#1142 | |
![]() Join Date: Nov 2011
#1143 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE! 10.79 @ 124 MPH WITH A 1.48 60' |
#1145 |
Thanks, I can't see anything on my work computers because of restrictions.
#1147 |
![]() Join Date: Mar 2009
Hey guys tell me what you think
here is my times at my local 1/8th mile track 60ft 2.280 2.254 2.310 MPH 92.59 92.97 92.98 ET 8.626 8.575 8.539 My best ET of the night was 8.504 with a MPH of 90.73 don't have the 60 foot for that one My setup is Motor and drivetrain Sr20det stock bottom end and stock valve springs 3071R on a stock manifold Freddy intake manifold s4 intake and s3 exhaust cams greddy inter-cooler Spec flywheel and stage 4 clutch 1pc drive shaft solid motor and transmission mounts Aem tru-boost running 13 psi in 1st gear and then 19 psi in 2nd and 3rd Suspension Solid subframe bushings full poly kit installed around CS coilovers full soft in the rear Spl Toe arms and RUCA with lock-out kit Tires Running 275/40/17 BFG Drag radials off my 98 cobra I'm am burning out but having a hard time staying near the burn out box the car just wants to take off also the car weighs 2700 with my fat ass in it any tips on lowering my 60ft would be much appreciated.
It's just the internet ![]() Last edited by z2roll4life7; 01-21-2014 at 08:29 PM.. |
#1148 | |
![]() Join Date: Feb 2008
![]() ![]() Feedback Score: 4 reviews
#1149 | |
#1150 |
Here is a link to my R230 rear end install. Figure the Drag guys might be interested in this..
http://zilvia.net/f/s-chassis/552252...0-install.html |
#1151 |
Seeing as most S chassis people are just into sliding around is there a good aftermarket drag suspension still available? Not interested in a stock suspension.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#1152 | ||
Back when I had my t-25 the best I could do was 9.002 at this track I have a JWT tune so no traction control. The car is pretty fast on the streets and up in the mountains. I guess the 1/8th mile doesn't like me. Quote:
Since my 240sx is a weekend mountain whore the stock suspension won't cut it up there thru those corners. I'm pretty sure I had my PSI around 22-23, how low should I go? I'm also swapping in a s14 Subframe hopefully that will help me get more traction.
It's just the internet ![]() |
#1153 | |
Otherwise you're better off with some softish lowering springs and the factory struts.
#1154 | ||
#1155 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
@ TOM or you can contact Fortune Auto and talk to their techs about the setup you have and get a custom set made. Between the discount and the custom upgrades I paid nearly the same amount as an off-the-shelf set of FA coilovers.
#1156 |
I finally got out for a baseline before I rip off the drift oriented nonsense. Only got two runs in tonight and these were the runs I've made on a prepped surface in over 5 years. First run I spun, second was a bit of a bog.
Run1 Run2 60' 2.46 2.396 1/8 9.51 9.33 MPH 79.9 80.42 1/4 14.40 14.19 MPH 101.1 101.0 I know my 60' sucks the big one and that's to blame on my heavy amounts of rust as far as launching goes, shit tires, and shit coils. My question is, would I be off in saying I can get into the 13s fairly easily with a better tire/stock rear suspension?
#1157 |
You have enough to get into the 13's if you just practice your launch. Tires and a better drag orientated suspension will help more as well.
Rule of thumb, for every tenth you shave off in your 60ft you knock off two tenths at the back end.
#1158 |
Thanks did not know that about the 60' but it checks out with my times. I forgot to mention the other differences between runs. I short shifted at 6k and "easy" shifting the first run to feel the car out. 2nd run I shifted a little past 7 but the t25 was just falling on its face.
Unfortunately the next day my tack is open is Valentine's so I won't be able to get back out till March. Maybe that'll give me time to throw in some poly bushings and get rid of some wheel hop.
#1159 |
![]() Join Date: Oct 2007
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#1160 |
You could try floating the rpms around 3500-3700 and slip the clutch. Seemed to work back when I played with low power sr's. also depending on what tires you use sometimes doing a burn out in the water box is pointless or even doing to long of a burn out with slick up z-rated tires
#1161 |
Yeah I'm definitely going to have to slip the clutch. I launched at 3500 but came out too aggressive. I didn't do any long burnouts, just a quick spin to clean them off.
#1162 |
Technically, you should be shifting when you reach or just past peak power. Once you "feel" like you're not accelerating anymore, you need to shift to the next gear. No sense dragging out to 7k and risking damage.
#1165 |
![]() Join Date: May 2006
The Bosch 1600's got discontinued, they had flow problems at higher fuel temps... I don't think anyone still sells them. It's either the new 1300's or 2000's.
#1166 |
buy the injector dynamics and never look back. Far more tune-able and easier to make idle.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
#1167 |
I took the fuel rail to a machine shop to have them open up the holes to 14mm. If I had the money to buy injector dynamics I would. I already had these injectors so I will see how they do for the summer and then buy the injector dynamics 2000cc next winter. Thanks for your guys' input. Hopefully I can make these work for the time being.
Sr22 in the works |
#1168 | |
95 240sx RB20 415whp 91 Nx2000 VVL yo |
#1169 |
FIC 2150cc injectors....great for e-85. Just like hooking up 4 garden hoses to your fuel rail. haha
#1170 |
Yeah I run 8 ID2000's on my LSx, it's ridiculous... but they work so well down to 1ms pulsewidth that the car idles just fine even on pump 91.
