![]() Join Date: Aug 2013
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
![]() Hey guys,
Been studying this set up and other on other forums and have just ordered this set up. I was originally going to go with the Chase Bays kit, but it I had been waiting for it since August. ![]() ![]() So I made my own. Here's the parts list and my "diagram": Total Cost from ANPlumbing.com - $142.00 Shipped ![]() ![]() I just placed the order and have not install it yet, but I just wanted to say thanks to every one in this thread. One benefit to this system is no welding skills are required. I hope to post a install and long term update. Stay tuned! PS: If anyone see's anything wrong that wouldn't allow this to work; please PM or comment.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
#2 | |
Try it out but you might have to ditch the washers on the rack and machine the fittings so you get the proper seal at the o-ring. Good luck.
S12 || KN13 || S13 || B16 |
#3 | |
![]() Join Date: Sep 2010
From what I can tell from reading this whole thing, NO. U have to machine down the fitting because the hex head is too thick making the shank of the fitting to short and not allowing the oring to mate with the sealing surface of the rack
#5 |
#6 |
![]() Well, fuck. I read that but somehow thought that it was fittings from another supplier that had the issues and earls worked fine. Guess I'll find some to machine these down...
#8 |
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
Ill just add this for those who want to make a full AN power steering set up for half the price. You will need a know someone with a TIG welder, you may be able to get away with a MIG.
First off, take off your PS hardlines from the rack. ![]() Next, take a cutting wheel or angle grinder and cut off the ends of the hardline like so. Make sure you have an inch or more at the end of the tube and nut. Clean the shavings that would be in between the tube and outside with sand paper. You will have to clean the tube till its flat and raw material because its going to get welded later. I sanded till the tube easily fell out the nut. ![]() Next purchase x2 "STEEL" AN-6 weld-on Bungs and take it to your welder. This can be done with a MIG welder as it is steel. They should cost $2 each, which is a mere 5% of what you would pay for the 2 AN adapters which would probably leak on you. Have your welder weld the bung to the tube from the outside. Make sure you take off the plastic o-rings on the nut before you weld them, they will melt on there. ![]() Now you have a power steering rack AN adapter that is OEM reliable. This is 95% of why PS systems leak.. because the AN Adapter being to short inside the rack. I wish i had a pic to compare my OEM AN adapter vs a AN adapter but I can guarantee the AN is half as short. ![]() After that you got the hard part done, you just need to get the high pressure line made, feed line, and reservoir. For Pump feed adapter, you can : 1. Go with OP and purchase - Pump High Pressure 16x1.5 Crush Washer -6AN 9919DFJERL or 2. purchase another Steel AN-6 Bung and have your welder weld on the high pressure feed side. The Reservoir leaves you with 2 choices: 1. Purchase a new PS reservoir like I did. eBay $27 ![]() or 2. Purchase x2 AN-6 Aluminum weld-on bungs and x1 AN-10 Aluminum weld-on bungs and follow the method done by OP. This will require you to have someone with a TIG welder. This will leave you with just the AN-10 line to purchase. The oil feed port : 1. If you have a TIG welder, follow OPs method. 2. If you do not have a TIG welder, purchase a AN-10 Female to Barb fitting for the aluminum reservoir above. Then just use the original rubber feed hose, its just a feed line so no need for it to be AN fitted. Hoses : For the High pressure hose, in most cities, there should be a hose shop around your neighborhood that makes these sort of line. In Socal, we have HoseMan all over. Just go in and have them make you a AN-6 to AN-6 High pressure line in steel braided material. This should cost around $40. The return hose from rack to reservoir. Look online like forum and eBay, you just need about 2 feet long, its a -6AN to -6AN. Return hose does not need to be high pressure, regular kevlar braided is fine. Oil feed line, its a AN10 to AN10, again look online. This one is super cheap because its a oil return line for turbos. Hope this helps |
#9 |
Power steering+AN Lines
Thanks man, pictures explain it all better. Only difference is the ones i've done have the tubes flared into a chamfer that's made into the fitting at the hex side to secure i to the fitting,then both ends are filled flat and welded toghether with two passes. And yes MIG works if done correctly. The ps resevoir on mine was relocated on a bracket by the radiator L/H side with fittings welded to it, gets it away from the exhaust manifolds and this all fixes the pump feed line leaking problems that these cars develop enventually with all new teflon braided ss hoses. Oh by the way I forgot to say that mine was also relocated to the a/c compressor area to give space for turbo piping "up there"
#10 |
Have you operated on this rack yet? My friends on Nissan Road Racing say that the weld-on bungs do NOT work and will blow the rack for some odd reason. The only person I know on here that has done the weld on bungs, besides you of course, is Ninocrack and he has not run his car yet.
#11 | |
![]() Quote:
#12 | |
#13 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
The way PeaceOnesxWai is actually pretty slick, and I kick myself for not thinking of doing it that way myself.
...i'm no engineer, I'm a slop!
#14 |
![]() Join Date: May 2010
![]() Feedback Score: 21 reviews
Peace (or anyone else)- Why didnt you run a PS cooler on your setup after removing the factory hardline "cooling loop"? Is it neccessary to run one, or are the chances of boiling the fluid low?
#15 | |
SMALL UPDATE: I haven't installed it yet, but the "Econo-Fits" for the PS lines, to small to fit around the hose that it claims. Shitty.
#16 | ||
Trader Rating: (34)
Woah havent been in this thread for awhile now..
![]() I chose to do the weld-on cause 1. its realiable and 2. its cheap. Quote:
Specify "cancel the pressure restriction"? Like removing the banjo bolt and adding AN fittings? |
#21 |
#23 |
I don't check old posts, but ya, looks good. Looks similar to an LS swap PS line I've seen before and being that your pan looked like a sikky pan, I just assumed...
#24 |
![]() Join Date: Feb 2012
I hurd Z33 PS cooler is pretty much a bolt in affair. Anyone have more info on this?
ACE マジック HEART |
#25 |
IDK what you mean by bolt on affair. It looks like any el cheapo shitty cooler you can buy at like vato zone and napa. I bought a cheap aluminum finned afco one from speedway. Easy peasy.
#28 |
![]() Join Date: Mar 2008
![]() Feedback Score: 8 reviews
Might be resurrecting a dead question but I've noticed my power steering isn't necessarily the quickest anymore since AN lines and cooler.
Once I'm rolling everything is fine, but if I try to make a really sharp movement I feel a very slight bit of restriction and than everything is smooth. When the car is idle it's hard as shit to turn sometimes. Any solutions or ideas to this?
IG: @vsMARTINO |
#29 | |
![]() Join Date: Nov 2005
Are you still running the banjo bolt and cast outlet on your pump? That has a built in restrictor that you may need to remove with a decent size cooler. There are -6 adapters for that if you need ALL the flow, or restrictors of various sizes. You basically have to experiment haha. For everyone else: I've been using a standard steel adapter fitting in my high pressure side with no leaks for a while now. No sealant, just tightened it good and tight...
#30 |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Sorry to bump an old thread...
I have the ISIS ps kit and my fitting on the rack leaks. I've looked through this thread and cant find an exact link to the fitting i need to go into the rack. this is the fitting in question: ![]() will this fitting work? : http://www.jegs.com/i/Earl%26%23039%...91954/10002/-1 if not can someone please link me to the fitting I need. Thanks
s14 kouki ka-t |
