SOHC-T Coupe Build
Well I finally gave in and decided to post these pics here, they've been posted on a couple of other forums for awhile now, but you'll get the compiled version.
My build list: SOHC motor: T3/T61 Turbo JGS Manifold JGS Wastegate JGS BOV JGS Custom Sheet metal Intake Manifold Emissions removed Espelir JGT500 Exhaust Built Spare Block(awaiting cash flow) Arias Pistons or Wiseco Crower Rods Clevite Bearings PDM Cam or JWT (undecided) SCE Headgasket ARP Headstuds Hybridka.com Solid Lifter Conversion Fuel and Ignition Control: AEM EMS 30-1600 GM 3 Bar Map Sensor 720cc Injectors MSD 6a Ignition MSD Blaster 3 Coil Innovate LC-1 Wideband Drivetrain: Heavy Duty Pressure Plate Custom Kevlar Clutch VLSD C's Short Shifter Suspension: D2 Coilovers 7/5 w/ Pillowball mounts SPL Tension Rods SPL Traction Rods SPL Toe Rods SPL Rear Upper Control Arms Tein Inner/Outer Tie Rods Whiteline Adjustable Sway Bars Boxed/Welded LCA ES Bushing Set to cover parts that the rest doesn't cover ES Subframe Bushings Custom Nismo Power Bar type tension rod bracket New Front Lower Control Arms w/ ES Poly Bushing Interior: Momo Monte Carlo Wheel Sentra B13 or B15 seats(have both, haven't decided which to use) Footwork: 5Zigen FN01R-C 17x8 35 offset w/ 215/45 F 235/45 R Pics of the car in progress: Car itself is a '92 Coupe, that will sport a pignose at it's current state. Car has been thoroughly cleaned and repainted underneath. The outside has not yet been, because it's in good enough condition that it isn't a priority as of yet. ![]() ![]() ![]() Suspension Parts: ![]() ![]() ![]() ![]() ![]() ![]() ![]() Diff Cover ![]() |
