Old 10-20-2019, 01:22 PM   #1171
Yellow4g63
Did u drive it yet? Putting load on it will make the temps go up vs idle.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 10-20-2019, 03:03 PM   #1172
wurley
wurley's Avatar
wurley is an unknown quantity at this point
with the same setup, clutch fan +nismo thermostat, I dont see over 160 when im just idling
WTB: FRONT S14 SILVIA Q'S SEATS purple zebra *still, been looking 8 yrs*
wurley is offline   Reply With Quote
Old 10-20-2019, 06:08 PM   #1173
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
I drove it for the first time last weekend to my brothers house a few blocks away and it stayed at that temperature. I did not want to drive it too far in case something went wrong lol. I asked because it is running rich at idle (10.2 ) I thought maybe its running too cool with the Nismo thermostat and maybe had to put in an OEM thermostat. I am guessing the current base tune needs to be adjusted and leaned out a bit at idle.
kojiki88 is offline   Reply With Quote
Old 10-20-2019, 06:50 PM   #1174
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
160 is way too cold. 185 -205 is the proper temp range for the engine to function properly. When pil, piston rings, etc. Is too cold, you introduce friction or just oil not properly lubricating
Dump the nismo. That's a bandaid for people who have a shit running car
Old 11-10-2019, 07:14 PM   #1175
S13VE
S13VE is an unknown quantity at this point
Dyno'd yet?
Work on mine is just about to begin finally
S13VE is offline   Reply With Quote
Old 11-10-2019, 09:08 PM   #1176
RalliartRsX
Trader Rating: (32)
Unfortunately, nothing too significant to report back.
14 psi made slightly less than 300WHP on a heart breaker. The IWG75 single port wouldn't take any duty cycle so we were stuck @ 14. Also had a phantom cam sync error @ 7k
Apart from that, considering how this all started, I can say it went well. Already installed a twin port gate and am awaiting a properly designed (that is not 1200 like the mazworx kit) crank trigger kit that doesn't push out the PS pump.
Car runs really good and is a freaking riot! Been slowly buttoning up things (reinstalling interior, splash shields, radio, speakers, etc etc). JK41 shifts nice and firm. Overall, really happy with how it turned out.
May try and make a few boost runs tomorrow to see if the gate is working as it should. Took it out a few hours ago after I did a home alignment to check things over.
Glad I went VET! The sound and spool is intoxicating
Old 11-11-2019, 01:16 PM   #1177
S13VE
Not even a single video clip....
Old 11-11-2019, 07:00 PM   #1178
jr_ss
Wait until you turn the wick up... 3rd gear tailwag is intoxicating.
Old 11-16-2019, 02:18 PM   #1179
DoingOK
DoingOK is an unknown quantity at this point
Looking for some help with a SR20DET build please. After scouring the internet for hours, it seems that there is no specific numbering sequence that would help place the cam caps in the correct order. These caps were already removed and in a bag so I don't have the correct reference as to what order they go in. The last one with the oiling port is obvious as to its' placement and it looks like there are dimples punched in three out of four caps. It would be a guess as to where these fall in line. Any help or recommendations? Thanks in advance.
Hmmmm.....won't let me attach a pic.
DoingOK is offline   Reply With Quote
Old 11-16-2019, 04:09 PM   #1180
RalliartRsX
Trader Rating: (32)
All the cam caps are lettered (I for intake), marked with an arrow for direction and numbered on every single VE head.
Are you sure you have the correct caps?
Old 11-20-2019, 07:56 AM   #1181
PRT73
PRT73 is an unknown quantity at this point
stock cams will be fine. if you really feel like spending money in that area
https://www.mazworx.com/store/p/370-...shaft-Set.aspx
hello , when you say stock cams, is it p11 sr20ve or sr16ve? Because I have sr20ve
thanks you !!
PRT73 is offline   Reply With Quote
Old 11-20-2019, 08:35 AM   #1182
RalliartRsX
Trader Rating: (32)
P11 SR20VE cams is what he is referring to
Old 11-20-2019, 11:22 AM   #1183
SidewaySSS
SidewaySSS is an unknown quantity at this point
Has anyone on here used N1 cams on a turbo setup, if so, what are the drawbacks?
SidewaySSS is offline   Reply With Quote
Old 11-20-2019, 11:53 AM   #1184
RalliartRsX
Trader Rating: (32)
^^^^None??
Old 11-20-2019, 01:10 PM   #1185
S13VE
I went Kelford, I have upgraded everything else in the head already and have had good experience with them in the past by simply telling them what my goal was, turbo choice etc etc.
On my old 34R, the dyno result was exactly within the range they had said to expect.
Old 11-24-2019, 09:47 AM   #1186
Def
I did. No drawbacks. Triggered VVL at about 3800 RPM. Pulled hard as high as I dared rev it (saw a little over 8k a few times, I'm sure it'd still pull at 8600-8800).
This was with an EFR 7163 twin scroll.
The N1 cams are similar to a stock F20C/F22C cam profile (S2000), and those things love boost too.
Honestly, with the N1s, you need a pretty big turbo. A 7163 is the smallest I'd go with. In the EFR world, I wondered what a 7670 would do. Probably still pretty strong response and even more nuts top end. That said, even the 7163 made so much power it was getting a little hard to manage at ~18 psi+(1.2 bar+).
The sound on the big cam is worth the N1s alone.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 11-24-2019, 09:51 AM   #1187
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
Wondering now if I should stick with my p12s or get a set of N1s for my own 7163 setup. Any chance you have a graph with the n1s? I’d love to see the curve
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 11-24-2019, 11:12 AM   #1188
peglio
peglio's Avatar
peglio is an unknown quantity at this point
I have custom cams very similar profile to the n1 and an efr7670 going on mine , will post up the results when it’s mapped in the new year [emoji1360] hopefully should still be pretty responsive
Sent from Big Bear Kustoms Ltd
peglio is offline   Reply With Quote
Old 11-24-2019, 11:25 AM   #1189
RalliartRsX
Trader Rating: (32)
Update: Sold the ECU and upgrading to the latest ECU Master Black (if anyone has one for sale before I plunk down in the next 2 days. Just waiting on black friday deals)
Old 11-24-2019, 01:57 PM   #1190
Def
I never dyno'd the car. turtl631 owns it now, when he gets it back up and running maybe he'll dyno it.
The calculated mass airflow never flatlined at the revs I was bringing it to, so even if friction was rising, it probably was still making more power with more revs.
DEFSPORT
Old 11-24-2019, 01:58 PM   #1191
Def
P12s are pretty close to N1s on the high cam. Not quite as aggressive, but should be fine.
Honestly, I would change if you can do basically an even trade for them, but if you have to put up decent money I'd keep the P12s.
Don't get caught up in building "the best" - just build something you like and drive it.
DEFSPORT
Old 12-01-2019, 01:22 PM   #1192
PRT73
Hello everyone, I'm on the construction of my SR22VET, I need a new oil pump for my assembly, I discovered on ebay a cheap oil pump to 70 dollars. the price seems super low it makes you want to buy. But it's Chinese shit or someone here has already tried?
https://www.ebay.fr/itm/Brand-New-Ni...YAAOSw0BtbwBZ2
Thank you
Old 12-01-2019, 02:30 PM   #1193
S13VE
Thank you
Don't you dare.
Buy it from a reputable seller, not worth taking a risk on. My genuine one was less than $300 AUD if that helps.
Old 12-02-2019, 04:10 AM   #1194
PRT73
ok i will try to find close to home, or if someone sells a new one in second hands
Old 12-02-2019, 01:21 PM   #1195
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
buy this, then have the oil pump gears WPC treated
https://www.efisolutions.com.au/oil-pump-p11-n14
Old 12-06-2019, 05:05 PM   #1196
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
Rb26kouki is an unknown quantity at this point
Feedback Score: 63 reviews
what kit is everyone using for cam signal ?
i only see 2 aftermarket options taarks & mazworx which maz has 3 different options.
Rb26kouki is offline   Reply With Quote
Old 12-06-2019, 06:31 PM   #1197
RalliartRsX
Trader Rating: (32)
taarls has 3 different options, not mazworx. The trigger wheel is similar between taarks and maz.
The 2 other options are home signals for when you are utilizing a crank signal.
Which you use heavily depends on the granualirty you seek as well as simply down to the ECUs ability t properly interpret the signals without a falls register.
The most ideal situation is utilizing a ATI trigger wheel on the shell (you can order them from ATI mind you), a 12 tooth trigger wheel conjunction with a cam home signal for TDC. All shielded wire ofcourse.
Maz makes a complete crank/cam trigger kit. However it is a 60-2 wheel which a fair amount of the older ecus are unable to properly decode
Ross machine produces a similar crank trigger to Maz
Taarks produces a crank trigger which is bolted between the PS and AC drive portion of the ATI damper and with this, spacers the PS pulley out 10mm
Engineered to slide produces their/his own proprietary crank trigger solution
Another NZ company produces a crank trigger which is mounted behind the flywheel
Most modern day ecus are able to only utilize with cam trigger option without false reading and with out requiring a crank trigger ki
Old 01-15-2020, 06:58 AM   #1198
PRT73
Hello, happy new year to everyone !!! I was wondering, who has the most reliable sr20vet in the forum? to see a little
Old 01-15-2020, 08:23 AM   #1199
brndck
brndck's Avatar
hell do any of us even have a running one???
the most reliable one would probably be a bone stock one, still in a xtrail
what I really wanna know is what kind of refresh/teardown schedule is Gocha following
[YT]www.youtube.com/watch?v=eh8USRB9Pf4[YT]
http://www.speedhunters.com/2019/08/...k-up-the-dmec/
Old 01-15-2020, 09:23 AM   #1200
PRT73
Gotcha seems to be driving well, who built his engine for him? in my opinion he does it every year ��
