Old 08-06-2015, 09:15 PM   #121
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
Originally Posted by dwnshft2drft View Post
Speedometer gear mounting kit:
Extension housing 32130-RRS50
Ball 32720-RRS50
Snap ring 32228-RRS50
6 speed with VSS plug are from early s15 the late type dont have them.
Thank you! But what about the actual plastic gear that sits on the shaft inside the tail housing? Am I doomed to track down a blown 5 speed and modify it to work? Or is there a direct replacement for the s15 gearbox?
ShakotanGazelle is offline   Reply With Quote
Old 08-06-2015, 09:52 PM   #122
dwnshft2drft
dwnshft2drft's Avatar
Trader Rating: (28)
dwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enoughdwnshft2drft will become famous soon enough
Feedback Score: 28 reviews
They did not mention that gear part number. You need to modified other gears for test fit.
And for the extension housing you already have it.
dwnshft2drft is offline   Reply With Quote
Old 09-04-2015, 08:33 PM   #123
itsjustdaphne
itsjustdaphne's Avatar
itsjustdaphne is a well-known jackass
Originally Posted by shaggy0778 View Post
Not my car, but a friend of mine in Jacksonville is making over 400whp on an s15 6 speed. He broke the original trans after 3-4 months of dailying/abuse including launching with 275 radials. He's now on his second
Mustang dyno:
And this one is done too.....
Time to go 350z trans, finally.
There's a video on my IG of how noisy it is.
The last trans did the same thing until it just didn't want to go into gear at all and I'd get stuck in neutral while driving.
@ddaapphh | @spectuned
itsjustdaphne is offline   Reply With Quote
Old 09-04-2015, 10:12 PM   #124
Kingtal0n
Kingtal0n's Avatar
If you drive it nice, it can last a long time at 400bhp. No hard launches, no slicks, no drifting, no terrible clutch kicks.
The only reason I am not using a six speed right now is because of their cir-clip issue.
tinyurl.com/4l80er
Old 09-27-2015, 01:23 AM   #125
itsjustdaphne
Riding in a tow truck at 3am. Just toasted the 3rd trans. Awesome.
Old 10-23-2015, 09:03 PM   #126
S13GG
S13GG is an unknown quantity at this point
Did you figure this out?
I used the USDM "speedo drive gear" to suit my chassis, ie: speed sensor (5MT - KA - 95) and had it enlarged to fit (I.D.) 28mm.
This part is inside the transmission on the output Shaft, so get the parts guy that has experience with the exploded diagrams, and not the 18yr old.
S13GG is offline   Reply With Quote
Old 10-24-2015, 08:47 AM   #127
ShakotanGazelle
I got a blown 5 speed for free so that's here I'm gonna steal that part from.
Anyone got the 6mt bell housing bolt sizes or a set I can buy? Bought a 5mt set but half the bolts are way too short - go figure
Old 11-08-2015, 12:10 AM   #128
mik5082
mik5082 is an unknown quantity at this point
circlip modification by neat gearboxes
https://neatgearboxes.wordpress.com/...x-circlip-mod/
mik5082 is offline   Reply With Quote
Old 11-15-2015, 09:15 PM   #129
ShakotanGazelle
so what do s13 6 speed guys use for driveshafts? the s15 one i have is too long and the carrier bearing is like 6" too far back.
Old 02-20-2016, 10:36 PM   #130
slow_sr20
slow_sr20's Avatar
slow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant futureslow_sr20 has a brilliant future
If anyone is planning to ditch the dual mass flywheel, keep in mind that you will most likely need standard s13/s14 flywheel bolts. The s15 bolts are way too long. ARP seemed to be the cheapest. That's what I used with a Nismo/Autech flywheel.
slow_sr20 is offline   Reply With Quote
Old 02-29-2016, 07:07 PM   #131
slow_sr20
slow_sr20's Avatar
Is there anyone out there with confirmed drive shaft fitment info? my car is s14/abs car. I purchased what i was told is a 6-speed s15 drive shaft. Fits into output of transmission just fine but is too long. The rear section from diff to carrier is off by 1/2" approx. The front section is entirely too long by probably 2-3". Anyone else compile any data? I figure i can locate a stock rear section and have the front section shortened, but was hoping for a bolt in solution.
Old 05-25-2016, 08:42 PM   #132
Goldhawg
Goldhawg is an unknown quantity at this point
I have an Autech S15/6 speed that I'm swapping in a Datsun roadster. It has 60K miles on it. I'm thinking that I should at least replace the clutch disc before I install in the car. thoughts? What clutch disc should I get to replace the one I have?
Goldhawg is offline   Reply With Quote
Old 08-15-2016, 09:54 PM   #133
rcefoonia
rcefoonia is an unknown quantity at this point
Amazing write up we don't even have this much info in AUS about the gearbox.
rcefoonia is offline   Reply With Quote
Old 08-15-2016, 10:01 PM   #134
rcefoonia
dam great job on the post
Old 09-24-2016, 07:25 PM   #135
Kingtal0n
Kingtal0n's Avatar
I was re-reading this for some info about the gear ratios and using a calculator came up with a different gear spread, here is the modified version
tinyurl.com/4l80er
Old 09-26-2016, 09:13 AM   #136
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
You should probably keep the final drive the same for a gear set comparison. I'm curious what an S14 5-speed looks like compared to an S15 6-speed, both with 3.692 FD.
3.916 was only on A/T cars, 3.692 was M/T, and 4.08 was NA and all USDM models.
Old 09-29-2016, 11:01 AM   #137
chulme1234
chulme1234 is an unknown quantity at this point
Quick question if somebody dosent mind answering....
Bought a S15 6MT to put on my SR20DE drift car
It came with the shifter, but no knob so I bought an eBay special, I've tested all the gears and its fine...
But how do I engage reverse?! I've tried pushing down and pulling up but no luck? Do I need a special gearknob to pull up?
Bit confused haha
Sorry if this sounds stupid!
Also sorry again for bumping an old thread
Sent from my E5823 using Tapatalk
chulme1234 is offline   Reply With Quote
Old 09-29-2016, 11:19 AM   #138
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
its a 90s 6 speed... so probably just push all the way to left and up, or all the way to the right and up or down. no need to push down or pull up on the gear shift.
Old 09-29-2016, 11:21 AM   #139
chulme1234
Looking at pics on one of the first few pages and it's all the way across right and down, next to 6th, sure I tried that though
Old 09-29-2016, 11:22 AM   #140
dwnshft2drft
Trader Rating: (28)
Do you have it installed already?
Old 09-29-2016, 11:23 AM   #141
chulme1234
Yes mate
Old 09-29-2016, 11:26 AM   #142
dwnshft2drft
Trader Rating: (28)
Theres a reset trick. Have some one push the car reverse while you engage clutch then force it to reverse. I had the engine running and be safe though.
Old 09-29-2016, 11:27 AM   #143
chulme1234
What I'm asking is do you have to push the knob down or anything to put it in reverse?
I know how reverse works
Old 09-29-2016, 11:31 AM   #144
dwnshft2drft
Trader Rating: (28)
This is correct no downs or ups. If you still cant put it in reverse. Try the Japanese trick I posted.
Old 09-29-2016, 11:42 AM   #145
chulme1234
How does that work? Do you keep pushing to the right and try put it in reverse?
Old 09-29-2016, 11:51 AM   #146
dwnshft2drft
Trader Rating: (28)
Yes mate, while someones pushing the car reverse. Try it and let me know if this works. If it does I'll tell you what went wrong.
Old 09-29-2016, 11:52 AM   #147
TheRealSy90
TheRealSy90's Avatar
All the way right and down how hard is that to understand.
Such a good signature.
Old 09-29-2016, 12:24 PM   #148
chulme1234
Because I didn't know that?
No need for the attitude.
Wicked cheers for the helpful comments buddy!
Old 09-29-2016, 12:40 PM   #149
dwnshft2drft
Trader Rating: (28)
He's doing it right but he was just confused
Old 09-29-2016, 12:53 PM   #150
dwnshft2drft
Trader Rating: (28)
No sweat mate! Hey wonder if you can help me out to find me a s15 evaporator box and s14a front bumper side cover/caps? (pictured)
