Old 07-31-2006, 09:19 PM   #91
bigJ86
bigJ86's Avatar
bigJ86 is an unknown quantity at this point
Send a message via AIM to bigJ86
the 4.6 is much larger then the 302... and the heads are also very wide.. do to the fact the 4.6L are shoc and dohc engines.....
(sorry for small pic)
" i'm going to **** you in the ass till you love me "-mike tyson
bigJ86 is offline   Reply With Quote
Old 07-31-2006, 09:38 PM   #92
S14DB
AFC #1
S14DB's Avatar
Mod motor would be way to wide.
Old 07-31-2006, 09:39 PM   #93
bigJ86
bigJ86's Avatar
weight for a 302 with iron heads is around 460-480lbs + t-5 transmission is 85 lbs
so a 302 with tranny is 545-565 wich is lighter then a KA with auto tranny......
Old 07-31-2006, 11:53 PM   #94
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Wow, I never realized how wide the 4.6 is.
Does that include exhaust manifolds and all accessories? Cause I just don't see how a iron block & iron head v8 weighs less than a 4 cyl with aluminum head...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 08-01-2006, 12:24 AM   #95
bigJ86
bigJ86's Avatar
ok i just did a lil more searching...... a 302 long block..... weight is 460 lbs....... so with all the accessories.... will be about the same weight as a KA... wich aint bad since it dose have iron heads stock...... just switch to aluminum heads, and u will save 50lbs and gain about 40hp.....
Old 08-03-2006, 02:04 PM   #96
ranger2339
ranger2339's Avatar
ranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura about
Send a message via Yahoo to ranger2339
Man the 03 cobra motor would be sick to put in a 240...
on another note i just placed my order with Hinson and will be getting all my install kit,cooling,tuned ECU, fuel system,exhaust and driveshaft...
Everything i need to get my LS1 into my coupe..
Ax
ranger2339 is offline   Reply With Quote
Old 08-04-2006, 12:04 AM   #97
ledzeppelin240
Keep us updated...I'm waiting till next summer to order all my stuff for my coupe.
Old 08-04-2006, 12:12 AM   #98
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Ax
How much did all that run you?
Neejay is offline   Reply With Quote
Old 08-07-2006, 04:00 PM   #99
ferris
ferris is an unknown quantity at this point
Send a message via AIM to ferris
what about tool requirements for the swap, would you need more tools because of fabrication needs and other differences then from say, an SR swap? Also, how much modifying and fabrication needs to be done if you buy the complete kit?
ferris is offline   Reply With Quote
Old 08-07-2006, 04:11 PM   #100
ThatGuy
Admin Asshole
ThatGuy's Avatar
Only fabrication is modifying your subframe. You could just go to the website and find out for yourself. www.hinsonsupercars.com
Old 08-08-2006, 02:54 AM   #101
blu808
blu808's Avatar
Thanks barry.
If you dont have a welder and all that jazz you can just order a complete swap kit including the x member. If you do it that way it is easy. You dont even need to cut the chassis like a sr swap. Just throw it in, and you can light em up at 120mph.
Old 08-08-2006, 02:59 AM   #102
Neejay
Neejay's Avatar
Originally Posted by blu808
Thanks barry.
man...I wish. So the most expensive thing is the engine themselves? (assuming lsx)
Looks to be a $6k-7k swap total.
Old 08-08-2006, 03:58 AM   #103
blu808
blu808's Avatar
You gota pay to play man.
You can have a 300 whp sr that needs frequent maintence, rebuilds, blown turbos, etc.
Or you could pay double and have a 350hp 350 tq motor that is smog legal and all it needs is an oil change here and there.
And it gets you laid.
Old 08-08-2006, 04:03 AM   #104
Neejay
Neejay's Avatar
LOOOL Yeah, Im not knocking it at all. Hell, if I had the extra cash, I'd do it in a heartbeat.
It's just fucking impossible to do (in my situation) without a real full-time job. Im starting a temp full-time job (co-op).
I can't imagine what'd it feel like to have a NA monster and dont even had to mod it at all.
Old 08-08-2006, 04:15 AM   #105
blu808
blu808's Avatar
From what i have found, craigslist is a good way to make money. Just become a jig like me.
Old 08-08-2006, 08:39 AM   #106
ferris
can this swap really be done for 6-7k? i thought it would be closer to 10-11k for the whole thing....i guess it depends on engine cost and whether or not you buy the kits.
Old 08-08-2006, 10:10 AM   #107
ThatGuy
Admin Asshole
ThatGuy's Avatar
It really depends on the engine you use and where you get it from. You can dig an LS1 out of a junkyard and hope it was well treated before and only pay $3000 or so. You can also go the crate engine route, which is much more expensive but reliability is awesome. Personally I have found a LS2 crate engine that makes 510hp and 480ft. lbs at the crank. It also costs $10,000 and it's brand spankin new. I've got alot of saving to do if I want to go that route.
Old 08-08-2006, 04:51 PM   #108
Jonas427
Jonas427 has a little shameless behavior in the past
How about this. Using all Hinson parts, how much will it cost to get everything you need, excluding the engine and transmission?
Jonas427 is offline   Reply With Quote
Old 08-09-2006, 04:39 PM   #109
shinrekka
shinrekka's Avatar
shinrekka is an unknown quantity at this point
for the 5.0 swap, dosent the mustang use a cable instead of a hydrolic system for the clutch. How would that work? Im not positive but I beleive the z31 uses the same tranny as the 5.0 but it may be hydrolic. Who is producing the 5.0 swap kit, hinson supercars? or was it another company? And when is the expected release date?
shinrekka is offline   Reply With Quote
Old 08-09-2006, 05:00 PM   #110
Fat Felix
Fat Felix is on a distinguished road
Send a message via AIM to Fat Felix
same question!
Not sure if I am remembering correctly.. but didn't the turbo thunderbird's use a t-5 but with a hydro clutch? If that part is true, can you use the bell housing off the t-bird and put it on the t-5 from the mustang? OR just use the t-5 from the t-bird altogether?
megasonly.wordpress.com
Fat Felix is offline   Reply With Quote
Old 08-09-2006, 07:12 PM   #111
ThatGuy
Admin Asshole
ThatGuy's Avatar
Did you even bother to check out www.hinsonsupercars.com to check the prices out?
Old 08-09-2006, 11:54 PM   #112
ledzeppelin240
What would be the advantages of using a 5.0L sbf instead of the 5.7L sbc?
Chevy
-driveablility, fuel injected, all alluminum (light weight), tunability, responds well to mods, 350hp/350tq stock, paired with a 6 speed manual tranny. There are probably some points missing, but the cost of engine and tranny is the downfall. (This is all my opinion...)
I believe anything worth doing is worth doing right and from the research I have done, my choice is the LSx. The cost I have worked out is about $6000 with the Hinson goods, and doing the work myself...So including the price of my car thats $7000 spent, but there is still suspension and a lot of other things that add up.
Old 08-10-2006, 12:31 AM   #113
Fat Felix
initial cost.
Old 08-10-2006, 11:33 AM   #114
Jonas427
Don't be an ass. Yes I checked them out, but I bet there is more involved that just what is listed.
A mod should delete my question and your useless comment, so that this thread doesn't get cluttered.
Old 08-10-2006, 12:12 PM   #115
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
um, he is a mod.
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 08-10-2006, 02:37 PM   #116
ThatGuy
Admin Asshole
ThatGuy's Avatar
Check out the F.A.Q. section on www.hinsonsupercars.com They cover all the Frequently Asked Questions, imagine that.
Why should I delete your questions? Hopefully it will help other people to not ask the same questions and follow the links provided first.
Old 08-10-2006, 03:28 PM   #117
Neejay
Neejay's Avatar
Good job on not replying with flames and/or immature shit.
ThatGuy, what would YOU do as far as chassis stiffening? (Sorry if this was covered prior to this post, I don't remember reading it)
Old 08-10-2006, 04:27 PM   #118
ThatGuy
Admin Asshole
ThatGuy's Avatar
I'm planning on running a custom cage. I'll decide after that's in, what other chassis bracing I feel the car needs. I've almost got the suspension where I'd like it. No sense in dropping in all that power if the car still handles like stock.
Old 08-10-2006, 04:34 PM   #119
shinrekka
shinrekka's Avatar
so what about the release of the 5.0 swap kit
Old 08-10-2006, 05:10 PM   #120
ranger2339
ranger2339's Avatar
Hinson Super Cars
247 McCutcheon Road Phone: (205) 887.5161
Lacey's Spring, AL 35754 E-mail: [email protected]
ORDER FORM
AC & PS $0.00 Date: 8/11/2006
Electrical $610.00
Engine Build $0.00 Customer: Josh Axel
Fuel & Cooling $1,250.00 Triple Six Drift Team
Hydraulics $0.00
Intake & Exhaust $985.00 [email protected]
Performance $0.00
Labor $0.00
Misc. Items $0.00
Motor & Transmission
Mounting Equipment $1,633.30
Nitrous Systems $0.00
Turbo Sys. $0.00
Subtotal $4,478.30
Estimated Car Purchase
Shipping & Handling
Current Balance
Total Balance Due $4,478.30
*Current pricing for June 2006
I got a complete order form from brain hinson, he is very easy to work with..
Here is what i have so far...
I have a spread sheet but dont know how to post it!!
Ax
