03-29-2013, 04:39 PM | #13231 |
What is this sensor thing? And can I unplug it? It's in the middle bar in front of the radiator. Same bar that supports the hood latch. It's getting in the way of me mounting my FMIC...
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr Last edited by Irresistible; 03-30-2013 at 03:19 AM.. |
03-29-2013, 05:07 PM | #13232 |
OK guys I need some Zilvia knowledge... My rb20 swap Alternator will not freaking charge.. I don't get it.
The rb alternator wouldn't charge originally, so I swapped it for a KA alternator. worked. My alternator was charging about 14.2 volts. I take it for a little test run around the block ( which was fucking amazing ) I shut the car off, DEAD. Jump it, drive it into my driveway. all good. shut it off. start it up again nothing. dead. Alternator won't charge at all now. zip zada nothing. I checked the ground checked the wires checked the belt but I'm lost.. God this thing is pissing me off. if it wasn't for the fact that the Damn thing pulls like a train in boost, i'd scrap it lol. BTW this turbo is freaking amazing, I was already at 5 psi before 3k RPM! I didn't take it past 3k rpm lol and that wasn't even floored! Also the turbo spools SO FREAKING LOUD like a diesel.. god I wish I got a video. anyway need some alternator help please |
03-29-2013, 10:58 PM | #13237 | |
did you check the alternator fuse? |
03-29-2013, 11:46 PM | #13239 |
yeah the guy who I got my car from did a piss poor job of installing the pbm hmic and now i'm fixing it, I'm thinking about just getting some metal bars and fabing something up
03-30-2013, 03:19 AM | #13240 | |
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
03-30-2013, 07:00 AM | #13241 |
That 'tuner lug nut not fitting right on oem wheels' may have been true many years ago. Here's a fact on anything marketed as a lug nut 'currently'.:
They MUST conform to fit ALL wheel base holes with a spec force(That spec would be 85'#). The main difference in all lug nuts is the thickness of the shaft/neck/ whatever you name it. IF you go using tuner lugs on your wheels on a DD, tighten them with a basic torque wrench, drive 40 miles, check them, then check the fuckers once a week. Why? Because, they are ALUMINUM and your lugs are STEEL. This means that if there is even the slightest imbalance in your wheel/tire the difference in the metals will cause the lugs to loosen. My OEM's are balanced right, but I still keep a tool box in the trunk filled with tire repair shit to include a torque wrench to check my lugs once a week. Those chrome OEM lugs, well, they can torque to 110'# lock them down, then check them in 40 miles and forget about them. ps If you had bought Mutekis(some others) you could have got a 5 lug set. If you go buying four lug sets, well, buy two, or spend the big bucks and buy the suckers by the piece
03-30-2013, 07:08 AM | #13242 | |
Nissan Parts | Online Nissan OEM Parts and Accessories type in VIN, search menu for bumper...the parts ie, brackets are listed in stock for under $10ea
03-30-2013, 07:24 AM | #13243 | |
Trader Rating: (58)
Feedback Score: 58 reviews
Have you tried a different battery?
03-30-2013, 08:33 AM | #13244 |
so i recently got a tomei elbow , i cant really tell by looking at the o2 hole but does anyone know if it uses a fat or skinny o2? i think its fat but should probly double check with anyone else who has one , thanks
edit , its a s13 redtop. Last edited by tengo240; 03-30-2013 at 08:33 AM.. Reason: oooohhhh |
03-30-2013, 09:46 AM | #13246 |
Tomei elbow uses "fat" o2 sensor. You can get an adapter though, off like eBay for a few bucks.
03-30-2013, 06:48 PM | #13249 |
03-30-2013, 10:47 PM | #13250 |
95 s14... Two white female plugs behind where the ecu is on the passenger kick panel. What do they go to? Is something supposed to be plugged in there? Thanks
03-31-2013, 01:07 AM | #13252 |
Will I be able to run a 17x9 +15 rim on my S13 silvia without rolling or pulling the fender (stretched tires of course) or having it look like shit? (keep in mind I'm not all about the herrafrush)
SCAMMERS MrFuel sold me a cracked manifold geoff240sx sold me a blown turbo |
03-31-2013, 03:05 AM | #13253 |
Working on my brothers s13 last night to replace a leaky power steering high pressure line. I'm having a tough time disconnecting the bottom hard line from the high pressure one ( near the sensor?) that also connects down there. We got the banjo one off at the top with a bit out a struggle but I can't get the bottom one out to save my life. Are they really that tough? Or should I just go ahead and replace the hard line also?
WTB: zenki hood, passenger headlight!! |
03-31-2013, 01:29 PM | #13255 |
03-31-2013, 02:13 PM | #13257 |
So I swapped in a 300zx (z32) alternator and it is charging right up!
and btw the way, a 300zx alternator is a very easy swap compared to a quest. on a RB20. |
03-31-2013, 03:37 PM | #13259 |
Hey guys/ gals, I was wondering if any of you used ARC-8000R Control Panel Kit. Did u have any problems? I was trying to figure how to set the timing for the pop up lights, and wiring up the heater core. Please chime in if your using this product successfuly, thanks!
03-31-2013, 09:52 PM | #13260 |
Any folks recommend specific replacement rear axle boots? I noticed some grease on my undercarriage and sure enough there was a fairly small tear in one of the boots.
I remember on here some people hate Autozone boots, but O'Reillys work great or vice-versa or something. I'm pretty sure it tore because my car is low so I'd like to get something that will withstand abuse a little better than OEM is possible. |
