Old 03-31-2012, 11:03 AM   #10261
daftphunk
daftphunk's Avatar
daftphunk is an unknown quantity at this point
My speedometer also stopped working. At one point it jumped around. Sometimes it works, but most of the time it doesn't.
I thought it would just be the speed sensor but could the cluster really be dead?
Everything else works except the speedometer
daftphunk is offline   Reply With Quote
Old 03-31-2012, 11:43 AM   #10262
s13Breh
s13Breh is an unknown quantity at this point
Originally Posted by s13Breh View Post
new here and new to turbo'd cars, but have a question. Bought a s13 with a s13 blacktop with a t25. Owner also installed a Blitz SBC Spec R boost controller and he didn't know how to use it lol and also came with a Japanese manual book which I can't read. It reads in cmHg (vacuum) and hkPa (boost). Question is, does the cmHg and hkPa (converted to PSI) have to match up? So what numbers should I input to safely boost at 8 PSI and 12 PSI (future use when upgrades happen) ?
found a conversion for hkPa and cmHg to PSI here: Blitz Boost controller Conversion - RX7Club.com
Thanks in advance!
anyone wanna help me out on this page? lol
s13Breh is offline   Reply With Quote
Old 03-31-2012, 04:48 PM   #10263
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
so I got an s14 sr Cometic gasket, 88mm, I have a stock bore s13 sr, 86mm. I've heard different things about my bore and the gasket itself, would it have a negative effect on my motor? do I need to get the proper size gasket or is this one still good to use?
zneubauer is offline   Reply With Quote
Old 03-31-2012, 07:47 PM   #10264
nathanss13
nathanss13's Avatar
nathanss13 is an unknown quantity at this point
So I got the s13 on the road finaly with a fresh ka with around 20k on the rebuild now I have an issue its got no power at all but ran fine in my parts car . I got new plugs wires o2 sensor got 2 mafs no vacum leaks and as far as I can tell its in time any ideas please let me know
nathanss13 is offline   Reply With Quote
Old 03-31-2012, 09:35 PM   #10265
LockOn!
LockOn!'s Avatar
LockOn! is making a name for him/her selfLockOn! is making a name for him/her selfLockOn! is making a name for him/her self
If it's not the speed sensor its the cluster. Same thing happened in my accord. I I had a jumpy speedo, that died periodically. Changed sensor first, nothin. Changed cluster, problem solved.
LockOn! is offline   Reply With Quote
Old 04-01-2012, 10:18 AM   #10266
h2v7
h2v7 is an unknown quantity at this point
i keep breaking muteki lug keys what do i do?
h2v7 is offline   Reply With Quote
Old 04-01-2012, 10:27 AM   #10267
delado
delado's Avatar
delado is an unknown quantity at this point
use a 17mm socket.
Originally Posted by G240 View Post
I'm glad the Zenki Unite thread isnt lame like this one. Sheesh bunch of girls in here.
Originally Posted by silviaks2nr View Post
That's because everyone with a zenki feels sorry for themselves and they find commonality in the fact that there's no hope for making them look remotely good.
delado is offline   Reply With Quote
Old 04-01-2012, 10:41 AM   #10268
Nackolas13
Nackolas13's Avatar
Nackolas13 is an unknown quantity at this point
RB rb25, rb20det
has anyone physically put the rb25 power steering pump on the rb20 and knows that it fits for sure. i would sure appreciate an answer asap thanks
Nackolas13 is offline   Reply With Quote
Old 04-01-2012, 12:18 PM   #10269
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
If your using a gun to put your wheels on don't, use a torque wrench I've never broken one, make sure the sockets completely over the key
shalezzz is offline   Reply With Quote
Old 04-01-2012, 12:22 PM   #10270
h2v7
Originally Posted by delado View Post
use a 17mm socket.
thanks i tried a 17mm socket it does not fit quite right wont turn em off skips off the splines.
yea i been using the lug iron that came in my car on the bottom of the key...
Old 04-01-2012, 12:43 PM   #10271
shalezzz
shalezzz's Avatar
Most keys are made to accept 2 sockets make sure your using the socket that completely covers the key is should be a deep socket cause you can put one on the end or slide one completely over. Slide it all the way over
Old 04-01-2012, 02:28 PM   #10272
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Which way is the S13 driveshaft loop supposed to be installed?
Let us say the piece on the left is #1 and the piece on the right is #2. The sides facing us are side A, and the sides they are lying on are side B.
Which piece faces down towards the ground and which side should face the transmission?
Thank you!
Old 04-01-2012, 03:17 PM   #10273
ghoti
ghoti's Avatar
ghoti is an unknown quantity at this point
Thank you!
"side A" should face the transmission. the piece on the left should go on top the one on the right on the bottom. Piece on the left is flat so it should mate well with the underside of your car.
ghoti is offline   Reply With Quote
Old 04-01-2012, 04:08 PM   #10274
e5s4y
e5s4y is an unknown quantity at this point
turbo lines
i just want to make sure i have all of my lines connected properly.
i have this one (nearest to the exhaust ports)
By e5s4y at 2012-03-30
going here (with turbo connected to mani, this is pointing towards the strut tower)
then i have this one (bottom of the block, has the oil restrictor in it)
going here (on top of the turbo, under the mani, this is actually where the restrictor is)
and then this one (coolant line from behind the head) going here (opposite side of the first one, facing the block)
thanks guys, just making sure i don't blow my turbo or bottom end, ha
BustedS13: anything you can hide on your person is free. junkyard law.
e5s4y is offline   Reply With Quote
Old 04-01-2012, 05:05 PM   #10275
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Yes, your lines are correct.
Old 04-01-2012, 05:10 PM   #10276
KiLLeR2001
Trader Rating: (46)
[IMG]
Thank you!
Piece #1 on bottom, piece #2 on top, side A on both facing towards front of car.
Old 04-01-2012, 05:55 PM   #10277
e5s4y
Awesome, thanks man. After I replied in my thread, I remembered this thread, ha
Old 04-01-2012, 07:42 PM   #10278
leung
leung's Avatar
Trader Rating: (73)
leung is an unknown quantity at this point
Feedback Score: 73 reviews
I'd switch the first line to the other way around. With the fitting with the bend on the turbo and the straight one on the block. Meh.
leung is offline   Reply With Quote
Old 04-01-2012, 08:13 PM   #10279
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
WHY IS MY PS BELT TOO SHORT???
I Have a RedTop S13 SR20DET, i just got a PS belt from a zilvian, and ITS TOO SHORT???
Its like a 1'' too short, any ideas why?
NO matter how low i put the ps pump, the belt still wont reach, its off by a bit
OutlawLui is offline   Reply With Quote
Old 04-01-2012, 08:50 PM   #10280
ogs14
ogs14 is an unknown quantity at this point
had anybody had there spark plug thread get stuck in the block? because this happened to me yesterday and now i am torn between two things. 1. take it to the mechanic and pay them but idk how much they will charge or 2 try and get it out myself with an ezout. has this happen to anybody and if so what did you do? thank you!!!!
ogs14 is offline   Reply With Quote
Old 04-01-2012, 09:28 PM   #10281
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
a thread were it just lists cross reffrence parts and parts number for RB MOTORS. No its not the RB F&Q thread. cant seem to find it. ubless i might of missed it
does anyone know what that thread is called. ???
has tons of good info for Rb parts.
Vicious Beaner! is offline   Reply With Quote
Old 04-01-2012, 10:50 PM   #10282
KiLLeR2001
Trader Rating: (46)
Originally Posted by leung View Post
I'd reverse the switch the first line to the other way around. With the fitting with the bend on the turbo and the straight one on the block. Meh.
True. Bends go on the turbo, straights on the block.
Old 04-02-2012, 07:00 AM   #10283
Prophet513
Prophet513 is an unknown quantity at this point
Are there crankcase breather filters for s13's?
also of these spark plugs: http://www.ngksparkplugs.com/part_fi...uv/results.asp
is the iridium ix the one i want to get for my mild NA build? and WHERE do i order it...
if the link doesnt work its just the part finder for a '91 240sx and the bottom model BKR5EIX-11
time for a v8
Prophet513 is offline   Reply With Quote
Old 04-02-2012, 08:47 AM   #10284
OutlawLui
OutlawLui's Avatar
Originally Posted by grimm199 View Post
Pulled my header off to see where my oil was leaking from. It is dripping into the header and out of the gasket an burning. The compression in that cylinder is 190 so it isn't the rings. My step dad said it might be the valve guides? Any ideas of anything else? It is also misfiring in that cylinder.
its not your rings, you have good compression because your piston rings are good and so are you valves, BUT!!!!!!!!!, you VALVE GUIDES from your exhaust side are bad, or atleast 1 is. Its ok its not a big problem, just take your head to a shop and tell them to replace your exhaust valve guides
Reason for this is because oil from the top of your head were your cams are is going down trough your vguides and out the exhaust, your car will still run fine like this, but im sure you dont want to be driving around with smoke coming out your exhaust
Old 04-02-2012, 06:46 PM   #10285
blksylv
blksylv's Avatar
Trader Rating: (33)
blksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymoreblksylv is not welcome here anymore
Feedback Score: 33 reviews
wheres a good place online to find metal t fittings for vacuum lines?
there is nothing wrong with enjoying the build. however, we sometimes have to remind ourselves that the build is only one part of the puzzle, and that ultimately - enjoying and driving the car is the number one priority.
blksylv is offline   Reply With Quote
Old 04-02-2012, 08:01 PM   #10286
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
Stuck between BRIDE FG rails or nagisa..... i have a zeta 2 and was wondering with of the two sat lower!!!!
Renelovesnike is offline   Reply With Quote
Old 04-02-2012, 10:49 PM   #10287
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
I need a MAF (maybe).
Long short, KA24 starts fine, but dies after a couple second or if throttle is applied. Unplug MAF, it idles like a champ. MAF sucks right? Right.
Second question: So far as I can tell, the 93-95 Altima KADE shares the same MAF as the S13 KADE. Why the hell is one so much more expensive than the other, if this is true? Is this true? Hook it up!
KA24DE Problem - YouTube
Added a video to show the issue w/MAF.
Prime is offline   Reply With Quote
Old 04-02-2012, 11:58 PM   #10288
No Face
No Face is an unknown quantity at this point
I am going through emisions my car has an sr, does it matter if I use an at from a ka or an sr? Thanks a bunch, also will they check to see if my charcoal canister is hooked up Properky or just that I have one? What do u y'all recommend besides getting new plugs an air filter and N oil change before running it through?
No Face is offline   Reply With Quote
Old 04-03-2012, 06:21 AM   #10289
erict90
erict90's Avatar
erict90 is an unknown quantity at this point
Wanting to know what are the bulb size for the hi & lows on a set of JDM kouki headlights with the bigger projectors, thanks.
Instagram: @erict90
erict90 is offline   Reply With Quote
Old 04-03-2012, 12:06 PM   #10290
daftphunk
daftphunk's Avatar
Just wanted to make sure on this:
I have an S13 Blacktop
I want to go ahead and get a PowerFC, and the one I have found is for a Red top.
From what I have heard, it's just a matter of switching a few wires or something along those lines and it will work just fine.
Can anyone else chime in on this?
