Old 02-05-2013, 08:29 AM   #991
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Originally Posted by baube View Post
my bad! yes I was talkin about the tacho
for the speedo just put your KA sensor in the RB tranny
Wrong! The ka and rb speed sensors are different. From what I've read a z32 na speed sensor should get your speedo within a couple miles and is a direct fit, from what I've read though. I haven't tried it yet since I'm broke but it will be my next purchase.
As for the tach, without a 10k resistor it won't be accurate. I have mine turned all the way to the left and it's off 400 rpm until I get to like 6 then it's off 1-1500 rpm.
smoked240 is offline   Reply With Quote
Old 02-05-2013, 08:47 AM   #992
baube
baube is an unknown quantity at this point
speedo works like before the swap in my s13... same for 2 of my friends
car was ka24de w/5spd
baube is offline   Reply With Quote
Old 02-05-2013, 09:19 AM   #993
smoked240
Okay? But you still didn't take the ka speed sensor and install it into the Rb25 trans. The Ka one is smaller and shorter. I could see if you removed the gear off the ka speed sensor and got it on the rb speed sensor, no idea on that cause I never tried it. Or you have an rb20 trans.
Old 02-05-2013, 10:48 AM   #994
xnissan240sx
xnissan240sx is an unknown quantity at this point
Originally Posted by GSXRJJordan View Post
What mount kit are you using? My Ruckus/Zerolift mounts didn't do that.
I have the top hat mounts.
xnissan240sx is offline   Reply With Quote
Old 02-05-2013, 05:04 PM   #995
2sav
2sav's Avatar
2sav is an unknown quantity at this point
Is there clearance issues with a nismo powerbrace on a s13 rb25 using syko mount kit?
2sav is offline   Reply With Quote
Old 02-07-2013, 02:23 PM   #996
projects
projects is an unknown quantity at this point
with the sway bar, if you can find one in the US ( you might have to by one in or go aftermarket) are A31 Cefiro or C33 Laurel Front sway bar. They run the McPherson strut like the Silvia but allow for the RB motor.
projects is offline   Reply With Quote
Old 02-07-2013, 02:33 PM   #997
slideslidegnarslide
Trader Rating: (29)
slideslidegnarslide is an unknown quantity at this point
Feedback Score: 29 reviews
Any body have an r33 trans crossmember and the dust plate between the engine and trans for sale?
I would actually love to find some one local to make sure it fits but I'm running r33 subframe and stock mounts..( well sorta still 2 post style but almost a solid mount at the bottom) I heard I either need r33 trans crossmember or auto Ka? Is this true and does any one have them
slideslidegnarslide is offline   Reply With Quote
Old 02-19-2013, 04:44 PM   #998
fsuarez
fsuarez's Avatar
fsuarez is an unknown quantity at this point
Send a message via AIM to fsuarez
**need swap help**
im going to have the swap done at a shop (R1 Motors) thing is i want to take everything all at once and not have Ray tell me im missing parts for the swap
i already have a rb20det swap inside a s13 with a rb25 turbo, already cleared the elbow and steering column problem
i want to swap out the rb20 motor for rb25 motor
what parts from the rb20 can i use on the rb25
fsuarez is offline   Reply With Quote
Old 02-26-2013, 06:57 AM   #999
RB240Coupe
RB240Coupe's Avatar
RB240Coupe is an unknown quantity at this point
double posted
RB240Coupe is offline   Reply With Quote
Old 02-26-2013, 07:02 AM   #1000
RB240Coupe
RB240Coupe's Avatar
RB
Alright RB Gurus need some help didnt want to start a thread for it but here is my problem.
Im currently in the process of building and inspecting my rb20. everything its being tore down to check for wear and see if everything is in spec. i have the service manual and have been through it searched forums and used that great trash can of the world the internet. What i need to know is what the factory Valve specs and measurements are height, length etc ? none of the info is listed in the FSM i have.
thanks any help would be appreciated
Old 02-28-2013, 03:36 PM   #1001
arlok
arlok's Avatar
arlok is an unknown quantity at this point
Hey guy, looks like my bov is stuck after 2 months without turning the car on, anyone has any idea of what's causing this?
Thanks
arlok is offline   Reply With Quote
Old 03-03-2013, 05:47 AM   #1002
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by EnemyS15 View Post
A little back story.. I have a series 2 rb25, using a greddy style intake manifold. I wanted to switch to top feed and found a set of Deatchwerks rb20/26 top feed injectors (Bosch ev14). The issue I had was the injectors were slimmer than the injector port itself. After doing some homework, I tried many other Nissan top feed injector insulators and nothing came close to a snug fit.
Uploaded with ImageShack.us
So i kept on digging and trying different options. Well I found a solution!! I found a company here in Florida (Fuelinjectorclinic.com) that sells solid spacers, made for a Supra top feed conversion. If this is old new, then I am late to the party and my bad for the thread. If not! Then I hope this helps others that run into this problem!
Pic here is the injector port, without the oem insulator
The spacer they sell fits right into the port and allows the injector to sit in right where it should sit, had it been a factory set up.
Final product! Now you can utilize other Top feed injectors with your rb25 greddy plenum! Very simple and fast Solution (besides the obvious "go buy side feed" answer) Hope this helps the Rb community out!
Posted for you Neo Guys...
CLICK HERE!!!
Old 04-02-2013, 07:56 AM   #1003
Ros7.exe
Ros7.exe's Avatar
Ros7.exe is an unknown quantity at this point
My RB20 ECU blew out was wondering if I could use any other ecu besides the Blue 22 one that I had. let me know please.
Ros7.exe is offline   Reply With Quote
Old 05-07-2013, 08:57 AM   #1004
smoked240
Alright you RB guru's what timing should I be at for e85 on my rb25? My tuner set my mechanical timing to 20..now I know with the stock ecu it should be at 15..since I'm running a standalone and e85. Does 20 sound about right?
Old 05-07-2013, 01:48 PM   #1005
GSXRJJordan
GSXRJJordan's Avatar
Doesn't make sense to pull timing with E85, I'd set mechanical at 15 and see what kind of timing you can add at your boost level (or throw a ton of boost at it and see how much timing you can keep).
Old 05-16-2013, 12:07 PM   #1006
palummi5
palummi5 is an unknown quantity at this point
is it just me... or does none of the OP come up....
palummi5 is offline   Reply With Quote
Old 05-17-2013, 05:35 PM   #1007
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
New to the rb's. Recently bought an rb26 and it came with a t04z t4 1.00 twin scroll. Looke specs and is good for 700hp. How laggy is this turbo on a rb26?
I'm just looking for solid 550hp. What turbo/ turbine housing a/r is recommended? Manifold is single t4 twun scroll with 38mm single wg.
Thanks for the help guys
silviaNC is offline   Reply With Quote
Old 06-02-2013, 01:22 AM   #1008
fsuarez
fsuarez's Avatar
trying to get a bit more power out of my rb20det; trying to achieve 250~350
info on my rb20:
bone stock
godspeed radiator
nobrand name intercooler
3 inch piping from front to back
its got a stage 3 clutch(done by previous owner, decided to keep it because i got used to driving with it)
Let me know what are some minor things i can do to get a bit more power out of this RB
Old 06-10-2013, 11:45 AM   #1009
alexander240
alexander240's Avatar
alexander240 is an unknown quantity at this point
Hey guys alright so i have an Rb20det Silver top with red top plugs everything is plugged up properly harness all done well grounded well but i can not get it to crank over it cranks it turns but i can not get it to turn over and ignite is it the time? how do i check for spark the easyest way?
WTB: Dmax Coupe roof spoiler.
alexander240 is offline   Reply With Quote
Old 06-10-2013, 07:16 PM   #1010
alexander240
So I had a picture on how my Rb20det CAS plug wiring pin ouput was Red, Green, White, Black But now i lost the picture and i need to make sure the correct order of the colors. Please thank you!
Old 06-10-2013, 07:20 PM   #1011
DJZ
DJZ's Avatar
DJZ is an unknown quantity at this point
Your fuel Lines are probably hooked up opposite. Switch around and it'll start
DJZ is offline   Reply With Quote
Old 06-10-2013, 07:21 PM   #1012
alexander240
In line goes to the fuel rail and out goes to the FPR?
Old 06-10-2013, 07:33 PM   #1013
DJZ
DJZ's Avatar
Isnt there 2 fpr's? dont remember, it takes like 5 seconds to switch, its worth a try
Old 06-10-2013, 07:51 PM   #1014
twinspool
twinspool is on the path to ruintwinspool is on the path to ruin
it goes:
fuel filter-->fuel rail-->fpr
I had same problem for few days and was replacing a lot of crap before swapping lines lol
twinspool is offline   Reply With Quote
Old 06-10-2013, 07:52 PM   #1015
Bmxer300zx
Bmxer300zx's Avatar
Bmxer300zx is an unknown quantity at this point
I just swapped plenums around on my rb20 yesterday. The back of the rail gets the "in" line with the fuel filter on it. The front of the rail gets the "return" line . Just think in and out while looking at the rail
Bmxer300zx is offline   Reply With Quote
Old 06-10-2013, 07:54 PM   #1016
Bmxer300zx
Bmxer300zx's Avatar
Originally Posted by twinspool View Post
it goes:
The rb20 has 2 regulators on is a fpr and other is a fuel back pressure regulator. Z32's have em as well. From what I remember a sr20 and rb25 have 1 like in your description
Old 06-10-2013, 09:10 PM   #1017
alexander240
well the lines are stacked on the Rb20 so top line is the IN and the bottom with the FPR is out?
Old 06-10-2013, 09:29 PM   #1018
Bmxer300zx
Bmxer300zx's Avatar
Follow the lines...... I converted to a forward plenum but standing in front of the engine you want the line that goes to the back of the engine (closest to firewall) your IN the one toward the front (by you) is the Return. I know the stock manifold is a cluster fuck but you'll be able to figure it out I had too.
Worst case still confused undo the lines from the regulators and blow air through the ends you're questioning. Not with your mouth a compressor if you need make sure your not pumping air i into the rail or regulators though UNHOOK both sides.
Old 06-14-2013, 11:30 AM   #1019
alexander240
Now that the CAS issue is all squared away now for the vacuum lines how can i find a leak? i know there is a line that is next to the T/b and its open it used to go to the canister but now that its gone is this a reason why it doesnt fire on also? do i just plug the T/b vacuum line?
Old 06-14-2013, 11:42 AM   #1020
slidewayz240
slidewayz240 is an unknown quantity at this point
borrow/make a smoker. there are plenty of diy write ups online. it is the quickest and easiest way to find them. another solution is to take brake cleaner and spray it on all of the lines as the car is running. when the idle picks up, you know you are spraying it where the leak is.
slidewayz240 is offline   Reply With Quote
