Old 11-14-2015, 01:01 PM   #1171
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Originally Posted by godrifttoday View Post
do you know where i can purchase termial pins for nissan 240sx ecus?
I would check with Wiring Specialities or Chase Bays
Originally Posted by S13stockness View Post
I have a 93 240sx. It has some cheap aftermarket Sony head unit. I want to put in a double din stereo with removable faceplate. I think a friend of mine had a JVC unit that had the detachable face. Could you recommend a HU for me along with a set of front and rear speakers. Maybe you can do a bundle deal so I can buy it from you
Send me a PM with vehicle info i.e hatch, coupe etc.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 01-02-2016, 04:03 PM   #1172
Razi
Razi is an unknown quantity at this point
Hey Broadfield,
I'm getting noise whenever my AEM wideband is turned on. I moved all my grounds to a spot on the dash support, to the left of the A/C unit. Thankfully this fixed the noise I had when I used the AUX and phone charger at the same time. But I still get a high pitched whine through the speakers when the wideband is turned on. This happens even with the headunit off, and the key in the off position.
All my AEM has for wires are for power, ground, and 2 wires for ECU logging.
I've jumped both the power and negative to the battery, and I still get that whine. I'm so confused.
Have you ever come across a problem like this?
Thanks!
Razi is offline   Reply With Quote
Old 01-02-2016, 06:46 PM   #1173
exitspeed
aWingThing.com
exitspeed's Avatar
How do you feel about the Pack going past the first round of the playoffs? Still can't believe we lost to the Bears. On a scale of 1-10 how bad do you want Cutler gone?
Old 06-28-2016, 08:33 PM   #1174
chandler_bing
chandler_bing is an unknown quantity at this point
Hey Broadfield,
What is your method for pulling speaker wires through the front doors of an s13? Also, where's the best spot to run the power wire for an amplifier?
chandler_bing is offline   Reply With Quote
Old 06-29-2016, 01:44 PM   #1175
chandler_bing
Hello,
What do you recommend to use to pull speaker wire through the front doors on an s13 and to run amp power wire through the firewall?
Old 07-11-2016, 04:53 PM   #1176
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
Any body know what's up with Toby? I've been trying to get a hold of him for two weeks now....
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 07-02-2017, 12:05 PM   #1177
relix oner
relix oner is an unknown quantity at this point
SUBWOOFERs in my 240 hatch
i want to put a subwoofer in my hatch. something that sounds clear and can get loud. while saving the most trunk space possible. Any really awesome shallow mounts subs you would reccomend? im ok with a 10" or a 12"...budget under $500 for the sub
relix oner is offline   Reply With Quote
Old 07-02-2017, 12:20 PM   #1178
kingJurzy
kingJurzy is an unknown quantity at this point
I had a 12 that needed the airspace of a 10. Hit all the point you talked about. Stereo Integrity BM mkIV
kingJurzy is offline   Reply With Quote
broadfield, toby
