#91 |
![]() Join Date: Apr 2004
It doesn't matter how much "better" they design the materials, that part still puts the steering rack into bending when it wasn't designed to handle that(inner tie rods pivot, and it doesn't locate the front spindle at all, so no bending). The rack might handle it for a bit, but I imagine the seals aren't up for that kind of beating.
#92 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
i have a few question just pertaining to basic angles and mods.
So I have a corolla and i have played with angle a little bit. My first setup was some steering rack spacers, stock inners and megan outer. ran great got good angle. and to correct the roll center i used battle version NRCA. so now i have a fresh chassis to play with. I want to get MORE angle by modifying some stock knuckles. MY idea.....? take a stock knuckle off. take a pre measured chunck out. not much. and then heat it with a torch and weld it back together. shortening the knuckle with increase the leverage and gain more angle? so with shortened knuckle length, megan tie rod ends, battle version roll center adjusters, t3 camber plates, and some battle version steering rack spacers, a fresh alignment i should have a good angle setup? in theory should be more then i had before with not having shorten'd knuckles. i dont have to worry about the tie rod hitting the lower control, and i already have my roll center adjusted with the battle version nrca. |
#93 | |
![]() Join Date: Nov 2005
#94 |
Another FYI (sorry i know). I'm using the GP Sports Hyper knuckle right now, and because it spaces the lower control arm and the spindle it added a bit of negative camber. It's likely that during compression the front suspension cambers inward, and by fixing the roll center it's added much negative camber. This could take a toll if your camber plates are out of adjustment which doesn't allow you to run less negative camber. Currently I'm stuck running 1.8' negative camber and out of adjustment.
.25 till 3 |
#95 | ||
#96 | |
![]() Join Date: Jan 2005
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
This also explains why I have seen some of these super low cars running retarded front camber. That would also get the angle below 90. I like changing the pick-up points better, but to each is own. Please keep filling this thread with great info. One thing that I keep thinking about is with suspention set-ups as stiff as have been discussed earlier what kind of compession travel are we talking about? |
#97 |
I can't hit more than 2.3' of negative camber. This is probably due to my shock manufacterer being partially misinformed, but it could be a potential problem for others as well. Another problem that could arise is the shock length. When the knuckle is raised the shock is also compressed. Shocks with a separate perch and preload adjustment will be ok.
.25 till 3 |
#98 |
![]() Join Date: May 2006
i should of started this thread years ago when i was curious about this and wanted to learn more back then.
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
#100 | ||
I know with my 10/8 there was pretty much zero roll, and with my 12/10 there was absolutely no roll. But then again, this was with less-than-grippy tires. Maybe the grip guys running slicks can comment on body roll a little more. But anyway, part of the reason you run a stiff suspension is to reduce camber and toe change with body roll. So with a corrected roll center, this should allow you to run just a little less static camber. I guess it depends on how your strut is angled and how low your car is. Those guys running extended front lower brackets on their coilovers are actually at a disadvantage there; they make the angle greater. Taiwan? Making a knock-off?!?! What?!?!? Hahahaha.
#101 |
The Taiwanese company could have copied a Japanese manufacturer initially; I know I've seen this before. Though, the design would be somewhat similar between manufacturers, the geometry might have changed. Anyway, I would rather have a part made in England rather than in Taiwan... but I guess it could go both ways (a part failing that is).
.25 till 3 |
#103 |
Dang, 695 pounds for all 4... that's about the price of just the GP Sports front knuckles.
Good deal, but who imports their stuff? |
#105 |
They (DriftWorks) cant estimate shipping? I wonder who rhdjapan uses for shipping because their stuff wasnt that bad on shipping charges to be honest. I wouldnt be surprised if they can ship international through USPS for a fair price. I may need to email them about shipping international.
#106 |
![]() Join Date: Nov 2009
yeah but they charge arm and a leg on the product itself. I've bought from rdhjapan before... insane prices on stupid simple stuff just because its jdm... seriously... but they are friendly.
#107 |
![]() Join Date: Jul 2005
I have a friend stationed in the UK, I don't see why he couldn't get the spindles shipped to him, then ship them out through the base USPS and get very reasonable rates on shipping.
![]() Instagram - SJKnoop |
#108 | |
I think what we were trying to get at is to have a more permanent solution to the shipping dilemma for Drift Works stuffs. |
#110 |
![]() Join Date: Mar 2007
![]() ![]() ![]() Feedback Score: 12 reviews
So the basic idea is to try to get all arms parralel with the ground while under load and keeping all arms as even as possible at the same time??
#111 |
Right, a more correct way of saying it might be - preserve the stock suspension geometry as much as possible.
I believe there are improvements that can be made to the stock geometry, but that is much more complicated then just correcting it back to stock. I figure if you make everything adjustable, you can tweak it at the track and get it set up for your own personal preference.
#113 |
No, at most those give 1/3-1/2 inch of adjustment.
The only ones that actually do anything are the top of the line Moonface ones....IMO 1/2 inch of adjustment isn't worth 450 bucks.
#114 | |
yeh they didnt look long enough, like how your setup is. how much do you think your set up cost, just for the roll center adjusters? |
#115 |
Remember, if they space the ball joint UP, then they don't actually do anything. The pivot point has to remain the same, the shank is what is supposed to be taller.
#116 |
Since you have to ream the spindle to accept the shank I am using and weld parts to the LCA, it will have be a LCA + spindle package. I will talk to Danny and let you know. It should be pretty affordable compared to whats out there.
#118 |
That's when you pass the point at which more side-to-side movement moves the knuckle out, and the knuckle comes back in - then you go to turn the other way and the tie rod is stuck. Hard to explain, hopefully that gives you a visual.
#119 |
so for a basic (begginer) roll correction setup on a slammed 240sx you would want inner/outer tie rods, tension rods, and the ruca and rear toe rod?
sorry im a little new to the suspension stuff... |
