07-23-2011, 06:21 PM | #1534 |
Which would stretch easier on a 18x10, 225/35 or 215/40?
Would anyone happen to have pictures of a 215/40 on 18x10? I currently use 225/35 but am considering switching to 215/40, unless they would be significantly more annoying to stretch. Thank you. |
07-23-2011, 07:23 PM | #1535 |
Honestly, I've found that tire size x wheel size doesn't always matter.
Different tires and different types of wheels all work differently, I found that out the hard way when I tried mounting 215/40 General uhp's on a x9.5 rpf1. It was pretty much impossible. I tried cheetah, starter fluid/brake cleaner, inner tube, blah blah blah It refused. Yet other tires mounted right up. Anyways, to awnser your question, I think a 215/40 is easier.
07-23-2011, 08:29 PM | #1536 |
The 215/40 will be taller, even stretched, correct?
The main reason I am looking to do this is because I would like to tuck up the wheels a bit higher while staying at a similar ride height. |
07-23-2011, 11:26 PM | #1538 |
matej, bumping up to the 40 will raise the "body"
when i used to run 35s i didnt have to lower my car as much to get the kit to sit level, after i bumped up to 40 sidewall i had to lowered it a lot more and now is tucking rim to get it to sit where it was before. im having a hard time deciding on which i like more.
@pwrmves14 |
07-24-2011, 12:19 AM | #1542 | |
Trader Rating: (58)
Feedback Score: 58 reviews
1991?
07-24-2011, 05:52 PM | #1544 | |
215/40/18 on 10J Yokohama S Drives |
08-03-2011, 03:36 PM | #1546 |
In time-out for misbehaving.
08-03-2011, 03:54 PM | #1547 |
That looks very nice.
I ended up going with 225/40, only because Craigslist is full of them, whereas 215/40 seems to be less common. Still like it though, lately I am into the tiny tire up front and taller tire in rear look. Race car. |
08-04-2011, 02:22 PM | #1548 |
matej thats my old setup .. 10s with 215/40/18 falken 512s
and new set neogens 215/40/18 on 10s u can see the neogens have the wheel lip protection.. so r little more fat.. and i already fucked up my fenders (cut the tire) lol so definetly falkens r better for that |
08-07-2011, 02:28 PM | #1549 |
I have 18x10 +10 up front and I want to slam the car. I plan on running a 225/40/18 ss595 federal. Will I have rubbing issues in the wheel well? Should I go with a 225/35/18 because I heard federal sidewalls run bigger...
08-13-2011, 02:24 PM | #1552 |
hi guys..just had flat tire today.. with 215/40/18 on 10 wide wheel.
its there any chance to save the tire and fix it? i mean can the repair hold the 60psi installation pressure and 40 psi pressure while driving? |
08-14-2011, 08:47 PM | #1558 |
Dan?
Alright. I'll be using 20/30mm fenders. I'm planning on -14 with tons of camber in front. I'm tucking wheel in the rear right now and want to continue doing so with the VS-KFs, but I need to get the front down lower. Right now, I'm reverse raked to keep from breaking tie rods and/or binding up at lock. Since I can get 225/45 rears for free all day, I figure 225/35 up front should level me out. 215/50 rear, but you get the picture. You can imagine how bad the reverse rake is with 225/45. |
08-14-2011, 09:14 PM | #1559 |
yes hi
ok, good your getting fenders! not sure the height difference but i think 235/40 would be better for the rear instead of 225/45. 100% do the 225 35 front.
@pwrmves14 |
08-14-2011, 09:35 PM | #1560 |
hey zilvians im running a 225,50,15 on 10 inch wide centerlines wheels and they have already popped on the beads from canyon driving. What tires shuld i use to be more function for street/canyon driving?
