#2 | |
95 240sx RB20 415whp 91 Nx2000 VVL yo |
#3 | |
Overall since your going with Haltech which should have onboard RPM switching capabilities you wouldn't need an separate RPM switch. |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Question about rom tune: Currently have enthalpy. I know the major changes in a rom tune are injectors and maf.
With the VE head having such a different cam profile and duration, should we get the ecu retuned? If yes, then will he be able to figure out when the cam changes or is the maf enough to compensate?
http://essencegarage.wordpress.com/ |
#5 | |
#6 |
If he is using a Haltech that has VTEC capabilities, he doesn't need an RPM switch. Just wire in your solenoids to the spare DPO's.
#8 |
To add to what Ground is saying, the S14/15 ECU only has one switch output/input on the ECU so you're stuck switching both cams at the same time. Now that isn't a huge disadvantage, but to get the most out of the system on a P11 head, you'd want to switch cams at separate times. The P12 head used one solenoid to switch both cams at the same time, but their cams have a completely different profile than the P11's.
Haltech has the ability to switch both cams separate from each other. I'm running a Ps2000 on my setup and plan to find the best combination for the switch point.
#10 |
^^ Very nice! I was initially going exactly this route with an HX40 and Xcessive intake manifold. But decided to keep it nice simple and clean. So I stayed bottom Mount. Nothing fancy myself. Below is the preview for whats to come for my VET build..
#12 |
No sir.. I was just mocking things debating to go top mount or bottom. For now ive decided to stay bottom to expedite build by reusing available parts and focus more on head and bottom end parts. I could easily upgrade later should I wanted more. Target goal with 20g bottom mount and high compression motor is at around 400-500whp running e85.
#13 | |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
https://instagram.com/eck_matthew/ |
#14 |
Banned from the Marketplace
#16 |
If for any reason you guys use the OEM throttle body from the P11 motors make sure to take out the butter fly screws and put lock tight on them.
#17 |
![]() Join Date: Jul 2008
![]() Feedback Score: 11 reviews
I feel like there is a TON of info scattered all over the internet about this swap. I'm talking about specs in the FSM. I joined multiple forums and clicked sketchy links on sites like rapidshare, etc. lol
I have uploaded what I found, and I also have the P11 SR20VE FSM in a PDF. Unfortunately, it is not translated and looked like someone had scanned it at home. If you want it, just send me a PM with your email. Anyway, here are some things I have found. May not help some guys out, but it did for me when I was looking for specs for valve clearances. http://s144.photobucket.com/user/ram...E%20FSM%20Info For example, ![]() |
#18 |
![]() Join Date: Apr 2004
This is my setup. You have to trim the inside of the p11 valve cover to clear the taarks Hall effect pickup. I'm running an Autronic sm2 for my EMS. The taarks setup is designed for the haltech EMS's. I am having a custom plenum made currently for much setup. I'll post pics and the builder after I get it and see the quality.
#19 |
![]() Join Date: Oct 2007
Whats that turbo size ? Power goal ? Looking good
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#20 |
Yes retune for sure ! Enthalply knows how to tune the vvl just call them
I saw a couple videos from cars they tuned and its rom tune
#21 |
Looks good Dave, thanks for your help on NRR.
Latest and greatest. ![]()
#23 |
Nagisa ou nagasi if im not mistaking
#24 |
They are Nagisa Shakitto plates.
#25 |
Sure thing Jr. Also you may wanna add a secondary check valve to your valve cover breather on the left side. Under boost that one could easily push some boost into your engines breather system.
I do love the taarks Hall effect setup. I do know that the sensor they use is sometimes dodgy, but it's a cheap one to have an extra sitting around. Also the turbo I have is a Borg Warner S360sx with a t4 .82 common tangential exhaust housing. My goal is 500whp. The bottom end has pistons and rods with a full refresh. The manifold I bought second hand and it needed a spacer to move the turbo away from the head, but for $150 it's hard to beats. |
#26 |
Jr. why you decided to keep the pcv valve ? I wanted to put a catch can fitting from there
#28 |
No particular reason why I left it. It was there, it works from the factory, why not reinstall it? However, Dave made a good point that I could potentially pressurize my crankcase through the small check valve there, so I may eliminate it altogether.
As it sits, I'm pulling some serious vacuum on the CC with my catch-can setup. I need to put a gauge on it to see just how much vacuum, as I don't want an extreme amount. I'm looking for 5-7in/hg or so.
