#1291 |
![]() Join Date: Jul 2009
with a proper length driveshaft you have plenty of room to maneuver if you get the correct measurements to a quality manufacturer like shaftmasters
#1292 |
![]() Join Date: Sep 2010
![]() Feedback Score: 11 reviews
I got my ds made here locally. It's just a steel 1 piece, and I'm using the stock s13 open diff. All I did was just measure from the rear seal of the tranny, to the diff where the ds bolts up, subtracted an inch for slip, and they had it done it 2 days and only cost $230. Fits perfectly!!!!
Follow me on Ig- Andydennington |
#1293 | |
Banned from the Marketplace
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() Feedback Score: 21 reviews
what mounts are you using? did you have to modify the trans. bracket?
I think im going to be buying those also. let me know if you have to modify anything if you get them before me. |
#1294 |
![]() Join Date: Oct 2010
Congrats. Any reason you decided to go VVTi? A lot of people say avoid the VVTi for S chassis swaps because they are harder to tune or wire, but I'm not sure how big a deal it is as I've never done it.
I had wanted to get a VVTi one at first since they are newer and thus the rubber and age affected materials would be in better shape in general, but people advised against it like I said. |
#1295 |
I modified the tranny bracket I had but its because it was for a r154. Xcessive has a w58 tranny bracket though
#1296 | |
#1298 |
^^?? Are u meaning the front half of the ds of the r154 and weld it to the 240 rear half? It won't work because the diameter is different on both ds.
#1299 |
I mean cut both front half shafts from each car to make a hybrid front half shaft that will bolt into the rear 240sx half shaft and to the r154. I didn't know about the diameter difference, is it large enough to make a difference?
#1300 |
Yes, the ds shop i took mine said it can't be done safely so they just made me a 1 piece. plus it gets rid of that carrier bearing.
#1301 |
I see, I just don't like the idea of having to get another ds made if I decide to change the differential.
Where do you guys go to get them made? driftmotion? shaftmaster? Do they need the r154 yoke and rear 240sx flange? Last edited by Mr. Phonso; 01-20-2013 at 08:12 PM.. |
#1302 |
#1303 | |
I just got it running on the pallet yesterday with not a problem. If you understand wiring, and know u can do it it should no be any harder to swap this engine in than a RB, non vvti 2jz ect.... |
#1304 | |
Its like $320 shipped for an Aluminum shaft from Shaftmasters. They are the best. Period.
Jets > Cars |
#1305 |
If you plan on changing differential just keep the stock pumpkin and put a cusco or kaaz or something in the same pumpkin. You don't have to change ds necessarily if you change the differential.
#1306 |
#1308 | |
#1309 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
#1311 |
I just called them and its 318 but that was for steel. I have written in my book that I paid 335 back in 2006 so i guess prices have gone up
Jets > Cars |
#1312 |
E double, just go to your local parts store and ask for their brass fuel fittings. I got them for like $5, they basically just clamp on the hard line as you tighten the male end into the female end.
#1313 |
![]() Join Date: Apr 2007
exactly, i can't remember what size they were or what i used. i didn't have much into the setup. I think looking back if i were to do oe style lines again i would run them down the drivers side frame rail then up. instead of up by the downpipe and then over.
#1316 | |
Aluminum Fuel Line, 5/8 Inch O.D. - Speedway Motors, America's Oldest Speed Shop
#1317 | |
Trader Rating: (53)
#1318 |
I would recommend that yes. (-6AN 3/8 )
I have one single -6AN line that Y's to dual -6ANs to the rail. I doubt this is enough for E85 as most people run Dual -6AN Feeds. *Then again alot of people say Ethanol isn't smart to use on Aluminum*
#1320 |
I'm not a chemist. but i can't see the amount of ethanol being in gas today being enough to corrode the lines. Someone else may wish to chime in. I read on a few muscle car/hot rod forums about people using aluminum stuff for years with no issues.
