05-20-2008, 08:43 AM | #122 |
Right... Good luck with that one.
It's probably not half as easy as you are thinking it is. 230 whp from an NA KA and staying together for a relatively long street life is probably almost impossible. |
05-20-2008, 08:47 AM | #123 |
05-20-2008, 11:43 AM | #124 |
Oh the wonders of bore / stroke / coinciding revability. <- sweet word.
But yeah dude, I agree with you. I saw N/A options, not N/A ka-(d)e options. Figured I'd stick up for the end I liked, considering I've driven stock and mildly built cars in all three categories. Nice analogy by the way.
- Tim |
05-20-2008, 11:48 AM | #125 | |
Trader Rating: (106)
Feedback Score: 106 reviews
EDIT: You are a fucking douche for neg repping me for my dyno numbers from like 3 years ago! WTF is wrong with you? Post up your dyno numbers bitch! |
05-20-2008, 11:51 AM | #126 | |
E-Sarcasm doesn't work. Thanks for explaining how a turbo vs. N/A engine works, though. Can you explain what the windshield wipers do next?
- Tim |
05-20-2008, 11:54 AM | #127 | |
s14
05-20-2008, 11:59 AM | #128 | |
Lol and you guys fail for the negative repping. I'm not entitled to express my opinions? At least I don't throw around a slew of swear words like a few of you scholars.
- Tim Last edited by timster; 05-20-2008 at 12:37 PM.. |
05-20-2008, 12:58 PM | #129 |
a micrometer, few companies parts book with specs, grind you own cam, new pistons,headwork.... 200 is feasible.... with itb easy and 200 is safe...
since when did building anything performance wise, made something last long...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
05-20-2008, 01:46 PM | #130 | |
05-20-2008, 02:38 PM | #131 |
I think you guys are getting a little crazy in this thread.
I'm thinking 200whp is possible, but much beyond that is speculation for a street build. In order to make more power, you're not going to want to stroke it, because that will kill the revs, and you'll need those, especially with the big cams they make for the KA. You'll have to get custom cams from Crower or somebody if you want to make big NA power with the the ultra-low rpm 2.6liter KA. In fact, you'll probably want to move the wrist pin farther up in the piston, and use longer rods for a better rod ratio. Ring lands don't have to be as thick in an NA engine as in turbo engines. Obviously up the compression ratio to 11:1 or so. Maybe a little higher if you plan to run E85. But hey, you'll need custom pistons if you want to move the wrist pin anyway. You'll want to bore it out a little, obviously. Just don't go too far, or the combustion chamber will need a serious working over. Streamline the ports, get bigger valves, and most likely get a custom intake manifold, or ITB's if that's what you want to do. just make sure you size the runner's length and width right. Do some research on that. I would then coat the combustion chambers, piston crowns, and exhaust ports with SwainTechs TBC. Yes, it's proven to make more power, because it keeps more heat in the combustion chamber, instead of transferring to your head. Your engine will also run cooler as a result. Get a metal head gasket. It's just common sense. Then you're going to want (at least) a DC sports racing header. If you're big into the NA, then getting a custom one will probably yield better gains, especially if you have ITB's, different cams, and bigger ports. Cams dictate a lot of header design. I would ceramic coat that just because it keeps the engine bay a little cooler, which is important, especially if you're running ITB's with no air ducting. Then, a full 3 inch exhaust would be a good choice, especially since you should be flowing a lot more air than a stock KA, and even stock KA's love 3 inch exhausts. If you want to be nice to the environment, you could run a 3 inch catalytic converter as well. I think that would probably net you around 225+whp. You have to remember the DOHC KA only makes about 130ish whp stock. Also, these are the same things you would do to any engine if you were building it to make more power. It's really not that hard. There is no magic to making the KA make more power. Or you could put all that money and a little more into an RWD SR20DE, swap a VE head on it, and make 250whp. I'm just saying. I also like how this thread started with someone asking about gearing and header flanges.
05-20-2008, 04:10 PM | #132 | |||
05-20-2008, 05:00 PM | #136 | |
- Tim |
05-20-2008, 06:07 PM | #137 |
I'm curious too. Does anyone have a built n/a ka? Is it everything everyone says it is, or supposes it will be like? I've been thinking of doing n/a myself.
This sig was inspired by nothing, then is wasn't. |
05-20-2008, 06:09 PM | #138 |
Some of the original questions were answered (gear ratio, exhaust flange, realistic power potential, and an idea of the cost) but not all of the original questions.
I have heard of several here on zilvia, but have seen none in person so I cannot comment on the streetability of the motors. Reliability is not a problem with the KA's. KA's are known to have bulletproof bottom ends and valvetrains (other than the upper timing chain guide breaking). Also reliability really depends on the skill and attention to detail of the person building the motor. The thing is, if you are going to get seriously into a N/A build you already have enother daily driver, or you are insane (take your pick). So streetability is not that much of an issue. Also a well tuned well built KA will have a pretty wide powerband and lots of low to mid range power and torque, which are the primary things that make race motors almost undriveable on the street, all top end and no bottom end. The REAL concern is can it pass smog? I'm sure you can get one to pass, but it will take some tuning wizardry for sure. Everyone is sooo swap happy that barely anybody actually builds a good KA, but they ARE out there. Just talk to bigvinnie, he is a KA guy and has built more than one N/A ka. |
05-20-2008, 06:17 PM | #139 | |
Wait, Turbo motors don't have torque or response? hahaha last time I checked, turboed cars have some pretty good torque numbers and there are many variables to the response on a turboed car. Have you forgotten the Mines Skyline GTR? Watch that video and tell me turboo cars don't have any response. [ame]http://youtube.com/watch?v=42KwIMakoaE&feature=related[/ame][ame="http://youtube.com/watch?v=42KwIMakoaE&feature=related"][/ame]
http://www.amazon.com/gp/prod Amazon book! |
05-20-2008, 06:57 PM | #140 | ||
Valid point nonetheless though. |
05-20-2008, 07:37 PM | #142 | |
s13sr blacktop pb manifold GT3071r blah blah 14ish psi That was a dyno during the tuning process hence the early cutoff. TQ stayed flat to 8k and made more peak hp than that. oooh yeah, check out that tq curve. I have more at 17psi and another at 21psi...didn't think they were necessary. Now show me yours mr. happy. |
05-20-2008, 07:48 PM | #143 | |||||
Oh wait you answered.. Quote:
05-20-2008, 07:49 PM | #144 | |
.. Sarcasm again.
- Tim |
05-20-2008, 08:01 PM | #145 | |
And you can have excellent response in a boosted application. Lets not get carried away with BS here. |
05-20-2008, 08:24 PM | #146 | |||||
05-21-2008, 02:52 AM | #148 | ||
Like " Water" was saying, "a race engine life spans are measured in hours for a reason". Take funny cars for example or top fuel cars. They usually rebuild their engines or swap in a new engine after EVERY PASS/RUN.
05-21-2008, 11:06 AM | #149 |
I'm all for NA KA. I currently drive a stock KA and refuse to drop money on a turbo kit when I feel suspension/braking is more important in a track setting. The issue with the NA KA is that there is hardly an aftermarket, and the parts that do exist are EXTREMELY expensive. $3K+ for a stroker kit? You can get them for a 302 for <$500 . In order for the NA KA to break the 200 HP mark regularly and reliably, the following things need to happen.
Destroker kit... High revs + huge cams are pretty much our only hope... Someway to redo the head... If we are going to be revving high, we need a high flowing head. If someone with a few junk heads lying around can find a way to make the head flow better and prove it with a flow bench and then offer their skills for cheap, that would help a ton. Someone on a 22RE (Toyota 8 Valve I4) forum actually welded metal into the ports of the head and then completely reconstructed the head that way. ITBs built specifically for the KADE... ITBs with the proper diameter instead of botched GSX-R ITB jobs. Until these are offered and offered at reasonble prices for your typical NA KA builder, the NA KA doesn't have a performance future.
Respect begets respect. |
05-21-2008, 12:31 PM | #150 | ||
