Old 08-08-2004, 03:09 PM   #91
Ian
Ian is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfectionIan is close to perfection
AKA is right...the offsets he chose are gonna ride alot better then the super low offset (includign me to some extent...17x8 up front w/ +9 offset) AND they were 400 bucks so HA
but yeah...steering is gonna be close to stock w/ his car and the drawbacks from the "not as wide" wheel base are gonna be nominal...i'm just such a slave to looks that i had to have low offsets
Ian is offline   Reply With Quote
Old 08-08-2004, 11:36 PM   #92
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Originally Posted by dmora79
what offsets are those?
:edit:
nevermind, i found em....
Seriously you guys are some hard asses.
Im sure the had the same problems i am currently having in trying to research appropriate offsets.
I get such wide variation and everyone saying "USE THE SEARCH" And again comming up with nothing consistent.
I think The ones pictured of "nitekids" are too wide, on top of the fact that NO ONE is using appropriate sized tires. On a 10" wide wheel you should be using 275~295s. From what people are posting it sounds like you are using 225s on rediculously wide wheels.
Thats simply absurd.
I want to have 18x9s all around and hope to fit 265s all around. Even still, those will be my bling wheels and i'll use my R33 GTR wheels for track events.
We have our reasons, with 265s you won't drift very well. You should be able to get close to the right offsets if you try hard enough. You guys are expecting someone to have your exact setup, well thats not gonna happen, you have to think for yourself sometimes, if thats asking too much then just be like the post starter and ask the company you are buying them from and get bad reccomendations.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 08-09-2004, 03:13 PM   #93
Crab Spirits
Crab Spirits is an unknown quantity at this point
Send a message via AIM to Crab Spirits
"On a 10" wide wheel you should be using 275~295s. From what people are posting it sounds like you are using 225s on rediculously wide wheels.
Thats simply absurd."
Why?
And why not try to understand how to properly choose offsets and width for your intents and puposes before even copying what someone else has? Seriously, it is not that hard. It is SIMPLE geometry. Take wheels off your car and do some measuring.
JDM fun
Crab Spirits is offline   Reply With Quote
Old 08-09-2004, 10:45 PM   #94
AAA240SX
AAA240SX's Avatar
AAA240SX is an unknown quantity at this point
When "Search," is applied as advice it doesn't necessarily mean for someone to be dependent on this forum's past threads. since every1 here posts setups that are doing well for THEIR project, you will never know what is right for you.
it all depends on your goals for the vehicle (show, strip, autox). there is no real answer to be found here on the forum. just friendly (sometimes) advise and input through past experiences; especially from those that have been in this game longer than others.
to find YOUR perfect setup: determine your goal for the project, read actual chassis engineering/suspension engineering & dynamics material, and use that knowledge to measure out what's really good 4 u. like those new caramel kisses from hersheys (DOPE SHIZNAZIT!)
-John
93 240SX FOR SALE!!!!!
AAA240SX is offline   Reply With Quote
Old 08-11-2004, 02:32 PM   #95
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
Originally Posted by VEX240
They are 18x8.5 +43 and 18x9.5 +35. Yeah I know its not enough now. When I asked what offsets to get for the sizes without having to pull the fenders. Well I got told to make the car fit the wheel and go bigger and flamed. I tried searching a little but dont have time to look over page after page of offest post. So I went with what SSR recomended. I'll just get spacers to make them more flush.
I am dealing with the same bullcrap now in my thread. "You know all this is 'easily' found on the internet", "call the wheel company and see what they say", "go look at pics, you can tell if they rolled or pulled the fenders", etc...
I guess if you are just buying $50 wheel sets you can play a bit....right?
I am debating a 17x8 +30mm up front and 17x9 +24mm out back....I don't know if 17x9 +24mm will work on all 4 corners without really stretching the front tires and it's obvious the backs will be sunk in more.
I think 1 17x8 +30mm upfront may be a little too far outside as well. I can't find a good shot of them at the right angle to tell.
alkemyst is offline   Reply With Quote
Old 11-09-2004, 07:32 PM   #96
supportTHEezln
supportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud of
Send a message via AIM to supportTHEezln
The rims are cool, I dig 'em.
supportTHEezln is offline   Reply With Quote
Old 11-09-2004, 07:53 PM   #97
s14falcon
s14falcon is an unknown quantity at this point
Can i slap you in the face for bringing up a pointless thread to say a pointless remark?
s14falcon is offline   Reply With Quote
Old 11-09-2004, 09:54 PM   #98
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
I'm just sittin here reading all this eating a noodle bowl and smoking a cigarette, thinking I am Japanese (for the record I'm not) anyhow about this thread. It's cool, I think if he posted here and asked what do you think, then he's getting what he asked for. I like the rims but they are just a little to sunk in. I'm not a big fan of stretched tires, but it looks cool as hell. Anyhow your car dude, hope your happy with it. nice rims though.
driftyour40 is offline   Reply With Quote
