Old 01-28-2011, 08:36 AM   #13411
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Yea I was with forest last night at his shop talking wheel sizing. And one of his vskf's are a 10 front negative offset with 30mm front fenders. He also runs a 17 x 10 front in a negative 10 I think.
Looks like I may go with the 18 x 9.5 +7 A Disk (107mm lip) with a 5-10mm slip on. That is still more aggressive than the R Disk of similar offset. Im just really trying to avoid spacers. How different do the faces actually look. A vs R Disk?
BX|Photo
LS400 - Slammed | Fitted | Loud
SuicidnS13 is offline   Reply With Quote
Old 01-28-2011, 10:45 AM   #13412
kernel
Trader Rating: (28)
kernel is an unknown quantity at this point
Feedback Score: 28 reviews
SuicidnS13
I just did my order for my vs-kf
18x10 +0 A-disk on front
18x11 -5 o-disk for rear
they goes on my s14 with stock metal fenders and rolled/pulled with stock camber arms
Here's the current size I'm running on my s14 with stock fenders.
SSR SP1 18x10 +3 BBK face
VS-XX 18x10.5 -7 with 225/40/18 tires
Ray's victrix 18x11 +1 with 5mm spacer, mean 18x11 -4 and 235/40/18
they all fit perfectly and no camber arms needed for massive camber..
With VS-KF A-disk on front, you'll need a 7mm spacer to clear Z32 brakes
R-DISK to O-DISK clearance are 17mm difference
A-DISK to R-DISK clearance are 7-8mm difference
I have S14 JDM front 4 piston caliper and they are smaller than z32 brakes so I'll need a smaller spacer i think
for the rear, 18x11 -5 can fit nicely with a 225 or 235/40/18 tires..
My fenders are only rolled and pulled a bit..ill do much more for better clearance
kernel is offline   Reply With Quote
Old 01-28-2011, 10:49 AM   #13413
nathanong87
nathanong87's Avatar
faces will look the same...just the pad is slightly thicker. pretty sure on this.
natelife.tumblr.com
Old 01-28-2011, 03:21 PM   #13414
SuicidnS13
SuicidnS13's Avatar
For the rears I ordered the same exact specs I had previously. I can still change them. Do you guys think I should step it up to the 18 x 11's for my current project?
Here are the 10.5's +1 low disk on my previous S14 pre-pulled
BX|Photo
Old 01-28-2011, 03:30 PM   #13415
nathanong87
naw...those will fit awesomely ...this time use stretched rubber rather than max rubber like last time . try to fit those with like -1.5 deg of camber.
natelife.tumblr.com
Old 01-28-2011, 03:42 PM   #13416
SuicidnS13
SuicidnS13's Avatar
Yup going for flush this time around. 235's or 245's for the rear. I already know I want 225's for the front.
BX|Photo
Old 01-28-2011, 04:58 PM   #13417
JonathanPrem
JonathanPrem's Avatar
JonathanPrem is an unknown quantity at this point
Go with 235 in the rears. If its possible can you post one from the back. I want to see how much it sticks out. I
JonathanPrem is offline   Reply With Quote
Old 01-28-2011, 11:23 PM   #13418
Lukasss
Lukasss's Avatar
Lukasss is an unknown quantity at this point
In love....
Lukasss is offline   Reply With Quote
Old 01-29-2011, 12:08 AM   #13419
energ
energ is an unknown quantity at this point
Send a message via AIM to energ
18x11.5 -18 265/35
18x9.5 -6 225/40
hope the new owner doesnt make these wheels fail, i will miss them for sure at least till the new ones show up!
energ is offline   Reply With Quote
Old 01-29-2011, 04:12 AM   #13420
spoolinrb25det
spoolinrb25det's Avatar
spoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to beholdspoolinrb25det is a splendid one to behold
SuicidnS13s old rims on my s15. i need to take some better pics
spoolinrb25det is offline   Reply With Quote
Old 01-29-2011, 07:26 AM   #13421
IThaJokaI
IThaJokaI is an unknown quantity at this point
Send a message via AIM to IThaJokaI Send a message via MSN to IThaJokaI
My buddy just lowered his s14, tucking tire on 18s. With stock arms he had 5.2* of camber in the rear, that's pretty massive.
WTB: 1(one) battle version toe rod
-Mike
IThaJokaI is offline   Reply With Quote
Old 01-29-2011, 07:51 AM   #13422
kernel
Trader Rating: (28)
wow, I don't have that much for my wheels fitment...never thought that stock camber arms could do that much tho
Old 01-29-2011, 07:57 AM   #13423
IThaJokaI
Im pretty sure its different for every car, but most I have seen get pretty crazy. When I lowered my coupe, I had 4.4 on one side, 4.32 on the other.
-Mike
Old 01-29-2011, 08:53 AM   #13424
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
When you align a lowered 240sx, there's usually a decent amount of adjustment, just not nearly enough to bring it back into spec. When I lowered my car, I ended up maxing out the camber positive, and then doing the minimum adjustment to get the toe into spec. Although my car isn't slammed, I was able to get it down to -2.5 degrees, while keeping toe within factory spec.
If I had say, maxed it out negative and then did my toe, I easily could have had -4 degrees +, and my car isn't even tucking tire. I'd say for a slammed 240, you've got a range of anywhere from -3 to -5ish, or more dependind on how low you are, on the stock arms.
Perfect Balance is offline   Reply With Quote
Old 01-29-2011, 10:19 AM   #13425
ayuaddict
ayuaddict's Avatar
I've hit -7 degrees of camber on stock arms.
aftermarket RUCAs and toe links are longer and allow for more POSITIVE camber.
Old 01-29-2011, 12:07 PM   #13426
icedsole
icedsole's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
im glad s15s are getting ruined now too
@pwrmves14
Old 01-29-2011, 12:13 PM   #13427
scweet1
scweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond reputescweet1 has a reputation beyond repute
19x12 -12 245/40
19x10 -6 225/35
Now in Candy Blue...
scweet1 is offline   Reply With Quote
Old 01-29-2011, 12:33 PM   #13428
R Drifter
R Drifter's Avatar
R Drifter is an unknown quantity at this point
car looks really good but im not digging the blue
R Drifter is offline   Reply With Quote
Old 01-29-2011, 03:51 PM   #13429
energ
who let this guy in this thread?
Old 01-29-2011, 10:48 PM   #13430
deolio
deolio's Avatar
internet sarcasm
Old 01-30-2011, 07:33 AM   #13431
thenooblet
thenooblet's Avatar
thenooblet is an unknown quantity at this point
I was thinking the same thing....
Originally Posted by towlie View Post
Texas does LS's hard
thenooblet is offline   Reply With Quote
Old 01-30-2011, 10:02 AM   #13432
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
At first glance I thought those Garsons were Rotiforms. Reminded me of that A4 avant on blue wheels....
It's different. Kinda like it.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-30-2011, 12:16 PM   #13433
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
Stupidly bright colored wheels were soooo '07.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 01-30-2011, 01:44 PM   #13434
sidwayswone
sidwayswone is an unknown quantity at this point
F 75x45mm -45
R 80x55mm -50
:ghey:
YouTube - Shane Bday S14 Cake
sidwayswone is offline   Reply With Quote
Old 01-30-2011, 05:32 PM   #13435
BoostinEuros
BoostinEuros is an unknown quantity at this point
Here is my girlfriend's setup.
MAE Riverside Dish.
18x9 et17 225/40
18x8 et17 215/40
Rolled fenders, no pull.
Spacers and a tad more camber soon. It's a work in progress lol. Not bad for a girls car.
BoostinEuros is offline   Reply With Quote
Old 01-31-2011, 12:04 PM   #13436
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
I guess he's planning on making some adjustments to the front fender wells, since the tire is like 1/2 an inch away from metal on all sides?
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-31-2011, 04:09 PM   #13437
blackoutt
blackoutt's Avatar
blackoutt is an unknown quantity at this point
Someone with 18x9.5 all around trade me for two of my 17" so we can do the 17-18.
blackoutt is offline   Reply With Quote
Old 01-31-2011, 05:35 PM   #13438
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Either post wheel fitment pictures, or get out. It's that simple.
Can't wait to get this thing back on the road.
Lame specs: 17x9 +5, 17x10 +19, 215/40 | 235/40. I'll never run Federal tires after this.
Especially with her new shoes on.
17x9 +5, 18x10.5 +14. Going to run Dunlop Star Specs 215/40/17, 225/40/18.
-Jspec-
Instagram/CrimsonRockett
Old 01-31-2011, 05:36 PM   #13439
OBEEWON
OBEEWON's Avatar
Mustang Bullets number one!
Old 01-31-2011, 05:39 PM   #13440
OBEEWON
OBEEWON's Avatar
Originally Posted by CrimsonRockett View Post
