04-06-2013, 06:38 AM | #13323 | |
add a methanol/water injector kit. This adds a slight increase in performance and cleans up the exhaust as well
04-06-2013, 08:46 AM | #13324 |
I feel like I should know the answer to this, but not sure... I had my summer wheels and tires off since October where I stored them in my basement until now. I put them on and drive the car and now they feel out of balance?? They were not this way before, can storing tires cause them to be out of round? They weren't even under the weight of the car though...
* S14SR22 * 9.0 c/r * GT3071R * |
04-06-2013, 02:04 PM | #13326 | |
Trader Rating: (31)
Feedback Score: 31 reviews
04-06-2013, 09:26 PM | #13327 |
Question : What does the RB20 do at redline? what does the ECU do. does it just Cut fuel or what?
Because I keep hitting a block at about 24 psi / 6300 RPM on my AEM, but I'm thinking I'm hitting redline and not even knowing it? my 240sx tach is way off. and possibly my aem has the rpm wrong too. So does it just straight up cut fuel or does it do like that shit in videos " Nnananananananana"?? |
04-06-2013, 09:49 PM | #13329 | |
Also how much power can the stock RB20 clutch handle.. because I'm easily making double and have no slip |
04-07-2013, 07:40 AM | #13330 | |
04-07-2013, 07:48 AM | #13331 | |
If you can figure out the manufacturer, it is simple enough to look up the torque specs for the disc. Most oem turbo discs are rated to about 350#' before slipping if they are STOCK(from my phone lesson with ACT). Ooohh yeah, ACT 13# flywheel, XTSS pressure plate and disc..all good for a smooth 350# of torque...later on. Boxes are purty too!
04-07-2013, 04:01 PM | #13332 | ||
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
04-07-2013, 06:56 PM | #13333 |
Ok so weird problem. No idea what to think of it.
My CEL light blinks when I shift. I have a Rb20 w/ WSP harness so it isn't a wiring problem. that's all.. my CEL blinks when I shift.. I don't even know wtf to think of it. not just one or two blinks. but like 5-6 steady blinks. |
04-07-2013, 09:46 PM | #13334 |
Trader Rating: (58)
Feedback Score: 58 reviews
Power steering rack, top seal. What is the PN?
04-08-2013, 07:01 AM | #13335 |
Trader Rating: (53)
Feedback Score: 53 reviews
are s13 and s14 non-abs brake boosters the same? i deleted my ABS system and replaced my stock front brakes with Z32's and the ABS brake booster is not cutting it at all. the brakes work well, but the pedal is ridiculously mushy and almost goes all the way to the floor.
This never happened when i put Z32 fronts on my 180sx back in japan and i didnt change anything except the lines and the front calipers on that car. i kept the stock s13 non-abs booster and master cylinder. i'm pretty sure my problem with the S14 is the ABS booster. Here is a list of the shit i did on my S14: - Completely bench bled master cylinder - Installed brand new non-ABS hardlines - Installed front & rear SS braided lines - Brand new seals and boots for all 4 calipers - Brand new Hawk HPS pads for front brakes and barely used Hawk's on the rear - Brand new rotors front & rear - Vacuum bled all lines to clean out old fluid and added all new fluid to the system |
04-08-2013, 09:27 AM | #13336 | |
04-08-2013, 07:58 PM | #13337 |
Alright guys I have a question about egr systems. I have an 89 hatch single cam. Only mods are test pipe to 3 inch exhaust and a cai (yes I know it's way too big). I have had a code 32. Cel. Egr system. I've replace the egr valve, egr temp sensor, checked replaced and triple checked all vac lines. And Checked/cleaned egr tube. Only thing I didn't replace was the egr solenoid which when I tested it seemed fine. So my question is what else could it be. The car is getting like 15-18mpg but runs like a champ. No run ability issues whatsoever. Any ideas? Anyone else with same problem? Any help is GREATLY appreciated...
04-08-2013, 09:42 PM | #13339 |
Only thing I checked was the tube goin from the manifold to the valve. I saw a write up about cleaning the carbon out of the egr ports on the intake for a dual cam but I wasn't sure if it was the same for a single
04-08-2013, 10:23 PM | #13341 | |||
Trader Rating: (58)
Clutch: Do you have an aftermarket one in there that you don't know about? Quote:
It's similar. I bet the valve itself is clogged solid.
04-08-2013, 10:32 PM | #13342 | |
what gap should I do, everyone says 0.8mm but that's for stock, so maybe like 0.5? |
04-08-2013, 10:32 PM | #13343 |
So I'm still having my wiring issue. 75 amp fuse in the engine bay fuse box keeps blowing. It's the grey fuse top left all by itself. I can't find any bad grounds or damaged wires anywhere. I unplugged the alternator and it still blows. I'm lost here.
04-08-2013, 10:38 PM | #13344 | |
Trace the wiring back as far as you can and you should find the issue along the way. |
04-08-2013, 11:03 PM | #13345 |
Plastic guard is there and in great shape. Lower harness is a wiring specialties. No wires touching. I tried jumping the fuse with a screw driver and the wire from the fuse block to the battery terminal starts smoking and popping. I didn't have any issues before the s15 swap.
04-09-2013, 01:06 AM | #13348 |
Why can't I make a thread???? I just joined the forums in search of making a rocket bunny s13 coupe and I already accepted the activation on my email but for some reason I cant make a thread????
04-09-2013, 09:26 AM | #13350 | |
