Old 02-22-2014, 12:01 PM   #121
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
I think my issue is the timing. Luckily a friend is letting me borrow his timing light Monday so I'll get it set correctly then.
@s13cole
FourtyKid is offline   Reply With Quote
Old 02-22-2014, 09:26 PM   #122
FourtyKid
FourtyKid's Avatar
Fixed my brake light and blinker issue. It was the switch under the brake pedal.
I need moooarrr loowwwww! Can't wait to get coilovers!
@s13cole
Old 02-23-2014, 12:50 AM   #123
Reece
Reece's Avatar
Reece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymoreReece is not welcome here anymore
If this car isn't lower than mine by this spring I'm gonna be sad.
Originally Posted by Almighty So View Post
Don’t price bash me.
Reece is offline   Reply With Quote
Old 02-23-2014, 05:05 PM   #124
Night drifte89
Night drifte89's Avatar
Night drifte89 is an unknown quantity at this point
yup guys I'm buying that lowering kit.....
Night drifte89 is offline   Reply With Quote
Old 03-12-2014, 11:21 PM   #125
FourtyKid
FourtyKid's Avatar
OK I haven't updated for a while so here's where I'm at.
I think the reason it won't start is because my timing has jumped a tooth or two. So Night drift89 and I are pulling the engine out tomorrow for timing work, a cleaning, and hopefully headers installation. I'm going to see if I can just get the stock VH headers to work somehow. I've heard if you disconnect the steering joint in the bay, drop the engine in, and reconnect it, they'll fit. We'll see soon I guess.
I also don't have power steering, so I ordered the VH-S13 power steering kit from Mazworx tonight.
Here are some pictures of what I've been doing:
Engine was dirty....
Reeeallllyy dirty:
So I started cleaning up a bit...I'll get more done when it's out of the car:
I also made a bumper support in my welding class for fun:
@s13cole
Old 03-13-2014, 07:46 AM   #126
mikey976
mikey976's Avatar
mikey976 is an unknown quantity at this point
Send a message via AIM to mikey976
where did you get your motor? Pompeii? holy crap thats alot of gunk.
btw diet coke does wonders on aluminum
KAe-T goal 400whp with A/C - Hatch VH45 track duty - Titan VK56 tow rig
mikey976 is offline   Reply With Quote
Old 03-14-2014, 12:18 AM   #127
FourtyKid
FourtyKid's Avatar
Well I had a productive night with me, myself, and I.
@s13cole
Old 03-14-2014, 08:12 AM   #128
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Car looks like its coming along nicely. Make sure you bolt that bash bar on and not weld it as well. Keep up the good progress dude.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 03-14-2014, 03:11 PM   #129
FourtyKid
FourtyKid's Avatar
Thanks!
And yep it'll be bolted on, I'm fabricating brackets that it will slide into, with a pin so I can easily remove it if need be.
Also, I got some wiring heat shield from PerformanceVH, I'll be using it on my starter/transmission wiring near the passenger side header, check it out:
@s13cole
Old 03-18-2014, 11:12 PM   #130
NismoRich
NismoRich's Avatar
NismoRich is an unknown quantity at this point
was it actually jumped timing causing it not to start? or was it wiring (did not go back to see how you did your wiring or if you had it done for you)?
NismoRich is offline   Reply With Quote
Old 03-19-2014, 05:14 AM   #131
marvlrose
marvlrose is an unknown quantity at this point
Looking good Cole!
I apologize for not being able to get back to you via email as quick as I would have liked. Looks like you have troubleshooted that starting issue pretty well since the next thing I was gonna suggest was to check your timing. I surely hope that is the only thing preventing it from starting because I have rattled my brain and did a lot of searching with no other ideas as to what it could be. I sure hope you get everything squared away soon. Cant wait to see this thing running!
-Marvin
marvlrose is offline   Reply With Quote
Old 03-19-2014, 10:11 PM   #132
FourtyKid
FourtyKid's Avatar
No problem Marvin. I'm also excited to see it running!
I got the timing chains set correctly with the help of a mechanically inclined friend
I've seen where guys will remove their steering shaft/knuckle, put the stock VH headers on, drop it in the car and put the steering shaft back in and it fits good, so that's what I'm going to attempt to do. $650 for a pair of headers is outrageous so I'm going to find a way to use these one way or another, whether I have to heat em up and bend em or whatever it takes!
So, I ripped all of the nasty heat shield metal off of the headers and painted them:
@s13cole
Old 03-19-2014, 11:31 PM   #133
KPNITRL
KPNITRL's Avatar
KPNITRL is making a name for him/her selfKPNITRL is making a name for him/her selfKPNITRL is making a name for him/her self
Great stuff so far!
Thumbs up to you for the header attack. Ive debated doing the same. Good luck!
KPNITRL is offline   Reply With Quote
Old 03-20-2014, 12:03 AM   #134
NismoRich
NismoRich's Avatar
I'm interested to see how those stock manifolds fit. now that the timing is set correctly, get that thing back in and running!
Old 03-20-2014, 03:51 AM   #135
zenki 95
zenki 95's Avatar
zenki 95 is an unknown quantity at this point
Subscribed!!! Nice Lmk if those headers fit
TAPATALK
zenki time! "Cant buy weed and pussy with disney dollars"
zenki 95 is offline   Reply With Quote
Old 03-21-2014, 09:47 PM   #136
FourtyKid
FourtyKid's Avatar
I got a bunch of stuff done today!
Timing covers, crank pulley, headers, and valve covers are back on.
How she sits now:
Driver's side header on:
Passenger side header on:
I also got my Mazworx VH power steering setup in, waiting to be hooked together!
My oil pan had a big ole drip leak coming from near the drain plug. Turns out it had impacted something (dat stance tho) and cracked. So I got it all sanded up and she's sitting with some JB weld on right now:
Should be able to drop it back in the car this weekend. Then we'll see how the headers fit.
Also, I am in love with this album...
@s13cole
Old 03-22-2014, 01:32 AM   #137
Reece
Reece's Avatar
I was gonna leave positive comments until I saw that Skrillex album. WTF man. That's not right.
JB Weld is my hero
Old 03-22-2014, 01:35 AM   #138
FourtyKid
FourtyKid's Avatar
JB Weld is my hero
Like I said Reece, haters gonna hate!
Oh, and this just happened:
Now I have to fill the holes.
@s13cole
Old 03-23-2014, 12:08 PM   #139
FourtyKid
FourtyKid's Avatar
So I got the engine in....kind of.
It fits in the frame rails but the 4th runner is in the way of the steering knuckle. I think I might just end up cutting them off, and welding some new pipe in with a 3" collector and run them all on the outside of the steering knuckle.
@s13cole
Old 03-24-2014, 01:21 AM   #140
FourtyKid
FourtyKid's Avatar
I need your guys' help! Since I've removed my spoiler I'm going to paint the car. I want you guys to choose the color for me!
My dad does painting do I can do it relatively cheap. I really want to do black but sanding and getting imperfections out would be a pain in the ass. Other than black, I've got it narrowed down to:
White
Some kind of teal
OD green (tactical look)
Light Blue???
Red
Dad suggested Hugger Orange [He's an old school Chevy guy]
Silver of some kind
@s13cole
Old 03-24-2014, 01:56 AM   #141
rangerjavi
rangerjavi's Avatar
rangerjavi is an unknown quantity at this point
What about two toning it?
Being a Floridian is a birth right!
rangerjavi is offline   Reply With Quote
Old 03-24-2014, 02:01 AM   #142
FourtyKid
FourtyKid's Avatar
I would love to two tone it, but it wasn't two tone from the factory and that is sacrilegious.
One of the most beautiful s13's in the world is Nigel Petrie's:
@s13cole
Old 03-24-2014, 02:25 AM   #143
rangerjavi
rangerjavi's Avatar
No harm being done since you plan on repainting it a different color than its original paint code anyway.
Old 03-24-2014, 08:06 PM   #144
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Nothing wrong with two tone on a non factory two tone car... Just don't go around claiming it is factory.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 03-24-2014, 08:34 PM   #145
NismoRich
NismoRich's Avatar
paint it black!!!
Old 03-24-2014, 08:48 PM   #146
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Your car. Your money. Your paint.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 03-24-2014, 11:08 PM   #147
FourtyKid
FourtyKid's Avatar
Originally Posted by NismoRich View Post
paint it black!!!
I want to, but I hate sanding and it would have to be perfect!
Sweet baby jesus if I could get it to look like this someday I would be in heaven...this really doesn't help my decision to pass on black, either:
@s13cole
Old 03-26-2014, 11:35 PM   #148
FourtyKid
FourtyKid's Avatar
Does anyone else think it would look really good in this green??
@s13cole
Old 03-27-2014, 12:11 AM   #149
Reece
Reece's Avatar
Dude. Light blue. Rad chrome wheels. Body vinyl. Then come to Brainerd and we can go streeting and take cool pictures of our cars together and we'll be Instagram stars.
But really. Light blue Silvias make me happy.
Old 03-29-2014, 01:14 PM   #150
Nickel&DimeSilvia
Nickel&DimeSilvia is an unknown quantity at this point
I'm doing the swap on my s14 soon, so just wondering if you used the stock vh ecu? and is the mazwork swap kit worth the money? as far as the engine mounts go. and if you used the stock s chassis clutch master cylinder? great work on the swap btw! looks great, can't wait to get the ball rolling on mine.
Nickel&DimeSilvia is offline   Reply With Quote
