03-26-2012, 09:23 PM | #10202 |
You want at least 35mm of thread so therefore you would need 55mm studs or more to be on the safe side.
edit: 60mm will most likely be what you will find... http://www.frsport.com/Nismo-40222-R...R)_p_7862.html
03-26-2012, 09:29 PM | #10204 | |
bump......
20 till 3:00 = ღ |
03-26-2012, 09:44 PM | #10205 | |
03-27-2012, 09:46 AM | #10207 | |
Trader Rating: (58)
Feedback Score: 58 reviews
If you current fuel pump is good, why change it? If you don't change the FPR, the 190 may still slightly overpower the stock FPR. The difference will be minimal to say the least, so it's on you.
03-27-2012, 09:47 AM | #10208 | |
03-27-2012, 10:15 AM | #10209 |
Please help me chose the right lsd for my 1998 s14 with rb25, i want the best for the buck, good for drifting, holds up my 265 tires,last longer. Im between tomei, kaaz2 and os giken. I really not wanna go towards the $1700 os giken lsd unless you guys tell me it really worth the the price. Thanks.
03-27-2012, 10:35 AM | #10210 |
os giken is honestly worth it if you dont want to be rebuilding them in the future. otherwise, kaaz/cusco/tomei have all been proven to work. i've got friends with cusco that like them, you just gotta take care of maintenance with em
street dancer. GLEAM |
03-27-2012, 12:28 PM | #10211 |
Anyone know where I can find thee OEM Nissen 240sx water sprinklers for the front wondsheld? I tried looking for them on courtesy Nissen and wasnt able to find them. Thanks in advance!!
03-27-2012, 01:09 PM | #10213 | |
should be the first two parts. part number. B8930-S13001 (passenger side) part #. B8930-S13002 (driver side) I'm pretty sure u can find them cheaper if u search a little bit more.
03-27-2012, 04:54 PM | #10214 |
Hi, was planning on getting a apexi intake system for my ka24de, but it doesnt come with any aluminum piping whatsoever. Can i use the piping, let say from a injen intake and use the apexi filter to complete the air intake?
03-27-2012, 05:13 PM | #10215 | |
just make sure they are the right size i believe the injen pipe is 3'. just double check.
03-27-2012, 07:44 PM | #10216 |
anyone have experience with any kind of ebay spacers? specifically the bolt on kind?
I was thinking about getting this to run in my rears. And no I will not be doing any track activity with these spacers on. Aluminum 6061-T6 Hub centric Wheel Spacers Adapters Nuts Lugs 20mm 240SX 95-98 | eBay |
03-27-2012, 09:06 PM | #10217 | |||
Trader Rating: (58)
Also, at the cost (140+ shipping for all 4), I'd sooner get extended studs, and call it a day with some slip on spacers.
03-28-2012, 12:56 PM | #10220 | |
HKS 71002-AK016 SSQV BOV C-Clip & O-Ring Set
03-28-2012, 01:46 PM | #10221 |
What is the diameter of my front sway bar? I'm upgrading to energy suspension bushings.
1991 240sx Base, no ABS/LSD/HICAS Here's what I'm looking at: Energy Suspension 7.5121 Front Sway Bar Bushings - 24mm To install the sway bar bushings, do you have to take the bar off and slide them onto the ends and to the correct locations? Thanks!
1991 240sx Hatch Daily'd! |
03-28-2012, 02:00 PM | #10222 |
no boost but doesnt smoke
i have googled already but would like some ideas from you guys, i have a 98 s14 kouki sr20det, lots of upgrades and such, but was driving one morning and had boost, next thing i no i have very little to none, running defi bf boost gauge and read 0.2 bar at most = 4lbs roughly from what it was running 12-14lbs. i checked what i could at the time, intercooler pipes, clamps, vacuum lines hoses, took the intake off and front side is spinning at start up, put intake back on engine starts up fine, no smoke, just almost no boost, couple of guys say it could be the backside of turbo shaft that broke, wastegate was removed to see if i could get boost at closed position same unhooked it and still same. any ideas would help again, i no it can be multiple things just seeing if ur ideas are same or different, thanks for the help
03-28-2012, 09:30 PM | #10223 |
Does anyone know if fwd sr20 flywheel bolt the same as rwd. I just broke a bolt trying to install clutch
2013 Toyota Tacoma, Faster than your beater 240 |
03-28-2012, 09:39 PM | #10224 |
Trader Rating: (58)
They are the same.
03-28-2012, 10:05 PM | #10225 |
Is there any other Nissan that shares the same DIN brackets with the S13?
e.g. Sentra
www.motoredge.wordpress.com |
03-29-2012, 06:40 PM | #10227 |
What size threading is this the stock oxygen sensor on the downpipe cat on the obdii s14?
one like this NAPA AUTO PARTS is it an m12? |
03-29-2012, 08:02 PM | #10229 |
curbed my car back in november. ripped apart the driver-side tow hook part of the rail . Instead of a box, it's bent outwards from the weld.
I know it matters, but how much exactly does it matter? I remember reading somewhere that only to a certain point that the rail is structural. flame away ! for the record, I wasn't trying to drift or hooning or anything of that sort. |
03-29-2012, 09:32 PM | #10230 |
k so the silvia front isnt sitting right on my car, pretty sure its twisted somehow but what is the vertical gap between the headlights/silvia centerpiece and the bumper and hood supposed to be? like tight or like 1/2''?
