Old 01-10-2006, 07:28 AM   #121
PoorMans180SX
PoorMans180SX's Avatar
That is a frickin' sweet car... Sorry I'm not entering the KA debate, I just wanted to say that car is awesome!!!
Old 01-10-2006, 09:27 AM   #122
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Yes, 280 on an engine dyno is flywheel hp. It's around 240whp.
SOHC have been being built by Rebello at 250-300whp for many, many years. Just - unstreetable.
Good find though.
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 01-10-2006, 12:37 PM   #123
OJmobileII
OJmobileII's Avatar
OJmobileII is an unknown quantity at this point
You guys should really be talking to Datson guys and oldschoolers. There the ones that really know how to build a KA and have done it etc. And Singel cams with make the better power, and yes singel cams are good. Look at the racing world most of the fastest cars are singel cam pushrod etc
1998 Mitsubishi Eclipse GSX - 50 trim
1991 Nissan 240sx Coupe - SR20DET TD06-20G
OJmobileII is offline   Reply With Quote
Old 01-10-2006, 12:41 PM   #124
OJmobileII
OJmobileII's Avatar
SR20forum.com and Nico, KA-T etc are better because people dont go throwing out crap all over the place and try to help people.
IM NOT GOING NA BUT I LIKE TO SEE WHAT IS NEEDED,because im turbo and thats what im into, And no you dont need a honda motor to make power, every motor wil make power. Its all in how you go about it and how it will respond.
Now its proven that the singel cam is better for NA power because you can port the head alot more than the daul. And you dont need to rev to 1111,1111RPM to make power. If a Bigblock V8 can rev to 8,000 plus im sure a little 4 banger can also. I mean comon people are saying it cant be done with out knowing. Or looking it up, Ive looked it up and have found out some good info. But really dont post if you dont know. Im not 100% sure, so im not going to share mis information like most people do on here.
Old 01-10-2006, 02:10 PM   #125
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
According to the internet, that 510 has the KA24E head with a Z24 block. I believe it was David Nelson of Washington that owned that 510. He used the Nissan Motorsports intake manifold but it is shortened and the angle was slightly changed to fit the 510. It has 44mm Mikuni carbs and a Nissan Motorsports cam (not sure which one). He claimed 270 flywheel hp at 7300 rpm so I'm guessing he used the R5 race cam. Max torque was 245.
Many 510 owners claim their Rebello motors are 240+ crank hp that is STREETABLE...ie idles fine, running stop light to stop light...killer, autocross...better than turbo. Don't hate, this is what many 510 owners have sworn by.
I'll look for some more links...
allmotorKA is offline   Reply With Quote
Old 01-10-2006, 02:33 PM   #126
OJmobileII
OJmobileII's Avatar
Can you send me a link to were you found this info? Or datson sites?????????
Old 01-10-2006, 02:50 PM   #127
Sean1978
Sean1978's Avatar
Sean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of lightSean1978 is a glorious beacon of light
Send a message via AIM to Sean1978
nice.. this thread is finally going in the direction I intended it to...
My Datsun 510 Wagon
Sean1978 is offline   Reply With Quote
Old 01-10-2006, 03:45 PM   #128
irax
irax's Avatar
adding aditional Cats in california is not legal... just thought you guys should know...having custom cats are... only if your PRE OBDII.
irax is offline   Reply With Quote
Old 01-10-2006, 04:20 PM   #129
allmotorKA
Here is a link to a thread in freshalloy:
http://forums.freshalloy.com/ubbthre...=&fpart=1&vc=1
If you read from the 14th post down, you will see another person claim 244+ flywheel HP at 6600RPM and 217 ft-lb at 4700RPM on his NA KA. He also states later in the thread that CR was 9.5:1, Redline was 7200 RPM, and ran on pump gas. Sounds streetable to me. You will also see the pissing match that insued later...sort of like this thread did earlier.
Old 01-10-2006, 05:17 PM   #130
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
I beieve it! 510's and KA's kickass....
BigVinnie is offline   Reply With Quote
Old 01-10-2006, 07:35 PM   #131
OJmobileII
OJmobileII's Avatar
Bigvinnie ive seen you post on countless forums about NA etc, and you were talking to somone about a 2.8 and he was getting a motor built at a shop building KAs. Do you recall what shop is doing all this motor work with KAs?
Im not looking to go NA really, Im looking to go NA with a hefty Nitrous shot. I talked to IVAN the 240 god. Since my buddy is good friends with him and he said he was able to spray a 175 shot on a stock motor. But it blew at 250shot but lasted a little bit. Now he was blowing up a KA and beating it to hell to see what happens and doing some RnD work.
Nitrous loves high compression and Ive been around LS1s, and my buddy has a 13:1 4.6 spray motor cobra. It is a all spray mod motor with up wards of a 400 shot on a daul stage. It can be driven on the street and he takes it out on weekends. It just needs race gas etc....... I also read you were spraying at one point but you got sick of bottles etc.
I would like to know what you think of the K and how it was on spray etc, If anyone tells me that High compression and nitrous is bad, im not going to listen and thats the end of the story so dont go there. I do have a whole turbo setup and the side and it would be good for 400plus but I really would like a spray car that is quick on motor etc
Old 01-10-2006, 07:49 PM   #132
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
I also noticed he outright said it was a robello engine. obviously it has had some work done. pissing contest must end, just buy a robello engine and be done with it.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 01-10-2006, 08:41 PM   #133
someguy_240
someguy_240's Avatar
someguy_240 is an unknown quantity at this point
Send a message via AIM to someguy_240
which header is this? and for the record ive seen 220hp dynod kae's (more like a hybrid datsun/nissan frankenstein motor) and seen them first hand they are streetable. unfortanetely i dont have my friends ka dyno because he threw it away after he sold his 510.
sorry for gettin jus a bit offtopic but i dont think ive seen that header? anyone help?
*** ok found out it was a rebello header
found info about david nelsons car but im not sure if i can post from a different forum
"...But my tires were wet!"
someguy_240 is offline   Reply With Quote
Old 01-10-2006, 08:47 PM   #134
Jeff240sx
I hate you too...
Jeff240sx's Avatar
9.5:1 cr + 7200rpm and 244bhp (200whp-ish) means it's the $5000 motor I laid out on page 3 (or 4), with every bolt-on imaginable, and cams.
Sure it's streetable. But it's not the 300bhp motor that was mentioned in this thread.
-Jeff
Whatup?
Old 01-10-2006, 10:00 PM   #135
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
http://www.ermish-racing.com/510parts/partshome.htm
Click on engines....carbed twin cam.
The Bay Area 510 people I've met recommend them. They supposedly have a nice 250HP street setup with Z22 bloc, single cam head, and 44mm mikunis.
atom is offline   Reply With Quote
Old 01-10-2006, 10:06 PM   #136
OJmobileII
OJmobileII's Avatar
Nice info......... Were are all these Datson guys? I hear about these cars alot but dont see them.
Old 01-10-2006, 11:23 PM   #137
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
thats troy's shop in fremont.. i just drove around there.. couple days ago... first thing u see when u make that left turn is nothing but 510's wagons 2 doors 4 doors... thats like nissan central in that industrial park... not hard to get to either.... right off the 880 freeway.. 12 valves are nice.. but more valves are better..
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 01-11-2006, 12:51 AM   #138
allmotorKA
I think he made his own...the rebello header did not fit his 510.
Old 01-11-2006, 11:15 AM   #139
Gnnr
Gnnr's Avatar
Damn thats a sweet 510. Any good 510 forums websites anyone know of?
Gnnr is offline   Reply With Quote
Old 01-11-2006, 07:07 PM   #140
someguy_240
yeah my bad, i read it wrong. thanx
Old 01-16-2006, 02:34 AM   #141
infinitexsound
dimequarterly
Old 01-16-2006, 03:22 AM   #142
andrewmp6
andrewmp6 can only hope to improve
that pic was a l28 and a high power n/a youll have to run high compression and higher octane fuel ill stick with a rb
andrewmp6 is offline   Reply With Quote
