01-27-2009, 08:25 PM | #1261 |
so this a motor my boss built but i did all the wiring. it uses an electromotive Tec GT system.
the wiring is not completely done since im not sure which chassis it will go into. engine is a US F3 VW motor. with a turbo diesel, long stroke, crank and max bore of almost 85mm it almost a 2200cc pay attention to the little details like the front main seal/dry sump hanger and ITB's dual ignition wheel pickups. one on the front of the crank and one in the crankcase on the back of the crank. oh btw who wants a big turbo...or a motor along with it? lol its a judd racing/truesports indy 500 turbo v8. 2600cc i think. thats the wheel minor size on a 1.39 A/R turbine housing!!!! just for reference... massive garrett turbo vs. tiny garrett turbo T25
I build air pumps! |
01-27-2009, 08:37 PM | #1262 |
Lol @ the size of those collectors... 2" primaries on a 2.6L v8 motor? I love that shit.
01-27-2009, 08:42 PM | #1263 | |
this works on the same concept. they want equal length headers and to allow good packaging so they throw on huge long pipes.
01-28-2009, 06:56 AM | #1266 |
It's a Judd V8 from an F3000 if I remember correctly.
4sfed180, Those engines are awesome! Did you guys make the front cover on the F3 motor? You got some nice stuff there. They used to run the largest turbines on indy cars. |
01-28-2009, 08:21 AM | #1268 | |
the F3000 motor was a Judd BV engine. the one my boss has is an older Judd AV engine. it was used in CART racing by Bobby Rahal. to make it clear. THIS motor was used by bobby rahal. lol. im pretty sure its a 2600cc but not sure. i cant seem to find engine regulations for the late 1980 CART engines.
01-28-2009, 05:07 PM | #1269 |
anybody have any good instructional MIG and TIG videos i should watch? my teacher sucks cock and doesnt really weld to well and doesnt teach really but i cant get TIG down at all. MIG im not to bad at but could definately use improvement.
01-28-2009, 06:02 PM | #1270 |
find someone decent that is willing to show you the basics and after that its all about practice practice practice.
01-28-2009, 06:13 PM | #1271 |
thats the problem right now. outside of school i dont know anyone with a welder. i just need to learn some basic technique so when i go back to school on monday i can practice. tig i was basically blowing through stuff today and mig i can get down pretty good it just doesnt look like that stack of dimes layed down..
01-28-2009, 06:20 PM | #1272 |
trust me it will be a while till you can "lay bead" when you weld. what TIG welder are you using. if you are burning through thr metal you need to reduce the power of the welder. probably the most important thing is to get the feel for the pedal and power youre providing. there are way too many variables to control if no one is giving you some pointers.
01-28-2009, 06:40 PM | #1273 |
miller, not sure on the model, but it does stick/mig/tig. right now material we are using is 1/8" steel. set on lift arc tig, 125amps, 2% tungsten and 100% argon ~ 25psi and brass or copper filler (i forget which it is). the power setting he gave to us. but i layed one decent weld down but the next two i made some deep ass craters. i didnt blow through but it definately seemed to hot.
01-28-2009, 09:50 PM | #1274 |
there are some instructional vids on my website.
Blu808 - Performance Engineering and Innovation site is not done yet, but check it out.
01-28-2009, 10:34 PM | #1275 |
I posted this in another thread, but I wanted you guys to see how a proper fuel system should be setup. Most people just add a fuel cell, and an external pump. This is wrong. You will still get fuel starvation in hard corners. The proper way is to use a fuel surge tank canister. You can find them here.
Manji Parts : Home Here is a complete road race fuel setup i did over the past few days. First thing is to Take the Canister which is a 10" long piece of stainless tubing with laser cut end pieces welded on, and get it ready for mock up. Then find a good mounting location, and mock up the lines. Notice we are using aluminum -6 hard line. -6 is larger than stock, and will be adequate to about 450 whp. Then we started making the fuel lines. Here is the feed line with the 10 micron cleanable pre pump fuel filter. Next we mounted the low pressure lift pump into the fuel system cage, and bent up the hard lines. Since the fuel feed line, and AST were mocked up I decided to get the main high pressure pump ready to mount. Here it is a 255 lph external pump. Since it came with an odd sized threaded nipple fitting a conventional -6 A/N fitting was not available. So i had to fabricate both together. Then I mounted the pump to the fuel system cage and bent up the feed line from the AST. Now that we had the main feed system mocked up I took the AST can out to weld the fittings on and drill the holes. With that all tigged up I reinstalled it, and confirmed fitment. After that was looking all pro I made the sending and return lines. If that isn't a gangster fuel system, then i don't know what is. You could drive this car on its roof and still get fuel to the engine.
01-29-2009, 01:14 AM | #1277 |
Hahaha awesome Luke! Hardlines are always a pain, but those look super pro. Pics of your flare tool?
01-29-2009, 01:17 AM | #1278 | |
Practice is the best thing though.
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage 95 base - retired |
01-29-2009, 01:33 AM | #1280 |
Thanks guys. Wait till you see the fuel system in my 1000 whp fc
I am saving up over the next few months just for all the fittings. Dual -12 lines dual pumps dual AST 100 lb injectors ect.
01-29-2009, 06:31 PM | #1282 |
To blue 808, most people in Aus use surge tanks, and your system is pretty pro, but there are a few guys in Aus that have made their own, and are so decent.
I cant take credit for these pics, here is a duel fuel cell setup, for running race fuel and normal fuel and here is a colour coded fuel setup, very very cool Idea, and looks neat |
01-30-2009, 07:50 AM | #1283 | |
Jordan, Summit has an AN- 37 degree flare tool setup to use with the aluminum hardlines. Cazman, that is a sick setup. I like that distribution block. |
01-30-2009, 08:32 PM | #1284 |
Thanks Bill!
Here is a breather setup we fabbed up today. Another update. Today I made the breather system for the car. Since the stock breather system sucks on these cars here is what I did. Took the valve cover. Then tig welded a -8 fitting on the rear of the valve cover, and a -10 onto the stock location. Then fitted a -8 fitting on the filter base, and attached the fittings onto the catch can. Then started to make the lines. The -10 male fitting in the stock location has a 90 deg -10 push lock fitting attached. Then -10 push lock hose goes from there down to the oem crank case breather tube. The -8 that is welded onto the top of the valve cover attaches to a -8 90deg fitting that attaches via stainless line to the catch can. I have also modified the baffling on the inside of the valve cover, and will try and get some pics tomorrow. Let me know what you guys think.
01-30-2009, 08:36 PM | #1285 |
Pics of baffling! I will be doing this soon, if you and Carlos say it works so well.
Here's me, on your nuts.
01-30-2009, 10:47 PM | #1288 |
I agree with you, I hate SS lines. I tried using the nylon braided lines a while back, i'll never use SS lines again. I always try to persuade customers to pay extra for the nylon lines to make my life easier. The nylon stuff is 100x easier to work with. Black looks cleaner too.
R34 NEO POWER |
