03-21-2011, 02:07 AM | #13681 |
The rears sitting like this for now:
Really should fit my centres... It's going black. The only red zenki I've ever liked is yours man, what red is it out of interest? |
03-21-2011, 08:15 AM | #13685 |
I am kind of confused by this. Running less camber would make your current wheels stick out more. You would obviously have to do something like run widebody or pull the fenders for it to work with your set up, but I don't understand why you'd need bigger wheels....unless you want crazy camber, and wider wheels, and widebody. If I remember correctly you hate pulled fenders and love the cambered look, so I guess that would make sense.
Instagram - SJKnoop |
03-21-2011, 08:44 AM | #13686 |
super off topic, don't know where else to post this since this is like the only thread on zilvia that i actually post on.
been looking at the stats on my photobucket, and this one picture's got 1700 views coming from zilvia and i can't find the thread that it's posted on. http://i393.photobucket.com/albums/p...1/IMG_2316.jpg let me know if any one has any leads on it
03-21-2011, 08:50 AM | #13688 | |
im talking about wheel in relation to the bottom of the kit. if i were to take my spacer off at zero and set camber around -1 it would look like ass. so i refuse to do it. wider wheels? i dont see why i would want to run 9j's on 50mm over fenders, shit, i already run a 38mm spacer as it is on stock fenders.
@pwrmves14 |
03-21-2011, 08:59 AM | #13689 |
Lol, right after I hit 'post quick reply' I thought....he probably means the bottom of the kit. Derp!
It makes perfect sense. I didn't realize you were running spacers, and I also thought your wheels were bigger then 9s, so thank you for the explanation.
03-21-2011, 09:54 AM | #13691 |
Try using BlueMagic to clean the headlights.
http://www.tarmac-spl.blogspot.com/ |
03-21-2011, 10:06 AM | #13693 | |
This just made my day! Mad-Ass I think I remember that being posted in the picture thread or something.
03-21-2011, 10:35 AM | #13694 |
s14.a marc post a pic of the rears like you just posted but without the front end all jacked up.
that is cheating. Monster trucks look like that if you jack the front to clouds. |
03-21-2011, 11:55 AM | #13698 |
how did you mount the rear bumper?
Same question for you nathan, i know you have zipties but how does it fit so well? Mine has a slight gap under the tail lights
street dancer. GLEAM |
03-21-2011, 11:56 AM | #13699 |
front is maxed without messing with preload, FA coils don't go that low but it's fine. Gunna raise the rear up a bit then tuck the exhaust since apexi dual n1s sit hella low.
03-21-2011, 12:03 PM | #13700 |
rear bumper- a zip tie directly behind the rear tire. and then I have drilled to wholes into the trunk probably below the reverse lights. and zipties pull it up. I'll see if I can get you pictures tonight.
03-21-2011, 12:19 PM | #13701 | |
EDIT: infact my jack can be seen behind the car in that very picture....unless its all smoke and mirrors Mine has screws in the normal place where the trunk closes, on the arch lip (you can just make one out behind my tyre) and thats it. |
03-21-2011, 12:23 PM | #13702 |
I drilled through the aftermarket bumper on mine in the red circles and looped the zipties where the yellow line is. and ziptied at the quarter panel lip
03-21-2011, 01:22 PM | #13704 |
^That's exactly what I did to mine, lol.
Jeremy, so you were able to move it off your driveway? lol raise it another 1-1.5 in the rear and it will look good. Ithical's car with my front bumper:
03-21-2011, 02:19 PM | #13709 | |
the only reason it looks raked out is becauase the rear fender line is lower than the front.
@pwrmves14 |
03-21-2011, 02:26 PM | #13710 |
