#1021 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
Hey guys, im getting prepped to relocate my fusebox in my 95 S14 SE. Adjacent to the large fusebox the is a smaller box for 3 relays. One of them is blank, the other says Lamp, and the last one says Anti-Theft. I know i can delete the anti-theft relay but which lamps does that other relay control? I'd like to get rid of it if i can but i have no clue what it goes to.
#1022 |
Where is the best place to buy OEM plugs and pins for the chassis harness (S13 if it matters)? I gutted my interior and I'd like to clean up the wiring, but some of the original plugs are missing/broken...mostly for the column, cluster and front lights.
Thanks! Sent from my EVO using Tapatalk 2
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please. |
#1023 |
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
^Wiring specialties sells a connector and pin repair kit.. if youre looking for body harness good luck.. youre better of using completely new plugs like delphi connectors
#1024 |
Maybe I'll just hack some off a junk yard car and solder then up to fresh wire. The main ones i need are two for the turn signal stalk.
#1027 |
#1028 | |
![]() Join Date: May 2006
Shoot me a PM or email if you're interested.
#1029 |
are you guys hiring any positions by any chance?
#1030 |
hey im in the process of removing all my old auto wiring in my s13 since i went to a manuel trans and want to know if i can get rid of the automatic control unit in the cab and all wiring leading to the passenger side relay box?im now running a wiring specialties pro harness now with the auto-manuel connectors
Instagram username:angelmkiv |
#1031 |
So I figured out that you don't need the auto control unit anymore after goin to a Manuel trans..my question again is can I also completely remove all wiring for the auto control unit?the main reason why I haven't is because in the wiring is the inhibitor and nuetral safety wiring..and I'd need those for it to start and have reverse lights..so how did you guys go about removing it? And I have a s13 sr swapped with a wiring specialties harness..
#1036 |
looking for some input on sleeving from those that have experience. Im seeing too many choices here! whats ideal to use in my engine bay?
http://www.wirecare.com/braided-sleeving.asp |
#1039 |
Ok I'll be nice and say thank you
Matej, you are constantly on the cutting edge. I will trade you a full BT harness for your ve motor. I don't know if it sold yet but damn smokin deal dude! Last edited by KoukiMonsta; 07-04-2014 at 07:36 AM.. |
#1041 |
![]() Join Date: Feb 2002
Trader Rating: (68)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 68 reviews
Hey guys Im in the process of getting all my wiring back together so I can get my S14 up and running. I have relocated the battery to the trunk and the fusebox has been relocated under the dash. So basically I am having to rerun all of my power supply to my fusebox under the dash, alt, and starter. Below is a picture of how I plan to have power supplied to everything. Wanted to see if you guys could check it out and make sure all looks well before I go switching the power on and poppin fuses or worse case burning the car to the ground. I have spent hours combing the fsm and I think I have it pretty much setup the way it was originally, just with things moved around a bit. Any input is much appreciated.
![]() The 8 awg coming out of the distro block will feed the 100amp fuse where the two white w/ red striped wires used to feed straight off the battery. The alternator will come off the post on the fusebox. I believe that is the way it was from the factory. |
#1043 | |
Come get it and I will give you a discount. ![]() |
#1044 |
Trader Rating: (68)
Ok great!!! Well I should be able to get it all hooked up tomorrow and make sure I have power to everything. If all is good then it is on to the task of pulling the harness back out and looming everything up and putting it back in for the final time!!!! Ill post up pix once it is all completed.
Cameron |
#1045 | |
Get to it! Drawing looked good, rebuild that whole harness! Ps - matej does your car run these days? |
#1046 | |
Trader Rating: (68)
Cameron |
#1049 |
#1050 |
Trader Rating: (68)
Well went ahead and pulled the front chassis harnes out all the way to the firewall, for the third time. Stripped it all back down to bare wires lengthened a few things that I wasn't satisfied with the first time. Also took all the grounds from the pass. side and ran them to one wire, did the same with all the driver side grounds, and then terminated them all in one spot. Reloomed the entire harness with techflex fire retardent sleeving and Dual Wall 4:1 adhesive lined heat shrinked. Drilled a hole in the upper frame rail close to the firewall and routed the harness through the frame rail and out the front through another hole I drilled. By the way this part was a PITA so I HIGHLY recommend you have everything loomed exactly the way you want it and make sure everything is in working order first!!! Ill post the pix of the finish product but if anyone is interested in the process pix just pm me. Still waiting on some more heat shrink to finish up a couple connections since I ran out.
![]() Out of the firewall into the frame rail. ![]() Out the front of the frame rail. ![]() The two new grounds for all lights, amb. temp. sensor, and brake master. ![]() Driver side runs. ![]() Pass side runs. |
