10-16-2012, 02:42 AM | #11821 |
350z- 3rd Gear No Longer Exists
Took my 2003 350z out to the track for a drift event yesterday. Everything was fine throughout the day until we left for home. I got on the highway and moved from 1st to 2nd with no problem. When I went into 3rd gear it was like I was in neutral. I thought maybe I shifted wrong so I pushed the clutch in and tried again, and still all rev no go (Doesn't grind or make noise). So now I'm doing 1-2-4-5-6. Should I be looking for a CD009 replacement now, or is there an easier and more cost efficient way to fix the problem?
10-16-2012, 06:55 AM | #11822 |
I want to make motor mounts for my Sr and want them to be solid aluminum like the excessive manufacturing ones. I'm just wondering what lenghth and diameter aluminum I would need
10-16-2012, 07:27 AM | #11823 |
BIG WTF Question: KA24DE valves are slightly smaller for the exhaust side than the intake side. All cam sets that are offered are only single pattern, ie, 256/256, 264/264, 272/272. With smaller valves on the exhaust, why are there no dual pattern sets to exploit the exhaust side with a longer cam event, ie, 264/272?
Would a dual pattern cam set not offer better engine scavenging to pull more air through higher vacuum velocity into the compression chamber? I do know one thing with 'carb' based four valve motors with dual pattern cams, they have a wicked nasty sounding idle that kinda has that baWUP baWUP baWUP sound. The only video I find have tiny 248/232 cams which seem a little backwards with exhaust valves being smaller
10-16-2012, 09:37 AM | #11824 | |
And stuff that sounds 'wicked nasty' doesn't always mean 'wicked fast' or even that it's running correctly. I don't know what your education background is or what level you are trying to get into this, but this book will answer allot if you already know some mechanical engineering/thermodynamics: Internal Combustion Engine Fundamentals, (007028637X), John B. Heywood, Textbooks - Barnes & Noble
* S14SR22 * 9.0 c/r * GT3071R * |
10-16-2012, 03:52 PM | #11825 |
I bought a head in the mail and when i opened the box the buckets had fallen out and im not sure which ones go where. is there an order or can i just put them wherever?
10-16-2012, 04:48 PM | #11826 | |
As an example, the last V8 I built, a stroked 351 --> 427ci, I had a choice between either a single pattern cam or a dual pattern cam. Both had similiar hp figures, but their torque curves were slightly different between 2500rpm and 3500rpm where many cams suffer a slight depression in the dyno sheet. The dual pattern cam smoothed this out by over 45%. The hp at the top was also slightly higher rpm as well. Again I ask, why are there no dual pattern cams for the KA? SImple small question that I believe rates a responsiblely solid answer from someone who knows their stuff
10-16-2012, 08:22 PM | #11827 |
Anyone got a rough/previous sale price for an R33 GTR/Autech S14 rear subframe brace bar thing?
Trying to buy one but have nfi what it's worth and seller wants way too much money for what is essentially a couple of bits of tubing. |
10-17-2012, 12:37 PM | #11829 | |
Without an issue?Depends The S13 has the EGR bung hole in a different place so you're going to have to modify your EGR pipe to fit. It also has another bung hole that is used for the IACV which the s14 doesn't have. So it all depends if you wanna pass smog or not. |
10-17-2012, 04:11 PM | #11830 | |
AFC #1
Dual pattern cams compensate for the intake manifold or exhaust header being less efficient then the other. Used to make the idle quality and vacuum better. The lope sound you describe is due to valve overlap not duration.
10-17-2012, 04:18 PM | #11831 | |
should it be necessary to get my driveshaft rebalanced after changing the front yoke/bearing?
10-17-2012, 05:37 PM | #11832 | |
Trader Rating: (32)
Feedback Score: 32 reviews
10-17-2012, 06:20 PM | #11833 | |
someone correct me if im wrong. if you took apart your driveshaft it needss to be balanced, if you only removed the yoke it should be ok.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
10-17-2012, 09:00 PM | #11834 |
Nope, that ain't me, just some letters I like
10-17-2012, 10:13 PM | #11836 |
Nissan 350z owners...
Windshield washer tank started leaking then just spilled everything out checked both my pumps and replaced both but still drips... No holes in the hoses. Any idea why? |
10-18-2012, 01:37 AM | #11837 |
So there are an @$$load of awesome diys to swap engines but:
What sites are reliable to buy SR's, KA's and VG's USDM or JDM(preferably)? Are there certain shops that do eng/trans swaps? Rounded up, what's an estimate like? 500-1k for an eng swap? I've google'd Illinois for Nissan shops and I guess I don't know enough to word my search right. And I've settled on buying a Z32 and getting a TT conv or S14.5 w/ SR-T |
10-18-2012, 08:37 AM | #11840 | |
Your source for rare JDM Parts | JDM Hookup Call them for prices because it will depend on what exactly you want and it sounds like you haven't decided yet.
10-18-2012, 09:35 AM | #11841 | |
There are a few cam makers that make the cams for the KA, either in NA trim or -T trim. The only problem is that they are all single pattern, so again my question is WHY are there NOT any Dual pattern cams? I would think that SOMEONE here might know one of the guys(JTW, BC, KELFORD, et al) to properly answer what I am asking. I get it, we all have knowledge of how these motors work at the mechanical level, the function of the fuellie system, some the ecu's(Martin at RSE, et al), but the reasoning behind the why as to dual vs single pattern cams has still not been answered.
10-18-2012, 10:06 AM | #11842 | |
AFC #1
In S14's and S13 with SCV's removed the KA has a balanced intake and exhaust. There is no need to compensate by running different intake and exhaust duration. Being a dual cam motor you can also mix and match cams to get different durations. The KA market is not as big as the SR to have on the shelf singles like the SR does.
10-18-2012, 11:51 AM | #11843 |
S13 reverse light on a manual swapped car. I bought the car manually swapped, I found the plug on the sr tranny, and it of course is not hooked up. What 2 wires should I be hunting for and where to make the reverse lights work.
10-18-2012, 01:09 PM | #11844 | |
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
10-18-2012, 01:19 PM | #11845 | ||
NICO has some good stock KA cam swap information iirc, but I am not gonna search it for you. Quote:
Also, your location is quite offensive, lol.
10-18-2012, 09:22 PM | #11848 | |
Do these guys do Z engines? I don't see them but I see no reason why they wouldn't. |
10-18-2012, 11:02 PM | #11849 | |
They can put 1JZ, 2JZ, RB, LSX, SR and VQ in anything and have done it for years, all that's left is for you to call, really.
10-19-2012, 06:16 AM | #11850 | |
I was perusing the web video selections and found quite a few with KA cam swaps. Mostly it was stock motors with 248's and a few 264's and only the ones who actually rebuilt the motors for a higher state of tune had the 272's in them. SR's: From my understanding, they come in both turbo, and non turbo. Turbo for JDM, sideways mounted non turbo USDM. SR cams are SR cams. With this said, is it a bad idea to consider a non turbo, high compression, hot cammed NA SR?
