10-29-2013, 05:48 PM | #15271 | ||||
Trader Rating: (58)
Feedback Score: 58 reviews
10-30-2013, 10:56 AM | #15272 |
anyone know about what suspension parts swap over from the s13 to the s14?? i have an s13 with everything and an s14 shell with no rust at all, just wondering if the subframe and other suspension parts would swap over with little work
10-30-2013, 02:18 PM | #15273 | |
AFC #1
Just noticed this. Thanks Cody...
http://zilvia.net/f/tech-talk/102582...fter-dyno.html
10-30-2013, 11:40 PM | #15274 |
Trader Rating: (92)
Feedback Score: 92 reviews
I bought a oil filter relocation kit ( Used ) from a fellow member , my question is and im pretty sure the answer is NO but .. can i reuse the o-ring? i did some searching its DERALE PERFORMANCE single top port filter mount 3/4"-16 threaded oil filters
question 2 what if the oil pressure for ka24de's idle/and at WOT ? just want to make sure that ill be ok and with in spec by relocating the oil filter. |
10-31-2013, 03:14 AM | #15275 |
I have an AE86 SR5 Corolla.
Bad brakes, bad tires, no power steering, needs tags, needs smog. There is someone willing to trade his 1990 240SX for my car. I very badly want a 240 and to be rid of 86. His car is on non op and he has the pink slip on hand. He says his car doesn't run due to a "rod". I realize this might mean metal hit metal and might need a new engine. I looked up a rebuild kit and it costs about 400$. Will the rebuild kit fix this kind of problem? My car is my dd and I use it all the time, it's reliable. I guess what I'm asking is, is it worth it or stupid?? I would greatly appreciate all the input, thank you very much. Sent from my SPH-D710 using Tapatalk Sent from my SPH-D710 using Tapatalk |
10-31-2013, 09:29 AM | #15276 | |
10-31-2013, 09:31 AM | #15277 |
10-31-2013, 04:17 PM | #15279 |
AFC #1
Pads are the same. All the 4 piston fronts and 2 piston rears use the same pad sets(F/R).
10-31-2013, 10:20 PM | #15282 | |
Control arms, only the traction (short) and upper control arms will swap over no sweat. The toe arm (really long arm) has different bushings, the s13 bushing is short while the s14 bushing is wider, so you can just swap out bushings and it'll fit. The rear lower control arms on the s14 have wider bushings as well and you can't swap a smaller bushing arm from an s13 to the s14. Similar year J30 or Q45 has the same rear lower control arms as the s14, but the ball joints are different sizes i believe. I can't remember if the Z32 had the s13 rear lower control arms or not, but everything else on a rear z32 and s13 is the same, sans the subframe. You can swap the traction and upper control arms of a J30 or Q45, also the Q45 toe arm will work with an s14 not sure about the J30. So somehow you can piece it all together. |
11-01-2013, 03:15 AM | #15283 |
Anyone happen to know the font type and font size they use for the sticker on the rear rocket bunny wing/(over)fenders?
Shown here that says "Rocket Bunny" Finishing up my rocket bunny and all I need is the rear wing(coming sometime next week) and I would like to get a custom sticker made. Sent from my GT-I9505 using Tapatalk 2 |
11-01-2013, 06:13 AM | #15284 | |
11-01-2013, 08:07 AM | #15285 |
Did USDM S13 coupes ever come with a rear spoiler? Got a PS13 Silvia with a spoilerless boot but the car originally had a spoiler so every time I open the boot it flicks up violently due to the torsion bars or whatever. Anyone know how to fix it without weighing down the boot/removing the torsion setup completely?
11-01-2013, 08:44 AM | #15286 | |||||
Trader Rating: (58)
You'll be fine pressure wise, it's not going to change that much if at all on the gauge. Quote:
They may be able to help? Quote:
11-01-2013, 02:09 PM | #15287 |
What kind of temperature reduction can I expect before/after the radiator?
This is for track use only. It's an SR, I have a Koyo N-Flow and dual FAL fans (S-blade) with shroud. run straight distilled water and a bottle of water wetter. No heater core, no AC condenser. I have a fanless oil cooler as well. Thx. |
11-01-2013, 10:31 PM | #15288 |
I didn't want to post this question in the fitment thread so I'm asking it here. I am picking up some used PBM coils this weekend and I was wondering if I will have to do a chassis harness tuck to keep from rubbing. Nothing major as far as fitting big wheels, I'm only using 16x8 0 offset, with 205/50/16 tires. I have already tucked the drivers side harness but didn't have time to do the passenger side and I'm not wanting to pull my fender off at the moment. I am planning on going nearly as low as possible but not quite maxed out. Any helpful advice would be great!
11-02-2013, 08:59 AM | #15289 | ||
11-02-2013, 10:45 AM | #15290 |
Thanks DriftBadger, that's exactly the advice I was looking for. If there's even the slightest chance of rubbing and leaving myself stranded I'd rather tuck. My fenders are rolled believe it or not. I have to apologize for my supposed location. I was getting a lot of hate on some comments I posted in another thread(cant remember what one) so I "changed" my location to "Floriduh". I'm in Canada...
11-02-2013, 08:17 PM | #15291 |
Chuki, definitely take the time to tuck the harness! My passenger wheel is 1/2" front the top of the wheel well and it never rubs. But I rubbed through it by the grommet in the firewall. I'll be tacklin this pita sometime soon.
I wish I did it when I hammered the tire killers Oh also, the passenger harness is just wipers, wiper fluid, and cruise. Maybe something else, so it can't leave you stranded. |
11-02-2013, 08:33 PM | #15292 | |
Trader Rating: (58)
Hard to say. You should be around 200-210 post head temps I'd assume.
11-03-2013, 07:22 AM | #15293 |
hey zilvia. i was looking over my ka since its out of the car and when i wrecked my car i smashed the aac plug off the firewall, so i took just the aac off the iacv and was looking over the aac and seen the little pintle like thing in the aac and figured it should move, but it was stuck. my question is shouldnt you be able to push it in and it pops back out or does it need manifold pressure to push the pintle? i got a new one anyway since the plug was smashed, just wondering if theres a way to check if they are good.
11-03-2013, 07:54 AM | #15294 | |
11-03-2013, 12:56 PM | #15296 |
Installed 30mm rotors on a s14 along with Hawk pads. Brake feel was horrible and eventually the rotor and pad seized up?
Has anyone seen this or heard of this happening? The fit was super tight with both new pads and rotors. Thanks for any inputs or direction. |
11-03-2013, 09:44 PM | #15297 |
How much does coilover droop effect ride quality? I'm on blown kei office(yes I know, upgrade time) which I believe is 9k/8k. The front and back are drooped 2-3" because the bottom collars were stuck.
Would I benefit greatly by preloading them and really working on the collars? My springs feel really soft, like softer than my grand am. I'm not sure if it's because they're old or the droop. Thanks guys. |
11-04-2013, 09:58 AM | #15298 |
Well, someone asked about where to buy these s13 clear tail lights and Andy's Auto Sport has them. Thread got locked, so I'm leaving here for whoever wants to buy them. Email this guy and ask. I just want to help fellow members. That is all.
[email protected]
courtesyparts.com |
11-04-2013, 11:02 AM | #15300 | |
