Old 07-27-2012, 11:07 AM   #121
CaBS
CaBS's Avatar
CaBS is an unknown quantity at this point
Originally Posted by future View Post
Everytime i check this thread its gets better
You like the "snack pack" then? =)
SXDevelopments on Facebook
CaBS is offline   Reply With Quote
Old 07-27-2012, 11:11 AM   #122
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
What is in it?
Old 07-27-2012, 11:15 AM   #123
CaBS
CaBS's Avatar
Hot chips (I think most Americans call them french fries?) covered in beef kebab meat with garlic and bbq sauce. MMMMmMmm =)
Old 07-29-2012, 08:13 AM   #124
CaBS
CaBS's Avatar
Some shots of the new combined frontmount, radiator, powersteering res and radiator overflow. They all go in/out as one piece now. But can also come out separately if need be. (bar the front mount)
New twin pump surge tank setup. Nothing in the car and the second pump is only activated when our preset injector duty cycle level is met to prevent heating the fuel unnecessarily. Also no fuel lines inside the car which is a plus.
Apparently some sort of organic steam cleaning process being undertaken after a "snack pack".
T/B fit up.
Hypertune make great looking throttle bodies no doubt about it. =)
The super sparkle booster is here to stay (for now) =)
Dropping it all in.
Injectors in the rail ready to go in.
To help fight the cold nights... =)
More soon.
Old 07-29-2012, 09:16 AM   #125
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Cold nights?
Hahahahaha. Silly Aussies.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 07-29-2012, 07:53 PM   #126
CaBS
CaBS's Avatar
Originally Posted by Slammed180 View Post
Cold nights?
You probably have a point there. Although all our buildings are not really made for cold conditions nor are are clothes so yeh compared to properly cold places. 4degrees C ends up feeling pretty damn cold!
Old 07-30-2012, 09:45 AM   #127
CaBS
CaBS's Avatar
All the bits going back in for the final time.
Hypertune T/B
Still had to fit up the TPS
Injectors all wired up and in ready to go.
Link bolted into position.
The new super sparkle black, still not finished yet though needs to have a cut back and another coat of clear before its done.
Once thats done it should look glassy smooth.
P12 coilpack cover looks nice I think, very functional on the street too keeping water off the coil packs with the vented bonnet.
All the oil plumbing completed for the turbo.
Wider view.
Brakes took afew coats of red, Brembo stencils can be put on later.
So much to do so little time.
More soon!
Old 07-30-2012, 09:57 AM   #128
future
future's Avatar
Trader Rating: (42)
I really like this thread
Old 07-30-2012, 09:59 AM   #129
CaBS
CaBS's Avatar
Thanks man, trying my best to keep the updates interesting!
Old 07-30-2012, 11:09 AM   #130
badfish816
badfish816 is an unknown quantity at this point
That throttle body is gorgeous.
badfish816 is offline   Reply With Quote
Old 07-30-2012, 01:52 PM   #131
Rps13Ed
Rps13Ed is an unknown quantity at this point
whats the mixture on the paint used for the VC?
Rps13Ed is offline   Reply With Quote
Old 07-30-2012, 02:30 PM   #132
alixander2012
alixander2012 is an unknown quantity at this point
Got a question, that hyper tune throttle body, where can I find one for my dual cam ka?
alixander2012 is offline   Reply With Quote
Old 07-30-2012, 06:18 PM   #133
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
ummmmmm maybe contact hypertune??? i have a feeling that as soon as you see a price you'll
op this thread delivers!!!! the work going into this car is fantastic.
Old 07-31-2012, 08:51 AM   #134
CaBS
CaBS's Avatar
Its not actually a custom mix its a one off colour released by a company. I'll try find out what its called for you. Its near impossible to get though apparently our painter came across some somehow.
Old 07-31-2012, 08:55 AM   #135
CaBS
CaBS's Avatar
What he said.
Hypertune - Performance Engineering
Thanks for the kind words! =)
Old 07-31-2012, 08:56 AM   #136
CaBS
CaBS's Avatar
SXDS15 Mazworx SR23VET - YouTube
Old 07-31-2012, 08:57 AM   #137
CaBS
CaBS's Avatar
The start up specs from Mazworx say that the motor should be cranked without compression and without the rocker cover on to check that oil pressure is building ok and the oil spray bars are working for the cams. Some shots of the head with no cover on it.
The P11 Rocker cover gaskets for around the spark plug holes are a totally different size to the P12 ones we found out last minute. They're the same as S15 so luckily the local Nissan dealership had them in stock so a mad dash was done to go buy a set. When they go in they only just fit on the outside of the ring around the hole.
Can see the Supertech goodies in this shot.
Tomei cam gears are used also you can see the hole drilled with a screw cap bolt in it. This is for the mazworx trigger setup we might move to something like that later but for now the CAS will do.
More soon!
Old 07-31-2012, 09:23 AM   #138
future
future's Avatar
Trader Rating: (42)
So what would you guess has been spent on the engine bay alone in parts?
Old 07-31-2012, 09:30 AM   #139
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
I would give a guess since I have basically the same Mazworx setup, but if he's like me, its not information that he would like everyone to know. Great job on the build, it looks great.
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 08-01-2012, 07:21 AM   #140
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
If you have to ask, you can't afford it.
I like how clean this thread is, not only your work, but posts as well and not many people are trolling it, so build content per page is quite high.
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 08-01-2012, 07:42 AM   #141
CaBS
CaBS's Avatar
Thanks mate, lots of building has been happening in a reasonably short period of time so there is plenty of documenting to be done! =)
I guess not many people trolling it cause there are not that many viewing it. :P
Old 08-01-2012, 08:12 AM   #142
CaBS
CaBS's Avatar
The fuel system was almost completed in these shots with just the final connections of the pumbing to be done. Consisting of two Pierburg pumps capable of -360L/h the second one only kicking in once a certain injector duty cycle is reached (set to whatever is appropriate). Both pumps on the side of the surge tank. None of the system goes into the car apart from the wiring of the pumps.
We were really happy with how compact and neat it turned up to be.
Teflon lines for the last part cause it was to hard to get the hard lines up in here.
Hardlines the main length of the car with an inline filter. This stuff is super light and self supportive so it doesn't need to be braced onto the chassis nearly as much as soft line does.
Small amount of rubber line has to be used to connect to these pumps as they dont have threaded ends on them which is a slight downside.
Another angle.
More soon!
Old 08-01-2012, 09:41 AM   #143
Conrad 2NR
Conrad 2NR's Avatar
Conrad 2NR is an unknown quantity at this point
Sexy lines, love the progress thus far.
www.motoredge.wordpress.com
Conrad 2NR is offline   Reply With Quote
Old 08-01-2012, 09:51 AM   #144
Edwin562
Edwin562's Avatar
great progress. subscribed!!!
Old 08-01-2012, 12:49 PM   #145
Imarvin240
Trader Rating: (18)
whats the fuel capacity of the surge tank? great looking build thus far.
Old 08-02-2012, 09:21 AM   #146
CaBS
CaBS's Avatar
I think its around the 2.5L Mark but not 100% sure on that I haven't asked.
Old 08-02-2012, 09:21 AM   #147
CaBS
CaBS's Avatar
Thanks guys!
Old 08-02-2012, 09:22 AM   #148
CaBS
CaBS's Avatar
Super sparkle cover on for the first time along with the catch can plumbed up.
Waste gates and dump pipe all installed a lot of mucking around to get this all done the bolts that come with the V-Bands from turbo smart dont fit. This was my job to fit so I in particular found this very annoying!
Thankfully Dennis from Grimm was still open and had some which fitted. (Thanks)
Andrew spent the whole day sorting last minute things out with ecu tests and a million other tiny jobs and was able to do the first start. The car then got towed to Unigroup to be run in on the dyno and get everything bedded in and find potential issues. One thing other than some small leaks we found was that the VVL solenoids were not working properly so the car was towed back home to get that fixed along with the heap of work still to be done on everything else.
More soon!
Old 08-02-2012, 09:29 AM   #149
future
future's Avatar
Trader Rating: (42)
Nice work. A man can only dream lol
Old 08-02-2012, 03:03 PM   #150
Imarvin240
Trader Rating: (18)
very excited to see what numbers this will put down along with how the curve looks.
