03-10-2008, 07:41 PM | #1052 |
Thats actually got rear overfenders. GTR style, Origin?
Garagesokudo.com.au - JDM tyt wheels. Sokudostyle.com - Sokudo Lifestylin' |
03-11-2008, 06:40 AM | #1056 |
heres his specs list
1989 Nissan Silvia Owner: Nigel Petrie Occupation: Fitter and Turner Length of ownership: 2 years Mods: Engine: Fully rebuilt SR20det TOMEI Rocker arm Stoppers TRUST Inl 264, EX 272 11.5mm Cams GREDDY Valve springs HKS 1.2mm Head gasket ARP head stud kit Nismo low temp thermostat CP 86.5mm Forged pistons (9.0 Comp ratio) Ceramic and teflon coated EAGLE Forged H beam Rods Rebuilt Head Trust sump Billet underdrive pulley set Racespec engine mounts Splitfire coilpacks GFB lightweight crank pulley Microtech LTX8 computer with custom loom Induction and exhaust: Trust TD06L2 full turbo kit with 45mm ext wastegate Custom inlet pipe with K+N filter Custom intercooler pipeing Hybrid GT cooler Samco joiner hoses 80mm throttle body Custom Inlet plenum with 45mm ram tubes Full 3 inch stainless exhaust Cooling: Earls oil cooler with GREX sandwich plate 60mm radiator Custom alloy radiator plumbing Greddy header tank Modified coolant lines 2 12inch thermos Nismo thermostat Custom coolant overflow bottle Fuel: R33 GTR fuel pump Sard regulator Defi fuel pressure gauge Custom fuel rail with earls fittings 870cc Siemens injectors Driveline: Z32 Gearbox with SR20 adapter kit Short shifter OS Giken Fly Wheel OS Giken Twin plate Brass button Clutch Custom Gearbox Mount Custom 1piece Tailshaft with hoop Welded diff Front GTR 5 stud conversion Rear GTR 5 stud conversion Suspension: HSD coilovers 9k front and 6k rear springs S14 lower control arms Super now rod ends Tien tie rods Adjustable caster rods 22mm front swaybar with rose jointed mounts 20mm rear swaybar with rose jointed mounts Adjustable rear camber arms Adjustable rear toe arms Adjustable rear traction arms Custom rear cradle bushes Urathane mounts replace every rubber bush Footwork: Front: Rays Volk Racing TE37 17x9.5+12 with 215/40/17 rubber. Rear: Rays Volk Racing TE37 17x10+18 with 235/40/17 rubber. Spare 18x10.5+22 Rays Volk Racing TE37 in Bronze Rays wheel nuts Brakes: R33 GTR Brembo Brakes all round EBC red stuff pads Slotted rotors Maltech Braided lines Tilton Pedal box with short series Tilton master cylinders Extended hand brake lever F-R Brake bias adjuster Inside: R32 GTR reclineable buckets lowered 50mm Defi Boost gauge Defi Oil Temp gauge Defi Oil Pressure gauge Defi Exh Temp Defi Water Temp Defi Fuel Pressure gauge Defi controller Motec shift light and Oil press warning light HKS EVC boost controller Custom loom made from scratch Removeable steering wheel hub RPM sued steering wheel Guttered dash Oddysey dry cell battery mounted on top of gearbox tunnel White guages Chassis: Stich welded chassis Strengthened strut towers Strengthened chassis rail Safety 21 roll cage with weld on mounts Front tubs Custom tin work Custom radiator/intercooler sopport Outside: Nismo front bar Nissan side skirts Pumped guards RPM mirrors Raised bonnet Shaved bootlid Origin carbon roof lip, boot lip and sun shades |
03-11-2008, 06:25 PM | #1060 | |
Trader Rating: (25)
Feedback Score: 25 reviews
Thats a pignose lip with the chuki bumper! |
03-11-2008, 10:06 PM | #1063 |
still need a good side shot of the dannger cart and am wondering if anyone has a pic of the vw speed demon idol thing they used as a promotion a while back
03-11-2008, 10:12 PM | #1064 |
Anyone Have Pics Of A Kouki 97-98 With The Stock Usdm Front Bumper And Lip But The Zenki 96-96 Side Skirts??
I Have Been Trying To Find A Pic Of This For A While Now But No Can Do.... Please Help. I Wanna See What It Looks Like Cause Im Thinking About Doing It.
03-12-2008, 08:35 AM | #1068 | |
Here's the real deal: http://www.aeroparts.co.jp/msports/180sx_b.htm |
03-12-2008, 07:34 PM | #1071 | |
any more from the front? |
03-12-2008, 07:50 PM | #1074 |
Trader Rating: (25)
Yeah, it's my buddy Tom's car.
http://i116.photobucket.com/albums/o...n/100_3081.jpg If you need any more, just ask. I have plenty. |
03-13-2008, 01:05 PM | #1080 |
Does anyone have a picture of a 10 inch wide wheel around offset 12 on the front of an s13?...mainly for strut body clearance issues.thanks
"There is no fail when there is no win!" -Break Win Garage |
