#1141 | |
also, stock seat covers come off, zipper on back side, pull the padding out, put it to wash/air dry. Soak the cover with a wet rag, then push down on the spot and "pat" it off. Steam clean if necessary or take it to a shop and they can do it. Good luck. when you push down, use enough force to make the water seep through the top, kinda like when you step on a wet rug or shoe. The material is so compressed the water is squeezed out
street dancer. GLEAM |
#1146 | |
#1149 |
![]() Join Date: Jan 2008
So to all you S14 dudes with a Double din DVD unit. How did you bypass the sensor that wants to stop you from being able to play DVD's while driving?
Not that I'm going to be watching and driving, but passengers might.
#1150 | |
![]() Join Date: Feb 2009
from what a buddy told me a while back there is a wire that gets wired to the park position or something but it just needs to be unplugged or bypassed
JUST A RED TOP SR |
#1151 |
Wire the E-brake sensor wire from the headunit to a switch. Flip the sitch on and off, acts as if the ebrake is engaged and allows you to play dvds while driving.
#1153 |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
Well hold on there just a minute... it totally depends on the brand of unit and sometimes even the model. Alpines you need a little module that clones the foot brake and e-brake sequence. Other brands you can simply ground the e-brake input wire. Yet others need a switch because it needs to see a negative on-off-on sequence. While some Pioneers need to have a wire moved in the harness to another pin, then grounded.
#1154 | |
See this is why I claim you my hero. Always knowing what your doing when you open your mouth unlike some and you have the experience and proof to back it up ![]()
JUST A RED TOP SR |
#1158 | |
![]() Join Date: Sep 2006
There is actually nothing under it, not even a glove box. Its there to hold the speedo and the vin. , and to maybe look like a normal car, lol I dont want to spend the money on a real seat and the proper rails right now, cause i would have to do both at once. I run an old style american harnes, so its 4-5" wide. With that snug, i dont move anywhere, lol. |
#1159 | |
do you still have the stock belt? I would assume putting on the harness to daily would be a bitch
#1161 | |
Im driving a race car on the street basically. ^need seats like those ![]() good head clearence. |
#1162 | |
![]() Join Date: Sep 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
#1163 |
Philosopher King
To me that is bs. Safety is up to the consumer not the manufacturer.
G O L D E N B E A R R E P U B L I C |
#1164 |
#1165 |
Philosopher King
I know what liability means and I think it's bs. Why isn't the driver responsible for NOT watching a damn movie while driving? It's retarded.
#1166 |
![]() Join Date: Feb 2007
![]() Feedback Score: 9 reviews
Nothing special
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html Owner of NVS Fabrications |
#1170 |
Cant you wire that up to a toggle switch to ground out the circuit while you are driving to play video?
