05-20-2011, 01:21 PM | #125 |
So I was told that the diaphragm that comes on these turbos is there weak spot. Apparently the crush under pressure ?? This is hear say honestly but I was told by someone it cause him to blow his motor. Is there a reasonably price alternative waste-gate to replace the one it comes with?
05-20-2011, 02:17 PM | #126 | |
BX|Photo LS400 - Slammed | Fitted | Loud |
06-06-2011, 11:59 AM | #130 |
So guys any more experiences with this turbo??? Seems to be alot of people ordering it...
Here is my complete install experience so far.. all godspeed products too. Purchase List: Godspeed Turbo Mani Godspeed Turbo Elbow Godspeed Downpipe Godspeed 18g DIF S13 Sr20det Lines Heres the break down of the install hardware wise: Bolt kit/install kit with turbo - copper washers were useable but the oil banjo bolt was not compatible with the DIF oil line kit. It was too short. Gaskets from Turbo kit - Good Gaskets from Downpipe and Elbow - Funny thing here is the 3 bolt gaskets did not match nor did they bolt up together. So I reamed all the holes out in the DP and have managed to get 2/3 bolts to work. Ill take a picture of the third for reference later. Turbo Install: Pretty straight forward. All the lines bolted up with absolutely no problems what so ever. The turbo probably could have been reclocked(exhaust side) just a bit, but I actually didnt see this till I got under the car and halfway bolted up the DP. Im just gonna have my shop cut/reweld the DP so its clocked properly for the exhaust. As of now my catback and testpipe will not bolt back up. The turbo was actually a hair large and I had to shave my factory mount about 1/2" in a C Cut to get the turbo to allow me to seat the manifold all the way down Other than those few issues which honestly werent that bad its gone pretty well. My only gripe is with the DP and the Elbow situation. But I dont really have the time or patience to re-order/replace them Ill just have my tuner cut and weld before we tune my power FC. BTW I am running the factory restrictor for bush bearing turbos (.63).
06-06-2011, 12:36 PM | #131 |
sorry but I didnt want to put my slr under there lol
for what I payed for the product im not even upset.
06-08-2011, 01:37 AM | #134 | |
Trader Rating: (57)
Feedback Score: 57 reviews
Beware for REF tickets |
07-13-2011, 01:25 PM | #137 |
so i got mines bolted down, injectors one, everything ready, car only made 235, we had it set to 15ps1 but it kept dropping to 12, idk what is wrong, im 500 bucks in the hole. and no idea, tuner thinks is the actuator and some other thnkis the maf, im using a stock one. what actuator should i get. iv spend some much doing this and nothing. hope its not the turbo since i got it from a menber here. sorry about my phone talk
07-13-2011, 01:54 PM | #139 | ||
What injectors, what tuning? Stock maf? Sounds like you are doing this ass backwards. Who gets a large turbo and keeps stock maf?
07-13-2011, 02:40 PM | #140 | |
http://zilvia.net/f/cars-sale/374160-1990-240sx-hatch-sr20det-350rwhp.html any way thats way too low for 550 and big turbo even with stock maf it should of max out the maf first. |
07-13-2011, 02:44 PM | #141 |
redtop sr, 30k on rebuild has bc valves, arp studs metal HG.big oil pan ect to b safe motor.
full 3 inch, front mount, safc 2 godspeed 18g with earls lines 550cc deatchwerks or w/e is called wit frp. no boost controller. the actuator was messed with to try to get more boost out of it. it went up to 15 then dropped to 12. |
07-13-2011, 05:59 PM | #142 |
So you guys adjusted the wastegate to be shorter or longer? Also what sort of dyno? 250whp-300whp would sound about right with an safc tune at a solid 13-15psi. Im pretty sure this turbo isnt even at its efficiency zone untill 17-20psi.
07-14-2011, 05:53 AM | #143 |
SAFC is not a tuning solution - they do more harm than good... but this - nor the maf is the issue... Neither one would make boost fall off. And you have stock cams/intake manifold?
Its either the actuator is opening too far - or isnt working correctly - or you have a boost leak. I'm gonna lean towards boost leak.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
07-14-2011, 11:02 AM | #144 |
Stock cams/intake. I'm not sure how they turned it I wasn't there.
They thought it was my actuator but when I get my car back I'll check for boost leak. I should not have one but it could always happen. I can't afford power fc just yet, thanks for the info I may take a new actuator to them to check it out. |
07-15-2011, 01:17 AM | #145 |
I have a feeling its how they adjusted the wastegate. My friends out here have no trouble holding 18-20+psi with this turbo.
