01-12-2011, 09:18 PM | #91 |
No sir. The stock injectors will not handle the 18g on the stock wastegate.
I would imagine at least 550's would be recommended for that turbo. Does nobody have this turbo on a KA yet? I havent seen anything. But i want to see the output difference vs the SR just on wastegate pressure. |
01-13-2011, 10:10 AM | #92 |
Hi, Fatboy Garage
Can you explain or list what is needed to connect I/C and Air Filter piping to the turbo? Your website pictures seem to show fabricated pieces connected with couplers..meaning I would need to get fabrication done also? Thanks. |
01-13-2011, 12:29 PM | #93 | |
Riley have After market intake and FMIC kit, so he have a adapter flange to connect the turbo. Thanks Ken,S I will have the picture for the flange later this week for you guys. |
04-25-2011, 12:20 PM | #95 |
Id say an SAFC with 550's but your timing is going to be retardely advanced. Thus why I sold my safc... Now if you have an enthalpy 550 or 740 tune with an safc your base timing will be allright.
BX|Photo LS400 - Slammed | Fitted | Loud |
04-25-2011, 01:06 PM | #97 |
i ran my car on a SAFC and 550's timing was pretty conservative and for what the turbo costs it does its job well.
i have since sold this engine , and this turbo and engine are still working great at the same 15 psi boost level on a SAFC. |
04-26-2011, 12:12 AM | #98 |
Why so u can run 10psi and not even run the t28 in its effeciency zone? Either route you go your gonna need supporting mods.
04-27-2011, 12:48 PM | #99 |
cool this is what i wanted to hear, i have 550's, i was going to get and intake manifold but ima keep the stock one. but the turbo is on the way and i cant wait!
05-01-2011, 08:32 PM | #100 |
Well here are my initial findings.
1. It hits the stock mounts so I need to shave them a bit. 2. The wastegate is super tight.
05-02-2011, 04:12 PM | #105 |
I got it when it first came out.
A bunch of track events, and it hasn't given me any problem, so no complaints on my end. Install on a s13sr is pretty much the same as installing a t28. This will be the setup I am going to run at Allstarbash if I drive.
05-02-2011, 06:32 PM | #106 | |
Thanks!! Ken,S |
05-02-2011, 06:51 PM | #107 |
Just got mine, very impressed with it, think I may run my hks actuator on it, I will post my dyno chart when it gets tune. Too bad is fd week and I will have to wait.
05-02-2011, 07:31 PM | #109 |
HKS actuators are adjustable (as are the ones that come supplied by godspeed with the turbo). A t25 one will not fit. Didn't have a t28 one on hand to test it out or not...
05-02-2011, 09:39 PM | #112 | |
Also how do I adjust the wastegate so that the minimum boost is no more than 10psi.
05-02-2011, 10:15 PM | #113 |
Td05 18g at 16.5psi
550cc injectors z32maf apexi super suction intake 3" exhaust from turbo back fmic enthalpy tune 91octane No idea how much power there is yet. I'll post up one I dyno it and see how much I can mess with the timing/boost. As for install stuff, I have flange adapters so I can use a coupler to mount my intake pipe and hot pipe, DIF lines, and a flange to barb adapter for the oil return.
05-03-2011, 03:38 PM | #114 | |
05-10-2011, 10:55 AM | #120 |
It bolts onto a stock mani like a t28 would. So if you have an s13 SR your gonna need lines and a reclock kit to use your piping.
