S14 | 501whp SOLD |
#1004 |
![]() Join Date: Oct 2012
That pretty much sums it up, I was wondering if it was a Jerico or libertys, did u order it, or was it second hand, if you don't mind me asking what did it set you back$$
#1005 |
![]() Join Date: Nov 2010
I got it from a friend..it was previously in an 8 sec 510 here in LA. Tranny had 12 passes in it. It has a browell sfi approved bellhousing a mark Williams yoke a long shifter and mcleod racing slave cylinder.. got the whole setup with custom clutch for 4.5k
#1008 |
Yes sir . Ur very right. Thats how it works.. this is my second time driving the car with new tranny the moment the car was going sideways I wanted to play with gas and get back on it as I used to but this tranny won't let me..
#1009 |
Its the way it works.. am not sure if by holding the shifter I can prevent from going into neutral I havent tried. . Am sure with slicks it will stick to the ground.. I was driving around on 275/50r15 MT. Et streets radials.
#1014 |
hou can do it with the aem to a point, add a front wheel abs sensor and use that as your speed , that way the boost dont ramp up with tire spin it help a lot
in a more expensive system you can run front and rear wheel speed sensors and have the ecu or traction box pull boost and timing at certin slip rates |
#1015 | |
#1017 |
out of curiosity, what does anyone use for driving on the street, other than drag radials? Being in Washington state, daily driving, a drag radial isn't going to do well in the rain. However, I am sick of driving with no traction when boost hits. It seems that 315/35/17 Nitto NT05 is going to be the best of all worlds. I wouldn't mind going to 335/30/18 but they are 3x the cost of a 315/35/17 setup if you include the costs for both wheels and tires.
#1018 |
if I wasn't using radials I'd be using either falken 615s or bfg kdws
#1019 |
I had falken 615s and they wouldn't hook for nothing. I still have them on the front and they are nearly as bad as the crappy Sumitomos. KDWs are twice the cost of Nittos and not twice the grip. I am not poor, but I don't want to throw away money on tires if there isn't an upside to the spend.
#1020 |
![]() Join Date: Jun 2007
^^At your power level, there is really no 'end all be all' tire for you dude... Either route you go, you will be sacrificing either traction in the dry or traction in the wet. I'm assuming your wheels are 10J? If so, maybe go down to a 265 or 275/40/17 all-weather tire. I daily drove on 275/40/17 drag radials in Okinawa & hated it in the rain w/only 350-ish at the wheels at the time. I still run them on my 240 with much more power at the wheels; but I have the luxury of not having to DD it.
If you do happen to find a good tire that hooks in the dry and holds well in the rain in boost, please let us know. GL!
