#91 |
Been doing a little thinking lately where i could put a pair of auxillary coolers. Used my awesome paint skills to depict my idea thus far. Ive always been a big fan of the ferrari f40, and ive been wanting to incorpate a few design features from it into the 240. A while back i decided i wanted to do the triple exhuast tip look from it. I also thought of today doing a naca duct on the quarter panel to feed air to a pair of coolers mounted vertical within the rear body below the tailights.
A plus side to this is bringing more air behind the car to lessen the low pressure area that causes drag on cars. So not only will i be drawing air from a fairly high pressure area, i will be disposing of it in the most effective area against the fight for less drag for more efficiency. The red squares are the coolers, the three black circles exhaust tips, the blue square rear diffuser, and the yellow and orange depicts various tempertures of the air exting the various parts ![]() ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:44 AM.. |
#93 |
Frankly i forgot to mention it at all. Original plan was to just cut the bumper to contour around everything, but with the position of the coolers and how far out the bumper sticks back form the body i dont think it would be very visually pleasing. I may either make a flat panel to go where the rear bumper is, vs how the stock one sticks out, or not run one at all depending on clearance and ducting needed. Height wise im not sure i will have enough room between the taillights and top of rear diffuser to run the exhaust in the center and the two coolers. May have to ditch the tri tip exhaust and just run it off to the left side straight out.
If the rear panel id make is going to be cut all up any way there is no sense in making one just to cover up the sides, as i have to fit a license plate back there as well. So currently, who the fuck knows if i will run some form of a rear bumper, not a huge fan of cars without it, but i will have ducting, diffuser, exhaust etc higher up where most cars ive seen havent really cut into the rear body. SO i have no clue till i start fitting things up and see how it all looks. ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 |
#95 |
![]() Join Date: May 2009
^^ Those welds are better than mine. Damn i totally forgot about the car show at the Superdome. Slanging tires for Pepboys is taking to much of my free time.
#96 |
Over the last few days i was able to get the everything bolted up, throw the stock suspension back on, and lower it down under it owns weight. The conclusion i have come to is this motor sits FUCKING LOW. The center of the heads sit even with my knee caps (I'm 6'1 for reference) needless to say its way down there.
![]() ![]() ![]() ![]() ![]() Also swung by my dads to pick up and borrow some tools vs just buying my own right now. saving money is good, who cares if your using tools that aren't your own. Biggest thing i picked up tho was his tubing bender. Saved me a few hundred bucks from buying one, and i dont have to wait for one to get shipped in either. Week or so ago i ordered a tubing roller. How this differs from a bender is the roller will give the tubing a nice radius bend, where as the bender gives short specific angle bends. Roller will come in hand for various pieces i.e. strut tower bar, some smaller wall roll cage tie in points maybe etc. Also picked up from dad a few angle finders and a tool to hold in place the tubing while you tack in place. Pretty usefull little tool ![]() ![]() ![]() ![]() ![]() I also have multiple parts on order currently, I'm quite excited. Heres a run down of what all is on order. - Front and rear fenders -Front and rear flares -Roll cage tubing -Bucket seat -Hole saw bits to cut roll cage Actual work itself on the car is going to slow over the next month or so as i have two large side jobs ill be under taking. So ill be tide up with those for a bit. They also are paying quite well so i should also in the mean time be able to get a few more parts ordered as well, namely rear inner and outer barrels to start mock up of the wheels. Cant really measure for the fronts yet as i need the new knuckles, lca's and coilovers as well. So front mock is still a ways out. Hopefully my friend buys my Varis parts in the next 2 weeks as promised and ill be able to get the knuckles and such just mentioned on the way. Busy times ahead. My bank account is really feeling it :/
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:45 AM.. |
#98 |
Work hard play hard.
#99 |
Had some unexpected free time today, so i cleaned up the garage a bit and threw out some things to make room for my buddys Cts-v that he is dropping off early this week for somebody work. Wait till y'all see this fucking thing.
![]() ![]() ![]() Also took the time to use some spare materials i had laying around to sorta mock up how i want to do the front tube work. The outside bar will be joining the downbar/dashbar through the firewall and the two angled bars will be going through the cowl and connecting to the dash bar as well. I fell this will be a very sturdy, structurally sound design. Of course there will be some bars connecting these upper bars to the lower rail. Ill figure that out once i come to it, but i already have a few ideas. ![]() ![]() ![]() ![]() Also picked up some 1/2" conduit the other day to mock up and try out some ideas for the age before i bend the actual dom tubing for the first time. dad recommended it and said ti was a good way to try new angles and such. ![]() ![]()
#100 |
Bro.. I am mind blown at how much your putting into this. Its crazy and i admire it! great job and ill be keeping posted. Best of luck and crazy ambition you got going! i'm rooting for ya haha
#101 | |
#102 |
Borrowed some glass tools from work today to pull the windshield. Was going to do the qtr windows as well but didn't feel like fighting with them as i **** using the saw, decided to pull the hatch and some door gaskets as well. Also found a bit of rust under the windshield urethane, but not a big deal as it isn't bad at all.
Does anyone know where to buy some New Old Stock gaskets and trim pieces for an s13? I have a feeling its going to be a bitch locate some factory gaskets and such Also got the car moved over as tomorrow the cats-v is getting dropped off, and she needs her space inside while i work on her. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Also went to a cars and coffee this past sunday. Some lovely machinery, and also my attainable dream car, 997 911 turbo. Mint condition, stock, manual, and not a crazy color interior. Ugh much want. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#103 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
Wait so you built a 199(X) 240sx instead of buying a 911......
I'm all for building cars and all but damn. I would have 100% wentry with the later choice. But that's probably why I'm not rich |
#104 | |
In a years time we will have an idea of the extra cost of the child and can budget for such, should be able to pay off the wife car and have enough set aside for a good down payment on a 911. Then ill have a truck to haul/tow with, a weekend/track day full on "racecar" 240x and a daily 911 turbo. Then in the next few years ill probably have to buy the wife a used aston martin vantage because she keeps saying i get my dream car she gets to get hers too. ![]() ![]() ![]()
#105 |
Trader Rating: (42)
Those two cars you are talking about definitely puts you in the upper class
And lastly I would not ever daily a 911. Maintenance alone would keep me from that. Then leads me to the same pointmonth thus is why Im not rich lol |
#106 |
![]() Join Date: Feb 2007
Trader Rating: (66)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 66 reviews
My S13 Build : LS swap, Corvette transaxle, ITB, Widebody, Do everything car
Try Nissan Race Shop / Fontana Nissan for trim pieces, moulding, etc.
They are a Vendor on here and give a decent discount. |
#107 | |
![]() Thanks i will check the out
#108 |
Well, the cause of no progress on the 240 is here. Decided to make a separate build thread for it to keep mine uncluttered in here.
http://www.stanceworks.com/forums/sh...ad.php?t=83789 ![]() ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:46 AM.. |
#111 |
Haha it's a buddy of mines. It will be gone in a months time. Doing some fender and fitment work on it.
#112 |
So the other day i was doing a bit of thinking on my tire sizes. The current plan is
Front 315/30/18 18x12.5 Rear 335/30/18 18x14 I fully intend to put this car through its paces on the road course and other various events. But at the same time is purpose down to its core is just a fun, badass looking car i can hoon in on the streets, to meets, and various events. With that being said a big inspiration to this build is the gt300 racing class put of japan. I love the way the cars look with their raised fender hips and large slicks and aero. One thing i have noticed is they are all running the same size front and rear tire (to my knowledge). So it got me thinking, logically it makes sense, tire rotations, swapping front to back etc to keep rear tire overwear to a minimum from over spinning etc. So im considering just going batshit insane 18x14 335/30s all around. Will give it that big tired wide hipped look i love from the gt300 racing class, better tire life from being able to rotate tires, and and its something i believe know one has ran width wise up front as well. \ I know someone brought up getting enough heat intot the tires to actually make use of them. But i have some big plans aero wise to generate some actually useable/measureable downforce that will def get me the heat and use out of the size of the tires il be running. ![]() ![]() ![]()
My S13 Build http://zilvia.net/f/showthread.php?p=6005967#post6005967 Last edited by laextreme5; 03-14-2016 at 09:47 AM.. |
#115 |
I think they run 13J, but could be wrong. Regardless those cars are simply inspiration, not necessarily guidelines im going by. Just the look im after to an extent.
#116 |
Piss poor update, but it is one. While i had my friends caddy's wheel off I measured to see the overall height of the tire, and much to my surprise it's the same overall diameter as the tires i intend to run. So I'm sure you know what happened next. I rolled the wheel over to the back of the 240 and good god. These son bitches are going to be huge. Its exactly the look I'm going for. Cant wait to see what it looks like with all the planned aero and wide body.:eyebrows:eyebrows
Currently still waiting on wide body panels to come in as well as roll cage tubing. Also have a seat on order, which is a ways out still as its coming from the land of the rising sun. I hate waiting on parts..... ![]()
#118 |
Won't be that bad, looks even bigger being out of the wheel well like it is. Although the height still shouldn't be downplayed, it's tall haha
#120 |
Lol no compensation, im not a douche trying to prove something. Building this car for me, and i simply enjoy sharing the progress with others.
